Question about Zanussi FJ1254W Front Load Washer
Keeps stopping through cycles - Zanussi FJ1254W Front Load Washer
  • gardinersimo Jan 07, 2011
    fab ill try it out
  • 4,323 Answers
Hi
IF the water drains completely then check the door lock-switch assembly, if that is fine then the issue is with the timer motor that is bad and should be replaced. When this part goes bad the unit will not complete cycle or will stop in between the cycles. Hope this helps...please post back for further assistance.
Daniel
Posted on Jan 04, 2011
How do I fix my cycling dryer.
so you have not done any work on the electrical system at all changed anything or anything like that do you have a model number Appliance 911 Sea Breeze
Nov 15, 2015 | Maytag Dryers
Cold water won't stop before rinse cycle
if it fails to stop running only at the rinse part of the cycle it is probably in the timer as the solenoid valve has to cut the water off when the washer fills for the wash cycle too. fills for wash cycle and cuts off water, washes and drains, refills for rinse cycle and water just keeps running? does this every time you run it? that's in the timer. bad solenoid (water inlet valve) would keep running even on wash fill up. hope this helps.
Feb 25, 2014 | LG WM2688H Front Load Washer
Rinse and spin cycle keeps repeating at 11 minute time to 17 minute time and won't stop
Sounds like your washer does not empty enough water for the spinning to stop. Have you check that the filter(s) are not clogged?
Jan 23, 2013 | Samsung WA5451ANW 4.7 cu. ft. Top-Load...
S5N27B keeps stopping mid cycle
If the cycle doesn't complete, check these:---
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows: On some units, the pause is timed and the unit continues after the allotted time. On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too. Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Dec 28, 2009 | Bosch Dishwashers
Kenmore dryer wont stop, just cycles through all the setting
Replace the timer if it continues through and past a timed cycle.
Aug 03, 2009 | Kenmore 62802 Electric Dryer
Timer keeps clicking round all the time, does not stop
You need to replace your timer, it controls the wash cycle. Depending on make and model they are relatively easy to replace and not to terribly expensive.
Feb 23, 2009 | Washing Machines
Washer machine problem.
Hello noemystotler
You said,
On the last spin cycle water, never stops keeps spraying. Triede different cycles same problem I even disconnected machine in same problem.
sounds like the timer is not progressing and is defective!
Aug 03, 2008 | Kenmore Elite HE4 Electric Dryer
Washer keeps stopping mid cycle
Bad timer motor or mechanism...accordianman
Mar 21, 2008 | Dishwashers
Keeps stopping
I have a feeling you are buying a timer board.
Dec 11, 2007 | Kenmore Elite HE4 Electric Dryer
Zanussi FJ1254W Front Load Washer Logo
134 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
