Question about Freestyle Shark Classic Mid Size Watch
The mode button wont work - Freestyle Shark Classic Mid Size Watch
You should be able to find the instructions on our website: http://www.freestyleusa.com/support/instructions/
However that is an older watch, I think this is how you set it.
When in time mode, hold down the mode button for 3 seconds. That should put you in set mode.
If that doesn't work try holding the set button down for 3 seconds.
If neither of those work, please contact our warranty/repair department and they will be able to help you out.
Warranty/Parts & Repairs:
47-14 32nd Place
Long Island City, NY 11101
Phone: 800-874-0907
nyu@genevawg.com
http://freestyleusa.com/support/warranty/
Posted on Jan 04, 2011
How do I use the buttons in this QHY watch?
Hopefully, this will help...
Lego Watches Manual Instruction:
There are 4 buttons on this lego watch case, Light button, Mode button, Stop button and Reset button, now I will show how to set the time easily!
1, Light Button: Press this button, the watch LCD light will display for 3-5 seconds;
2, How to use the stopwatches chronograph function?
Answer: When the lego watches in normal working condition, Press "Stop button" for 1 time, then the watch goes into the chronograph mode, then you can use "Stop button" and "Reset button" to operate this function.
3, How to set the alarm time?
Answer: When the lego watches in normal working condition, Press "Stop button" for 2 times, then the watch goes into the alarm mode, then you can use "Stop button" and "Reset button" to set the alarm time, also you can turn off or turn on the alarm function and chime on every hour function by the same operate.
4, How to set the right watch time, hour, minute, second, week, date, month, year?
Answer: When the lego watches in normal working condition, Press "Stop button" for 3 times, then the watch goes into the time setting mode, then you can use "Stop button" and "Reset button" to set the second, minute, hour, week, date, month and year.
This is all. So now please have a try to set your lego watches time!
Dec 06, 2014 | Watches
Nike Triax Fury works after replacing battery, but buttons wont work or change anything!
I had the same problem - replaced the battery of my Nike Triax Fury and the time was blinking and none of the buttons were working. Turns out that you need both springs placed in the proper spot - the silver and gold springs. Both springs can be placed in their proper spot with the batter in. The gold one goes in the tiny hole near the "view" spot, and the silver spring goes year the 'cage' that holds the battery in place accross from the gold spring. Good luck.aa07e646-2c11-45e3-b8fa-b40ec2fd82c2.jpg
Nov 29, 2012 | Nike Wr0139001 Triax Fury 100 Regular...
Athletic wrist watch stuck in 24 hour mode
Maddening, isn't it? Fortunately the solution is here:
http://www.ehow.com/how_5593310_set-athletic-works-watch.html
1 There should be four buttons: mode, reset, start and light. Find the mode button and press it three times until it is in the set time mode.
2 Find the reset button, which usually is located on the bottom right side of the watch face, and hold it until the time starts blinking.
3 Press the start button to change minutes.
4 Press the reset button again to switch to hours.You will know it worked when the hour starts blinking instead of the minutes.
5 Press the start button to change the hour. The watch can handle two modes: standard and military. As you press start, the hour will change from AM to PM, noted by an "A" or a "P" in the top right. When you get through 24 hours, the watch will change to military time and an "H" will be displayed instead of "A" or "P." Keep pressing start to go through another 24-hour cycle and it will revert back to standard time.
Apr 30, 2009 | Watches
Auto light wont turn off.
You need to press & hold the forward button on the right side of the watch for a few seconds. That will turn off the auto light
Aug 05, 2008 | Casio G-shock G2300B-1V
Watch
Hold down the mode button and it should start blinking on the seconds. If not the mode, then the adjust button, but hold if down for a few seconds. Then if it was the mode button probibly the adjust changes the time, if the adjust , then the mode button should adjust the time. I don't know if it just adjust the seconds and then you have to move to hours and then min and so forth, but if you do just try the st/stp button. Tell me if this works, it should but if not I'm here to help. Good Luck!!!!
Jul 09, 2008 | Watches
I need to adjust Timex 1440 sports watch. could you help me please. I have top left as mode, top right start/stop,bottom left indiglo and bottom right is set. Thank you jyo
Go to the time mode,hold down the set button, it may take a couple of seconds and it will start blinking , then go to your mode button to move from seconds to hour to min etc.etc,etc. It probibly is your start/stop button for chaning the numbers. If that dosn't work, hold down the mode button on the time mode for a few seconds, and go from there.
Jun 29, 2008 | Timex Watches
Timex 1440 sports WR50M
Solution #2 by Guest, posted on May 13, 2008 solved my problem. OUTSTANDING solution #2!
1. Hold in the MODE button until the alarm time appears.
2. VERY IMPORTANT - release and TAP the MODE button AGAIN, and the time should appear with the seconds flashing.
3. Use StART/Stop to choose among seconds, hours, and minutes, and
4. Use ADJUST to increase the selected number
5. Press MODE to put the thing back in regular operational mode.
After several attempts with other directions over the last four months, these 5 steps WORKED.
Mar 30, 2008 | Timex 1440 Nylon watch
Timex 1440 sports digital watch time setting
  1. Press and hold the mode button until it starts to blink, then release.
  2. First the alarm time will come up.
  3. Press the mode button once to get to the time and date.
  4. The seconds will flash first.
  5. Press the st/stop button to toggle between the seconds, hour, minutes, date (month and day) and day of the week.
  6. Press the lap/reset button to change the values.
  7. When done, press the mode button again to return to normal.
Mar 09, 2008 | Timex 1440 Nylon watch
Timex 1440 sports watch, WR50M
In "Time Mode" when time is displayed, hold the "mode" button until the alarm flashes. Press the "mode" button again and the display should change to the seconds flashing. Press the st/stop button to change location between seconds, minutes, hours, date, month, and day. Use the lap/reset button to make any changes.
Feb 15, 2008 | Timex 1440 Nylon watch
Compass wont work correctly
if your hands aren't straight when you use the compass try this to sync the hands.
1. Press and hold the middle button to enter T-Touch mode.
2. Press the centre area on the face twice to display 24hr/12hr
3. Press and hold the middle button to enter T-Touch mode untill screen says sync.The hands will face 1200.
4. Press either the upper (East) or lower (West) button to adjust the compass hands. They should both face 1200.
5. Press the middle button to get back to 'regular' compass mode. Note that your offset setting will still show in the digital area.
Oct 10, 2007 | Tissot T-Touch T33759851
Freestyle Shark Classic Mid Size Watch Logo
243 people viewed this question
Top Freestyle Watches Experts
ray gallant
Are you a Freestyle Watch Expert? Answer questions, earn points and help others
