Question about Frigidaire ATF6000ES Front Load Washer
Heard that the wash tub needs to have "moving
  • Frigidaire Master
  • 8,220 Answers
Your shipping support hard ware should be in a bag behind the appliance. use this service manual as a guide to moving your appliance I think page 9 or 19 shows the hardware
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jan 03, 2011
Fisher paykelwasher basket removal
you need fill with hot water to soak it over night to loosen the basket so it can lift out.
Feb 08, 2013 | Fisher and Paykel GWL11 Top Load Washer
Tip
How to repair washing machine easily
Figure A: Common leak locations
These are the six most-commons places for washing machine leaks.
Figure A shows where the most common washer leaks occur. We cover hose, pump and tub leaks, but there may be additional problem areas specific to your brand of machine. There are two types of washing machines: belt drive and direct drive. If you open up the cabinet and don't find any belts, then you've got a direct-drive machine. Repairs are similar for both machines, but generally easier on the direct-drive unit. The following photos are from a belt-drive washing machine. If you have a direct drive, refer to your owner's manual or diagrams (see "Buying Parts") for brand-specific details.
Tip: Make sure the water on the floor isn't the result of a plugged floor drain. It happens!
Back to Top
Replace leaky supply hoses
Unscrew the water supply hoses
Turn off the water main or shutoff valve and unscrew the supply hoses from the back of the machine with an adjustable pliers. Pry out the old hose washers with a flat-blade screwdriver. Install new gaskets in both hoses and reconnect the supply lines. " title="Unscrew the water supply hoses " style="box-sizing: border-box; color: rgb(66, 139, 202); text-decoration: none; bottom: 6px; height: 16px; position: absolute; right: 22px; width: 65px; background: url(http://www.familyhandyman.com/images/ProjectDetails/step_by_step/enlarge_button.gif) 0px -16px no-repeat scroll rgba(0, 0, 0, 0);">
The first step is to locate the source of the leak. Empty the washing machine, move it away from the wall and start the fill cycle. Look for drips around the water supply hose connection at the back of the machine while it fills with water. Shut off the water and replace any old, heavily corroded or rusted hoses with new ones (photo). If the hoses are in good shape, replace the internal washers only. Special no-burst hoses, regular hoses and new hose washers are available at home centers and hardware stores.
CAUTION!
Unplug the machine before performing any repairs.
Back to Top
Replace leaky internal hoses
Photo 1: Look inside the machine
Unscrew the access panel from the back of the machine or open the cabinet. Look for leaks while the machine fills with water. If you don't see any, advance the machine to the agitate cycle and check again. " title="Photo 1: Look inside the machine" style="box-sizing: border-box; color: rgb(66, 139, 202); text-decoration: none; bottom: 6px; height: 16px; position: absolute; right: 22px; width: 65px; background: url(http://www.familyhandyman.com/images/ProjectDetails/step_by_step/enlarge_button.gif) 0px -16px no-repeat scroll rgba(0, 0, 0, 0);">
If the supply hoses aren't leaking, open the cabinet and inspect the internal components. Belt-drive machines typically have a rear access panel that unscrews. Access direct drive machines by removing the two screws on the outside of the control panel and flipping up the lid. Then pry up the cabinet clips and pull off the entire cabinet. With the cabinet open, restart the fill cycle to check for internal leaks (Photo 1). Look for additional clues like rust and calcium deposits. Most often you'll find the leaks in the spots we show in Figure A.
Hoses tend to leak around a worn-out spring clamp. First try to remove the spring clamp with an adjustable pliers. If you can't get it, you'll need a special hose clamp pliers (Photo 2) available from your local parts supplier. Replace the old spring clamp with a new worm-drive clamp (photo below). If the hose itself is cracked and leaking, remove it and take it to the appliance parts supplier for a replacement.
Back to Top
Replace a leaky pump
Photo 1: Loose the bolts
Loosen the two motor mounting bolts to relieve tension on the belt. One will be at the rear of the cabinet and the other is nearby. " title="Photo 1: Loose the bolts" style="box-sizing: border-box; color: rgb(66, 139, 202); text-decoration: none; bottom: 6px; height: 16px; position: absolute; right: 22px; width: 65px; background: url(http://www.familyhandyman.com/images/ProjectDetails/step_by_step/enlarge_button.gif) 0px -16px no-repeat scroll rgba(0, 0, 0, 0);">
The pump usually leaks around the pulley seal (see Photo 3). If you spot water leaking from this spot, the pump is shot and will have to be replaced.
To replace the pump, work from underneath the machine. Unplug the machine and tip it up against the wall. Block up the front with a car jack or 2x4s so it can't tip over while you reach underneath. Replace the pump as shown in Photos 1 - 4. If the belt is darkened from burning or is worn down to the threads, replace it, too.
Back to Top
Replace worn-out tub fittings
Photo 1: Lift the lid
Slide a small putty knife between the washer lid and the cabinet. Push the putty knife against the spring catch while lifting up on the lid. Release both catches and fold the lid back. " title="Photo 1: Lift the lid" style="box-sizing: border-box; color: rgb(66, 139, 202); text-decoration: none; bottom: 6px; height: 16px; position: absolute; right: 22px; width: 65px; background: url(http://www.familyhandyman.com/images/ProjectDetails/step_by_step/enlarge_button.gif) 0px -16px no-repeat scroll rgba(0, 0, 0, 0);">
The most challenging repair is fixing a leaking tub fitting, whether it's the air dome seal, the center post gasket or the tub seals. (See Figure A and photos for locations.) Before proceeding, make sure that telltale drips are coming from around the tub. The details of this repair vary by brand and model. The details we show are for most Whirlpool and Kenmore belt drives. Study a schematic drawing or consult a parts specialist if your machine is different from what we show.
You'll need a special spanner wrench (Photo 4) to remove the tub and replace the tub fittings on this type of machine. It's available at your local appliance parts supplier. Follow Photos 1 - 5 to access the tub fittings. You can open the top of many machines by releasing the spring catches (Photo 1). However, on others you have to unscrew several screws and lift off the entire cabinet. Look in your owner's manual or at a parts diagram. (See the manufacturer's Web site or one of the sites listed in "Buying Parts.") You'll have to unscrew the water inlet and the tub snubber (Photo 1) before unclipping the ring (Photo 2). Fastening systems for these vary by brand, as do attachment methods for the agitator (Photo 3) and inner tub (Photo 4).
There are four tub seals that secure the outer tub to the cabinet, each consisting of a bolt with a rubber and metal washer. Rust often develops around one of the tub seals, causing a tub leak. A new tub seal kit will come with four new bolts and oversized rubber and metal washers that will seal small leaks (Photo 6). But if the tub is completely rusted through around the bolt, it's time to buy a new washing machine. Replace all four tub seals as shown in Photo 6.
If the leaking occurs only when the machine is agitating, a bad center post gasket ("doughnut") is the culprit. Remove the outer tub to replace the center post gasket (Photos 8 and 9). While you're at it, replace the air dome seal as well (Photo 8). Reassemble the washing machine and run a test cycle.
Buying Appliance Parts
Washing machine parts are available at appliance parts distributors. (Look in the Yellow Pages under "Appliance Parts.") Try to find a parts supplier with well-informed staff, ideally ex-repair technicians, who can provide diagrams and help diagnose any problems specific to your brand of machine. A great Internet source iswww.searspartsdirect.com. Enter your model number to access exploded-view diagrams and a thorough parts list for easy on-line ordering.
You'll need the brand and model number for proper part identification. Model numbers are usually stamped on a small metal plate located under the tub lid or on the side or back of the machine. Copy down all the plate information and take it along to the parts distributor.
Metal ID plate
Back to Top
Tools & Materials
Required Tools for this Project
Have the necessary tools for this DIY project lined up before you start-you'll save time and frustration.
Hammer
Socket/ratchet set
4-in-1 screwdriver
Adjustable wrench
Putty knife
Slip joint pliers
on Jul 14, 2015 | Washing Machines
Do I need to secure the tubs inside Kenmore Elite Washer & Dryer?
Not the dryer but you do for the washer ... there is bolts that go in the back to hold the tub ... the bolts came with the washer went it was new... you may be able to get a set from sears...
Oct 03, 2009 | Kenmore Elite 45986 Front Load Washer
Need to secure for moving
You should have some bolts that came with the machine. They are fitted into the rear casing and screw into the drum to hold it steady. If you dont have the bolts then you can try packing some towels around the outside of the drum ( from underneath ) to hold it steady.
May 21, 2009 | Frigidaire ATF6000ES Front Load Washer
Loud banging noises
Hi!
The reason of this noise is from loose lower front weight mounting bolts or a loose bolt securing the driven pulley. Check the motor adjustment bolt for tightness. The noise could be from a loose wire harness, plastic purse-lock wire harness retainer on upper hose hitting the top cover or a plastic injection mold standoff on the outer tub bearing housing may possibly be interfering with the driven pulley. Also, check the drive belt for a weak spot on the belt. Ussually felt on the backside of the belt as a "flat" spot. Check the belt for a weak seam and replace it.
It may also occur due to the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 06, 2009 | Washing Machines
Whirlpool Stylemaster 4217141 tub not moving wash/spin cycles
Sounds like the drive belt is broken or very loose. Take off the back and check the belt. If loose or missing, tighten or replace. This is usually done by loosening the motor support bolts and moving the motor until the belt is tight, then re-tighten the bolts. Replace belt in the same way.
Apr 22, 2009 | Whirlpool Washing Machines
URGENT~no clue how to reinstall transport bolts for moving washer
The long one go on the bottom and the short one go on top the hole for the shipping bolts are on the back might have a clear plastic cover over the holes on the back panel there is only one way to put them in start by hand tighten the bolts with nothing in the drum the holes should line up one you fill the catch and get hard to turn start using a wrench when it is done try shaking the inner tub it should not move all the shipping bolts do is keep the tub from slapping around inside the cabinet and breaking things Good luck
Apr 03, 2009 | Washing Machines
How to secure front loading drum for moving????
transit bolts vary with machine. pack polystyrene blocks tighty between tub and cabinet and that will do the trick
Sep 25, 2008 | GE WCVH6260F Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer--Tub won't move
what a bogus website you are. you offer no free support and you should say so
Jul 12, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
126 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
