Question about Maytag Performa PAV2200
Maytag/Performa Dishwasher The dishwasher will not start. All modes can be switched, so I am getting power, but it will not start when the start switch is pressed.
  • 639 Answers
Electronic problem. just call service.
If its 10 years old or more don't put money into it!
The new ones are much more energy efficient!
Try these guys,they are good!
A&E Factory Service is nation wide!
1800-905-9505
They are open 7 days 24 hours to make appointments
Neil
Posted on Aug 24, 2008
My Maytag Performa Dishwasher is leaking when doing the dishes...
Sounds like your fill valve is stuck in the filling position...see if you you have water standing in it a couple hrs after a drain cycle. if it does then the valve needs to be replaced or you can take it apart carefully,(there is a sping that might fly out and get lost) and clean it. Mine had some small trash in it from the city water line.. The left side has an over flow hole is where your water is coming from..
Nov 12, 2009 | Maytag Performa PAV2200
Tip
Maytag recalls dishwasher/fires feared from heating element
Maytag is recalling dishwashers for fire hazards including Maytag, Amana, Jenn-Air, Admiral, Magic Chef, Performa by Maytag and Crosley brand dishwashers with plastic tubs and certain serial numbers.
Check these serial numbers to see if you have the dishwasher in question.
Call 1-800-544-5513 if you think you have one.
on Jun 04, 2010 | Dishwashers
Maytag performa dishwasher PDBL390AWB - dirty dishes
The problem is hard water. Go to www.dishwasherfilter.com and get their new product. It filters the water and takes out the hard minerals that cause spots and clog dishwashers. It is very affordable and has a money back guarantee.
Sep 13, 2009 | Bosch SHU9915UC Dishwasher
Soap dispenser doesn't open
My recommendation is to switch over to a tablet and merely put the tablet on the floor of the dishwasher bypassing the soap holder all together. It should work just fine that way. good luck.
Dec 29, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Maytag Performa Dishwasher draws water then stops
More than likely you need to replace the washer control panel.
Jul 19, 2017 | Maytag 24 in. MDB5600A Jetclean II...
Dishwasher won't start
1. No power to the dishwasherMake sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer
Replace if defective (note: uncommon problem).
4. Selector switch
Nov 01, 2008 | Maytag MDB7100AWB Dishwasher
Dishwasher not cleaning well
How hot is the water ;120 is the minimum it should read at.If its below 120 than look for either a bad heater element or turn up the water heater.Rinse Aid needs to be added if its out.
Apr 11, 2008 | Maytag Performa PAV2200
Maytag performa dishwasher pdc3600awx
Home depot sells the faucet adaptor you need. It is called "Long Dishwasher Aerator" and states 55/64 " - 27 thread. The number on the top left which I suppose is the part number is 36094B. It also has a yellow stick with "2A" on it, which should help find it quickly. It is located in the section where they have all the kitchen faucet aerators etc. Found it easily. Cost was $3.77
Mar 30, 2008 | Maytag Performa PAV2200
Maytag Performa dishwasher
Check the float switch.
Mar 10, 2008 | Dishwashers
Dishwasher only runs in rinse only mode!
my dishwasher just keeps bleaking clear AND NO WATER IS GOING INTO THE MACHINE IT JUSTS KEEPS RUNNING BUT THEIR IS NO WATER COMING IN.
THANKS
Jun 30, 2007 | Maytag 24 in. MDB5601A Free-Standing...
Washing Machines Logo
551 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
