Question about Siemens HB77L65GB 900 Watts Convection / Microwave Oven
Hello, I have a microwave Siemens HF 66051.The oven is working perfect,but the microwave doesn't.The fuses are well. Do you have any idea?
    Brigadier General:
  • 8,909 Answers
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
This is a job for a proffessional but if you are safety clued up, here's instruction.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 or moving coil meter on high resistance range for short circuit, (DVM's won't show the fault!), the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Posted on Jan 03, 2011
Replaced 20amp fuse that was blown. new fuse did not blow, but oven is still dead.
see this causes and fix it. God bless you
If your microwave oven doesn't seem to work at all, check these: Fuses Door switch Fuses Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it. Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work
Sep 22, 2012 | Cuisinart CMW-100 Microwave Oven
Is there an in-line fuse to the magnetron on a Siemans HF 75950 GB /02 combination over
Microwaves have a main fuse (typically ceramic) as well as thermal fuse. You can find a variety here: http://www.electronix.com/microwave-repair-fuseslamps-c-557_560.html
Jan 27, 2011 | Microwave Ovens
The microwave has no power! I have checked the fuse and it's ok..what can be wrong? Thank you, Julie.
Julie please go through your manual there are some buttons you need press to get the microwave working
Jan 19, 2011 | Siemens HF17055GB Microwave Oven
Glass door for a Siemens microwave hf 879
I've the same problem. Inside glass broke while heating.
May 20, 2010 | Siemens HF87950GB Convection Microwave...
Was working perfectly fine- just started buzzing when turned on and is not heating
Hello :
It could possibly be a fuse. as cheap as they are nowadays, I would recommend to replace it rather than risk taking it apart .
If it's not the fuse :
Did you switch it while there was nothing inside it lately ? Is there any error code displayed ?
good luck .
please rate !
Mar 28, 2010 | GE JVM1440 Microwave Oven
MW8115SS worked perfectly and then went dead
Blown fuse , take the outer cover off and change the fuse. Iff you don't have a fuse use a piece of tin foil until you find a replacement fuse.
Hopefully this helps you out.
Aug 18, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
I have a Siemens microwave (inno-wave) that we have had for 3 years. It is a HF 17055GB/02. When I try to cook something, say I set it to cook for 2 minutes, after 23 seconds it stops and reverts back to...
I wonder if this is an inverter-based model... I ask because on Panasonic/Quasar units, a problem with the magnetron or inverter will cause this very symptom.
If so, because of the voltages and currents involved, I do not recommend that someone without experience attempt repairs on an inverter circuit.
I would contact the manufacturer at the number in your owner's manual to find the nearest authorized servicer.
Sep 25, 2008 | Siemens Microwave Ovens
Start button
I have a related problem, my Siemens microwave/oven as soon as I press the start button brings down the fuse. I put up the fuse again, the clock is working, the light inside as well, but as soon as I set the microwave on and press the start button, it brings the fuse down again. Is this a problem with the siemens microwave or with my electrical installation?
Jan 09, 2008 | Microwave Ovens
Siemens HF 87960 GB Microwave/Combo Oven
Please, Can somebody tell me where can I get one of this oven??? Thanks Andy
Dec 08, 2007 | Siemens HF87950GB Convection Microwave...
Siemens HB77L65GB 900 Watts Convection / Microwave Oven Logo
673 people viewed this question
Top Siemens Microwave Ovens Experts
William Miller
William Miller
Steve
Gerry Harvey
Gerry Harvey
Are you a Siemens Microwave Oven Expert? Answer questions, earn points and help others
