Question about Samsung S860 Digital Camera
Card is locked when i am inserted a memory card in samsung camcorder.i tried moving up the part in SD.But still i am getting same error.Its a brand new.can tou please help me out ??
  • hamnas_21 Jan 03, 2011
    i couldn't format.its saying write is protected.
  • 65 Answers
Try formatting the card. Either with the camera or a pc with a flash card reader.
Posted on Jan 03, 2011
  • prouddad_1 Jan 03, 2011
    check for a little switch on the flash card. Some of them come with a write protect switch
Anytime I inserted memory card to my Samsung Digimax S600 Digital Camera it an error message is displayed saying "MEMORY CARD LOCKED". I have tried other memory card but i received the same message. How...
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Sep 14, 2010 | Samsung Digimax S600 Digital Camera
I just bought a new memory card (8gb) for my digital camera (Samsung NV10) and when I inserted the memory card, I kept getting "Card Error". It said I should format the new memory card and I tried to...
The largest SD card you can use in your Samsung NV10 is 2GB. thats why once you insert the 8GB sd card its shows card error or need to fromat.
FYI. for every digital camera there's a compatible memory card and you can see from the box or manual and Its writen SD or SDHC.
goodlukc and thank you
Aug 10, 2010 | Samsung NV10 Digital Camera
Keeps saying card locked when i want to record - is it the card that has gone wrong or the camcorder
Hello
Kind regards
Andrea
Apr 04, 2010 | Panasonic SDR-H40 HDD Camcorder
Memory card error replaced card but still get error message?
Is it the SD memory card? or the Micro HDD(4GB) you're pertaining to. In case of micro hdd not detected or error, micro hdd socket(CF) assembly has a problem most likely, need to be replaced. SD card; check your SD card's capacity, it can handle only up to 2GB or try to format your card elsewhere and re insert it again in your camcorder, if it will prompt you "FORMAT SD CARD?" you're lucky
Feb 25, 2010 | JVC GZ-MC500 Memory Card Camcorder
How to unlock my memory card
On side of The SD card there is a little lever that slides up and down this is the protection lock. PUSH it all the way to the top. Sometimes when inserting it gets caught and will move just enough to have the camera consider it locked. So be careful when inserting it.
If this does not fix it try another SD card or reformat it.
Please rate my help++++Thanks for using FIXYA
Feb 07, 2010 | Cameras
How to format a SD memory card for samsung
Hi Sir
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Sep 09, 2009 | Samsung SC-X210L Mini DV Digital Camcorder
    My hdd is full and I want to record on a 16GB SD card. When I insert it and try to format it does not format and I get a message state memory card error.
    few, if any, SD cards larger than 2GB are SDIO compliant. Most cameras which take SD require SDIO-compliant media. Try a branded card (eg Samsung, Kingston) which is certified SDIO media.
    Jul 03, 2009 | JVC Video Cameras
    Memory card error
    Hello
    Kind regards
    Andrea
    Apr 14, 2009 | Samsung Digimax 401 Digital Camera
    16G Memory Gets "Memory card Error Please Check Memory Card"
    You may try to format the memory card and then try again. If needed, you can use a camera photo recovery tool to recover photos from memory card.
    Card Recovery Software Free Download
    Apr 10, 2009 | Panasonic DMC-TZ5 Digital Camera
    Memory card error
    did you already formated your memort stick? try to remove your memory card from your camcorder and insert it again. look for the settings on your camcorder. it might cause the problem. hope that helps!
    CHARCOIS
    Aug 17, 2008 | Samsung SC-D103 Mini DV Digital Camcorder
    Samsung S860 Digital Camera Logo
    Top Samsung Cameras Experts
    Kazim ERGUNEY
    Kazim ERGUNEY
    Are you a Samsung Camera Expert? Answer questions, earn points and help others
