Question about Sansui Televison & Video
The remote contro of my scart01h does not work. I though the battery run out in the first place, but after chenge them it is still bloqued. What can i do?
Remote will not do anything
1) change the batteries by new ones
2) clean the contacts batteries with spray contacts cleaner
3) resolder the wires connector batteries.
4) open the rem.contro and clean the keypad from oxide, with cleaner contacts.
5) otherwise you must go to the repair shop TV.
God bless you
Jun 30, 2012 | Televison & Video
My remote won't set to the tv I tried pressing the set button and it didn't work then I replaced the batteries to see if that would work but it didn't and now I don't know what to do please...
Hello
You might have a cellphone with camera option. Set the cellphone co cemera mode, and place the remote control at about 1 feet away from its camera lens, and press each button on your remote control. Remote control emits infrared rys as we press each button, but can't be detected by human eye. Electronic cameras can detect it. If there is any infrared ray emission from your remote control you will see its image on the camera screen for each button press to your remote control. If there is image and still the Tv doesn't respond to it, The TVs' infrared snsor inside has damaged and should be replaced. If there isn't any image; check the battery contacts of the remote battery compartment first. Clean these contacts by using a piece of corborandum paper or with the tip of a razor blade. Improper battery contacts, due to rust and dust to these contacts will prevent the battery supply voltage to enter into the remote contro.
Still it doesn't work at all, the remote control is damged and should be replaced. Contact the nearest Vizio Authorised Service Cente fro original remote control. OK.
Jul 21, 2011 | Vizio VF552XVT 55 in. LCD HDTV
Remote will not operate volume or on/off switch
Hi
Check your remote control for its infrared emission. You can check it with the help of a cellphone with camera option. Put the phone to camera mode, and place the remote at about one feet away from it lens, and press each button on your remote control. If there is any infrared emission from the remote control, the cellphone camera will sense it, and you can see its image at its screen. Before doing this test, put new batterys to your remote control. If ther is no infrated image seen on phone camera screen, check the battery contacts of the remote contro for any rust or dust. If they are also OK, and still there is no image on the camera screen, the remote control is damaged. OK.
Jul 14, 2011 | Televison & Video
Does not work
Hello
Check its battery contacts first. In remote controls, if battery contacts get rusted or dusty, proper battery connection will not occur. If battery contacts are good, check its infrared emission. You can check it with the help of a cellphone with camera option. Put the cellphone to camera mode, and place the remote control just one feet away from its lens, and push each button on the remote control. Eventhough human eye cannot detect infrared rays, electronic cameras can. If there is infrared rays emitting, you can see its image on the cellphone screen. If not, be sure that the remote contro is faulty. If there is infrared image, and still the device you wants to control does not respond; infrared sensor inside your device is faulty, and should be replaced. OK.
Jun 15, 2011 | Radio Shack (15-2147) Remote Control
Technika universal remote tr41r remote codes for technike tv dvd freview combi
Hi, I have a Technika LCD26 620 TV and ave a Technika TR41R remote contro but i cant find the code?
Any help please..
May 31, 2011 | Televison & Video
Remote will not work. I have chged the batteries and made sure they were in correctly
Hello
Check the remote contro for its infrared emission. You can check it with a cellphone with camera option. Put the cellphone to camera mode, and place the remotes' front end towards its lens, at about one feet away from it, and press each button on the remote control. If there is infrared emission from it, you can see its image on cellphone camera screen. If not check the remote control. Check the battery polarity. If it is alright, you have to open it to see whether there is any loose soldering points developed or not.
If ther is infrared emission from the remote, and still the TV doesn't respond to it, surely the infrared sensor inside the TV is faulty, and should be replaced with same type and number. OK.
Mar 26, 2011 | Emerson EWD2204 DVD Player/VCR
Remote contro effective range has dropped to less than 10 ft. New batteries do not correct problem.. I have to tv's with two remotes. Neither remote makes any difference. Both remotes control the...
the IR sensor could be going bad or maybe it slipped down inside and now isn't getting good signal. Let me know if you want to open it up and do some checks.. If the IR sensor looks like its in a good place, it could be failing.
Jun 19, 2010 | Vizio VA26L 26 in. LCD HDTV
What code?
try 0164 - works my toshiba
Aug 26, 2008 | Televison & Video
Televison & Video Logo
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
