Question about Emerson 025806092806 Microwave Oven
The plastic film inside the window on the door is pulling away from the glass. Does this consttute any danger. Does it or the micrwave have to be replaced? Other than that the microwave works perfectly.
    Brigadier General:
  • 8,909 Answers
The film stops food particles and steam from entering the part of the door that is difficult to keep clean. That is all it does.
No danger just difficult to clean.
Posted on Jan 03, 2011
I own a microwave: model # jes636wk01 There is a plastic film covering the wire mess on the inside of the door. Will the microwave operate safely if the film is damaged or removed?
yes. It is there to protect the glass from food splatters It is the panel with the million holes that controls the micro waves I would not remove it but have it replaced if damaged.
Jun 09, 2013 | Microwave Ovens
I have a Kenwood microwave oven which has a plastic film on the inside of the glass door. I have used it like this since new as it was not obvious that a film was stuck on the inside until now as it is...
It should have been removed from new. Much of your foodstuffs could have contained toxic substances that leach from this plastic membrane. But as you are writing to ask then you have survived so far.
Remove it......
Please rate my help++++Thanks for using FIXYA
Dec 09, 2009 | Microwave Ovens
The film on the inside of the microwave oven door has bubbled & is raised off the glass. Is it safe to use.
No, that must be patched or replaced. It's critical.
The film protects the door screen from getting food, grease or moisture in it, which can lead to corrosion and arcing.
The screen prevents microwave energy leakage, which can cause arcing and fire.
If the bad spot is not too big, you can cut it away and clean it squeaky clean and patch it with clear packing tape.
If it's too bad to patch, you'll have to see if you can get new film, or if you need to order the inner door panel or whole door.
You can locate Sanyo manuals, part distributors and authorized servicers here.
You can find Sanyo UK microwave owner's manuals here. You can find Sanyo UK support, parts and authorized servicers here.
Oct 29, 2009 | Sanyo Microwave Ovens
Remove door film
First let me tell you micro doors are dangerous to mess with if you are not trained to do so,if the film is missing or damaged you can order it from any appliance parts wholesaler,
But most manufacturers prefer you replace the whole door it's much safer.
Aug 14, 2009 | Microwave Ovens
Condensation inbetween glass door on GE Spacemaker
Your glass seal has failed and I doubt it makes sense to replace the door. Yes, it can be dangerous as the moisture becomes worse you risk the chance the glass could over-heat and blow out. Sounds like you need to replace it, sorry!
Aug 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Leaking Microwave door seal (between grated and back of door)
I think that you can get the plastic wet, ie sponge, or lick.
Jun 26, 2009 | Microwave Ovens
Damaged door on microwave
Buy a detector to test your microwave to be sure it is not leaking radiation. The detectors range in price from ten dollars to about thirty five dollars and can be purchased in most hardware stores. If you discover that the microwave is leaking radiation, never try to repair this appliance yourself. Take the microwave to a professional for repair. All things considered though, the microwave oven is fairly inexpensive these days it may be a better idea to just purchase a new one.
Apr 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Food splatter behind screen on door of microwave
If you take the glass out you have to find a deaker or someone who the tools to check for leaks around the glass.
Mar 17, 2009 | GE JVM1640 Microwave Oven
We burned perforated plastic inside window of door.
Explain this to me in more detail, write me at home wbwill@sbcglobal.net, this could be dangerous, I don't know what you mean you by burning anything, but if you burn't something, why, and will that happen again, and what is this perforated vinyl?
Is it the enclosure of the oven, see through the glass?
Explain this to me, soon as you can.
Will
Dec 16, 2008 | Whirlpool GH7145XF Microwave Oven
Microwave Oven replacing plastic film on inside of door
FSP stands for "Factory Service Parts" which I believe was originally terminology from Amana, which now (along with several other brands such as Electrolux, Frigidaire, Jenn-Air, Kitchen Aid, Litton, Roper, and Whirlpool) is now under the Maytag umbrella.
Confusing, eh??
Hopefully the new one will have adhesive included. If not, then you'll have two sheets to use to get it right.
In that case, I'd probably recommend the spray-on type adhesive you can find at hardware stores or big box stores such as Wal-Mart, Home Depot, Lowe's etc. It will probably be made by 3M.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
May 20, 2008 | Microwave Ovens
Emerson 025806092806 Microwave Oven Logo
1,033 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
