Question about Panasonic TCP50U2 50 in. TV
I am having trouble with the digital audio out that is connected to my receiver. When I try to have the tv play through the speakers they cut out after a few seconds. When I use the receiver as a tuner for radio stations I do not have a problem
  • 39 Answers
Check that the TV has the Digital Audio turned ON in the audio menu. In those few seconds before the rdio cuts out, do you get sound at all?
Hope this helps
TV_Doctor
Posted on Jan 03, 2011
How do I connect Samsung smart TV to a Yamaha receiver and get sound to come out of surround sound speakers?
Generally you will connect the Digital audio or optical audio cable from TV to the input of Receiver. Then using the remote control of Receiver you will program the source for digital audio or optical audio as TV. I am assuming the speakers on the receiver are already connected and working. All you do is then turn on TV and turn on Receiver and select TV on Receiver. The TV audio will play through the receiver. Make sure the TV sound is in Mute.
Aug 07, 2014 | Yamaha Audio Players & Recorders
Can't get balance, bass and treble to work when connecting Bose Acoustimass 5II to HK AVR 525
On my yamaha 375 receiver if I connect digital or hdmi it disables the balance/bass treble etc but they work with anolog don't know if yours might be the same just abit strang if anolog doing it aswell
Jan 15, 2014 | Harmon Kardon Harman Kardon Avr 525 7.1...
I cannot get sound from my sony tv (ldl 40bx420) to play through my strdh520 .....my blue ray sony bdp s580 sends a nice signal through it to the speakers.....I have tried every tip in the manual to try to...
Depends on your sources and connections. If you have Cable Box, DSS, FIOS, etc. Audio would be from Coaxial or Digital Optical from the respective source. You would need to check the Audio settings on the Cable Box, DSS, etc. If you are using Cable or off-air, direct from the TV, it would be connected from the analog audio (rca) or Digital Optical output from the TV and The Audio out setting on the TV should be set to Fixed. On the Sony Receiver, make sure all inputs in settings menu for audio are set to auto. Hope this helps, if you still have a problem, post a reply/comment with any other equipment you have connected between TV & Receiver
Jun 27, 2011 | Sony STRDH520
I just sold my surround sound system and now I can't get the on board speakers to work.
Just check the rear of the television if by chance you have left any cable still connected to the audio output jack. If there the TV might be trying to redirect the audio to an external device not present. Sometimes it could also be a simple setting to be changed , . Check if you have a switch at the back of the TV stating External or Internal speakers. From the manual i got
A/V Receiver: The TV can detect audio connections on the DIGITAL AUDIO OUT jack and the right (red) analog AVR AUDIO OUTPUT jack.
Note for Analog A/V Receivers: When you disconnect an analog A/V receiver, manually change the Speakers setting to TV to hear sound from the TV speakers.
Press Menu on the remote-> Goto AV
Select Audio by pressing the right key
Under that the first option of Speakers -> select and set to TV.
Only then will the TV speakers play the audio.
Hope this Helps.
Mar 04, 2011 | Mitsubishi Televison & Video
I have just bought the samsung ht c555 home cinema kit connected it to the the tv all is working well when playing a5.1 dvd but ihave no sound out of the system when on ordinary tv how do you get all 5...
you will have to connect an audio output from the tv to the sourround reciver. you should have some audio output on the back of the tv and a corresponding input on the samsung ht c555
Dec 24, 2010 | Samsung Audio Players & Recorders
Onkyo TX-SR606 getting no sound from HDMI sources on speakers. I have a motorola cable box and a panasonic DMP BD-35K blueray player both attached to the SR606 via HDMI cables (HDMI3 and 1 respectively)...
Not sure if this is your fix, but I had what I thought was the same problem. I played with my Onkyo quite a bit ensuring the correct assignments for HDMI, audio and all that stuff. Turns out I neglected to make sure the output devices were properly assigned. Many devices aren't default to output sound over HDMI. I changed the audio out settings on the cable box to HDMI and suddenly the Onkyo worked great. I know, I'm an idiot for not checking that in the first place, but maybe someone out there is having the same trouble as well.
Feb 20, 2009 | Onkyo TX-SR606 Receiver
Lg home theater to lg plasma tv
This is a typical problem with TV broadcast UNLESS you use a matrix DSP surround sound mode, most DVD audio is either Dolby digital 5.1 surround or DTS multi-channel surround sound, unless you are viewing a HDTV broadcast with 5.1 Digital sound connected from the TV to the receiver then you are probably receiving a 2 channel Stereo sound format, I would suggest that you try to set your TV input mode to a audio Dolby Pro- Logic which will yield 5.1 and should engage all speakers.
Feb 17, 2009 | LG LHT854 Theater System
Denon AVR-2105
If the Cd is wired digitally, it will only play through the main zone, because the Denon cannot convert down to RCA to cater for the zone 2. If you plug RCAs from Cd to Denon, Main zone will STILL play from digital, and RCA connection will allow zone 2 to play Cd from RCA input....same with dvd, Satellite Blah blah... no stress, any nasty RCA will do if you want to try before you splash out on really costly cables...perhaps you can help me...want to run AVR 2105 with 2 speakers in zone 2, manual says cant do it - only ably to surround back or biamp...dont want either, dont have stereo yet to try it out...did you have any trouble with that?
May 26, 2008 | Denon AVR-2105 Receiver
I am trying to connect my Samsung 56" DLP HDTV to my JVC THD50 home theatre system, all the speakers are hooked up correctly but I can't source from the tv to the speakers correctly, I connected a...
On the rear of the receiver you will notice several AUDIO IN connections. Make sure that the AUDIO IN and the receiver's input selector match (for example, if you are connected to AUDIO IN for the VCR section, the input selector on the FRONT of the receiver should also be VCR). Also, make sure that the input selector you are using is set to "Digital Audio" or a digital audio enabled equivalent and NOT analog. Check all connections again to make sure you have not grounded any speaker wire. Check to see if "MUTE" is on TV or Receiver. Try another audio in source just to make sure the speakers are connected properly. If that works, you can pretty much decide that it's either the input selection is wrong or the audio source is not set to digital 9also check to see if PCM is enabled and try setting to "AUTO" if you have that function. If you have option on receiver for speakers A and B, make sure selection matches your wiring.
Apr 03, 2008 | Audio Players & Recorders
Connecting bose 321 system to lg hd flat screen,bose receiver plays fm am ok threw speakers.tv will not play threw bose speakers.bose dvd plays sound ,but no picture
You will need a Component Video Cable
Connect the Red Green and Blue Connections from the TV to the Bose.
if your audio is coming from the TV, also connect stereo audio from the TV's audio out to the "TV" input on the bose.
if you want to hook up other devices (VCR, BluRay, etc) the video will go directly to the TV and audio will go directly to the Bose
Jan 18, 2008 | Bose Cinemate Digital Home Theater System...
Panasonic TCP50U2 50 in. TV Logo
70 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
