Question about NetGear MR814 Wireless Router
I have a netgear router purchased about 7 months ago at best buy. I have a HN9000 modem and for one thing, I can't clear the router and it keeps locking up. I keep trying to clear it by hitting the reset button but it doesn't work. I can't log into the router because I cannot remember the username and password I assigned it. I am ready to throw away and go purchase another one any suggestions?
    Problem Solver:
  • 26 Answers
Press and hold the reset button for 30 seconds if you must to see if that resets the router to factory defaults.
Posted on Nov 09, 2017
  • 52 Answers
SOURCE: Router Password
try admin and admin again for password. If that is not it try leaving the password box blank. Good luck Are you sure you did not change the password when you set it up the first time. If you did you have no other option than reset.
Posted on Jan 30, 2008
PABLOCSA
  • 1124 Answers
SOURCE: Netgear wpn824v2 can't login to router, can't reset defaults
The router username is always admin
The default password is password or (for older routers) 1234
Try the default username and password before resetting the router to the factory defaults.
When a router resets, it goes back to the state when it was new — all information that was entered by hand is lost! Examples are critical things you need to get online, such as ISP username, ISP password, IP addresses, security keys, and ports and services that were opened. It all needs to be re-entered.
So, have your ISP information before resetting the router.
Naturally, if you moved to a new city, or if you bought a used router, the old information in the router may not be of use to you. Contact your ISP if you can't connect any computer directly to the Internet. Then, if there is a connection problem when the router is added, see No Internet Access Through the Router
Reset for most routers with a reset button on the rear panel
Write down configuration information such as IP addresses, security keys, opened ports and services, etc., that you modified. (The default username is admin and the password is either password or 1234. Try these before resetting the router.)
Press the reset button on the back until the test light blinks.
This takes about 10 seconds.
(To avoid accidental resets, the small button is recessed. Use a pen or paperclip to access it.)
Release the button.
Wait for the router to reboot.
Log in with the default password.
If the router was not cleared, try these additional steps AFTER the router has finished rebooting.
Unplug the router's power.
Press and hold the reset button.
While the button is held down, reconnect router's power.
Continue to hold the reset button for 20 seconds after reconnecting the power.
Posted on Oct 21, 2008
  • 51 Answers
SOURCE: forgotten pw
There is no way to access the router without resetting it. You must reset the router, and make a new username or password. Sorry!
If you want, the only setting you need to set is to change your local IP address to 192.168.2.1 (IF you have DSL.)
Posted on Dec 28, 2008
  • 30 Answers
SOURCE: keep getting a 401 unauthorized code when trying to log in to sur
Your Web server thinks that the HTTP data stream sent by the client (e.g. your Web browser or our CheckUpDown robot) was correct, but access to the URL resource requires user authentication which 1) has not yet been provided or 2) which has been provided but failed authorization tests. This is commonly known as "HTTP Basic Authentication". The actual authentication request expected from the client is defined in the HTTP protocol as the WWW-Authenticate header field.
Generally this error message means you need to log on (enter a valid user ID and password) somewhere first. If you have just entered these and then immediately see a 401 error, it means that one or both of your user ID and password were invalid for whatever reason (entered incorrectly, user ID suspended etc.).
401 errors in the HTTP cycle
Any client (e.g. your Web browser or our CheckUpDown robot) goes through the following cycle:
Obtain an IP address from the IP name of your site (your site URL without the leading 'http://'). This lookup (conversion of IP name to IP address) is provided by domain name servers (DNSs).
Open an IP socket connection to that IP address.
Write an HTTP data stream through that socket.
Receive an HTTP data stream back from your Web server in response. This data stream contains status codes whose values are determined by the HTTP protocol. Parse this data stream for status codes and other useful information.
This error occurs in the final step above when the client receives an HTTP status code it recognises as '401'.
Fixing 401 errors - general
Each Web Server manages user authentication in its own way. A security officer (e.g. a Web Master) at the site typically decides which users are allowed to access the URL. This person then uses Web server software to set up those users and their passwords. So if you need to access the URL (or you forgot your user ID or password), only the security officer at that site can help you. Refer any security issues direct to them.
If you think that the URL Web page *should* be accessible to all and sundry on the Internet, then a 401 message indicates a deeper problem. The first thing you can do is check your URL via a Web browser. This browser should be running on a computer to which you have never previously identified yourself in any way, and you should avoid authentication (passwords etc.) that you have used previously. Ideally all this should be done over a completely different Internet connection to any you have used before (e.g. a different ISP dial-up connection). In short, you are trying to get the same behaviour a total stranger would get if they surfed the Internet to your Web page.
If this type of browser check indicates no authority problems, then it is possible that your Web server (or surrounding systems) have been configured to disallow certain patterns of HTTP traffic. In other words, HTTP communication from a well-known Web browser is allowed, but automated communication from other systems is rejected with an 401 error code. This is unusual, but may indicate a very defensive security policy around your Web server.
Fixing 401 errors - CheckUpDown
When you set up your CheckUpDown account, you may optionally provide two items 2. Web Site User ID and 3. Web Site Password. You should provide these only if your site uses HTTP Basic Authentication. If you provide them, the CheckUpDown robot always uses them. This will result in a 401 error if in fact your site does not use this authentication. Conversely, if you do not provide them and your site does use this authentication, you also get a 401 error.
If however your URL is open to all comers, then an 401 message should not appear. Because it indicates a fundamental authority problem, we can only resolve this by negotiation with the personnel responsible for security on and around your Web site. These discussions unfortunately may take some time, but can often be amicably resolved.
Alternatively or the other way around is :
open the XP hosts file, and do a manual insert there.
The hosts file is located at: C:\WINDOWS\system32\drivers\etc
The entry is: 192.168.0.1 www.routerlogin.net
You might need to flush your DNS records at this point, or simply restart your computer.
And then use the following URL to access the admin page:
http://www.routerlogin.net/setup.cgi?next_file=start.htm
***Here is another solution to the problem, which is a fairly straight-forward way to disable the annoying wizard.
Type in your browser:
http://www.routerlogin.com/CA_HiddenPage.htm
Select: Disable Configuration Assistant, and click on Apply.
You can re-enable it by navigating to http://192.168.0.1/CA_HiddenPage.htm (where 192.168.0.1 is your router’s IP address)
Posted on Apr 11, 2009
SOURCE: cannot get dlink 524 wireless router to work with HN9000
Hi! I will be more than glad to assist u in this concern..if u bypass the router it will work, the reason why the modem wont talk to the router bcoz the router is not properly setup.. if you are using a cable modem from ur cable company provider- u need to do a mac clone on the router u have to clone the mac address of ur computer. normaly the mac of ur computer is the one register to your cable company and on the setup page of the router just selct on the internet setup, dhcp after clonning the mac address of your computer. u need to connect ur computer directly to the router and then after doing the process connect the router to the modem. if u are using a username and password, u have to use the pppoe settings on the router, if ur isp set a static ip , set it up to the router, to check the ip setting of your isp.. connect the computer directly to the modem and check if u have internet.. then click on start, run and type cmd,it will give u a dos prompt and from there type ipconfig/all and it will show u the ip address, subnetmask, default gateway, dns server.. I hope this will solve ur concern..
Posted on Aug 09, 2009
2 months ago we purchased the NERGEAR88 modem/router, it was workin great untill today. I have my laptop hardwired to the modem/router and the internet works fine but the wifi does not work anymore, none...
Not having defined the problem very well it is hard to answer.
  1. Press the reset button on the back of the router for 10 seconds. This will reset to factory defaults.
  2. Check on the manufacturers website for a firmware update.
  3. Buy a new router.
NETGEAR Support Answer Troubleshooting Connection Issues
Mar 03, 2015 | Computers & Internet
After years of dial up, I've acquired a HughesNet
According to the manual, you can purchase any wireless router (manual calls the router "air base")
I would advise a D-link or a Linksys router.
Manual:
http://www.viasatelital.com/manuales/Instalacion-HN9000.pdf
Jul 12, 2011 | Computers & Internet
I just bought a laptop computer and I already had a desktop. My internet provider is Hugesnet Satelite. I bought a Netgear N600 wireless dual band router thinking I could just hook it up to my desktop...
The HN9000 should have an ethernet port. You will require two ethernet cables to connect the desktop to the router.
1. Connect the ethernet cable from the Modem to the Ethernet Input port on the Router (It is generally placed away from the other ports on the back of the router.) 2. Connect another ethernet cord from one of the output ports on the router to the desktop computer. 3. On the laptop, turn on your wireless card. The process for this differs from computer to computer. If you were to provide the model of laptop, I could provide you specific instructions. 4. The network setup should be complete.
If you need more help, let me know by replying to this solution. Thank you for using FixYa!
Apr 01, 2011 | NetGear Computers & Internet
I have a cable modem and want to get wireless...do i need to purchase a wireless cable modem or can i just purchase a wireless router and somehow hook them together?
You can just purchase a wireless router :) I personally like netgear routers haven't had the best luck with linksys. Then connect the two with a ethernet cable. The router will give you instructions and a cd to set up :) how this helps
Jan 14, 2011 | Motorola Computers & Internet
WPN824 Transmitting Signal, no internet.
As a last resort, you can reset your router by holding down the reset button in the back. It doesn't sound like this will fix the problem however. Purchasing a new router shouldn't be necessary, as most if not all Netgear routers come with a 1 year warranty standard.
Aug 02, 2010 | NetGear RangeMax WPN824 Router
HN9000 DSL and RangeMax Wireless not connecting wireless laptop
uninstall then reinstall wireless card drivers then reconnect.
Jul 26, 2009 | NetGear MR814 Wireless Router
Have a new Hughes net HN9000 satellite service and trying to get the Netgear wireless router to allow me to connect to the internet. Have two other computer set up for the home network and they can see the...
Hey, Can you perform the task below and paste me the results from the modem:
Connect the modem to the computer. Open command prompt and type ipconfig. Paste me the results for IP address, subnet mask and default gateway.
Also, confirm, how you have connected the modem to the computer. IS it using a ethernet cable or USB?
Once I have this information, I will be able to provide you with an accurate resoultion.
Jun 30, 2009 | NetGear MR814 Wireless Router
Wndr 3300 net gear router wont work with hn 9000 hughes net modem
I went to the Hughes web site to check out the modem. They say it is also a router. I think you will have to disable the router abilities of your WNDR 3300 Net Gear Router.
Get into the Netgear setup by loging on to it.In its WAN setup select Static IP Address and set the Static IP Address to the same as the hughes modem, except for the last number which should be about 50 greater. IE: Hughes 192.168.12.1 and Netgear 192.168.12.55.
In the DHCP setup, disable the DHCP Server
In the Wireless setup, Give your network a name is SSID. You should also set up security to keep others off you internet connection with a WEP key.
I hope this helps.
May 30, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
Loss of connection
This problem is mainly cause by the router firmware, so I advuice you to contact Netgear and ask them to update the firmware of your router to resolve this problem that you have....
Apr 21, 2008 | NetGear RangeMax NEXT WNR834B Wireless...
NetGear MR814 Wireless Router Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
