Question about Audiotek Car Audio & Video
Does any body know wat the perameters are for the Audiotek K7 12 in. subwooofer are?
2 Suggested Answers
marked
  • 6487 Answers
SOURCE: acer travelmate 2410
The best thing tha you can do here is to do a System restore on the computer on the date that everything was working fine and with the sound software still installed on that computer , that will definitely fix the problem..
Hope that helps............
Posted on Oct 07, 2008
I got a rci-2960f cb radio does any body know anything about this radio it has a big heat ink on the botton does any body know wat watts it was putting out
The radio has a heat sink as it has a amp built into it--about 100 watts maximum output---get someone with a DUMMY load and watt meter and see what it is putting out power wise--Most of the RCI have a variable control on the front for power output.
Apr 18, 2012 | Radio Communications
I have and know my code, but when the computer starts, it puts a different code into the network box. How do I set with the code for automatic start each time?
1) What operating system are you running on the computer?
2) Is your problem with the router, or your computer? If your setting up the router, then you have to press the "Save" button when you enter various different setup perameters. You will then have to set the profile up on your computer to match those perameters.
Dec 16, 2009 | Linksys Wireless-G Broadband Router
Audiotek amplifier RMS
the usual RMS of and amp UNBRIDGED is 1/4 or the max so 1200watt max would be 300 watt RMS and a 1000 would be 250 WRMS
Jul 18, 2009 | Car Audio & Video
I dont know wat model civic i have =/
In the door sill on the drivers side, there should be the model description, as well as body, trim, and paint color codes. If not, the dealer can tell you based on the last 8 of your VIN.
Jan 06, 2009 | 1998 Honda Civic
Acer travelmate 2410
ya realtech sound driver go web sit dl latest sound driver for your model under help suppprt area onn acer website ok
Oct 07, 2008 | Acer TravelMate 2300 Notebook
Audiotek amp
RMS(power) = peak(power) * .707
find the peak power of your amp and use the above formula
It will have enough power to do so.
Aug 06, 2008 | Car Audio & Video
Audiotek amp
1500 Watts.
good luck
Aug 05, 2008 | Audiotek Car Audio & Video
Help with jensen vm9021ts
To ground a wire is just to pretty much hook it to the negative battery terminal. And since, the body of your car is directly tied to the negative battery terminal, just attach the wire to the body of your car. Some times there is already a ground run and I would typically use one of those. In your case I would just run it to the ground behind the radio. The black wire you hooked up for the power of the head unit is what you need to wire it to. Let me know if you need more help. Good luck
-Andrew Hawkins
May 31, 2008 | Audio Players & Recorders
Car Audio & Video Logo
85 people viewed this question
Top Audiotek Car Audio & Video Experts
xxxxxx xxx
Are you an Audiotek Car Audio and Video Expert? Answer questions, earn points and help others
