Question about Microwave Ovens
Just show error E3 and does not work - Microwave Ovens
    Brigadier General:
  • 8,909 Answers
Error code F3 on many models of microwave oven means a problem with the touch panel, (tact switches).
Replace the switch panel to fix the fault.
Hope this helps.
Posted on Jan 03, 2011
What does e3 mean on a Samsung microwave
Temperature of exhaust air too
High
Let it cool down?
Cause:
The oven cavity gets too hot due to excessive
operation with no load or small load, or due to
some blocking materials around the Air Filter or
Air Exhaust at the back of the oven.
Remedy: • Open the oven door and check if 1) the oven
has been operating with no load or too small
load, 2) the air filter is placed in a wrong
position, or 3) any blocking materials exist
around the Air Exhaust. Cool down the oven (for
approx. 30 min) under the normal temperature.
The oven is back to normal when the error
code "E3" disappears and "ON" appears again
in the display window.
• Unplug the power cord, remove the blocking
materials around the ventilation openings, cool
down the oven (for approx. 30 min) sufficiently,
plug the power cord in again and check if the
error code appears again.
• If the symptom persists even when the oven is
cooled down sufficiently, contact the nearest
service centre
Jun 26, 2014 | Samsung MW1080STA Microwave Oven
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Our oven keeps saying E3 F1 when attempting to preheat. We bought the oven used and didn't get a manual w/it... Any ideas?
Hello & Welcome to FixYa
F1-E3 error means open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you want to do it yourself and wan to be sure before replacing the sensor then you can test it with a voltmeter between 1080-1120ohms....if it reads more then or less then this then it needs replacement however, if the reading is around between 1080-1120ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Apr 11, 2011 | Microwave Ovens
Got an E3 Error Code and a popping sound. now it dose not work.
Error E3 control board is probably faulty.
That's what the notice board says.
Mar 06, 2011 | Microwave Ovens
E3 error message on prestinge induction Cook. Not able to do any operation, as soon as we power on the cook, it goes to E 3, It is only 3 hours old. Please help me.
E3 generally means a control board error.
If it didn't get damp with steam from cooking, take it back and exchange it.
Hope that helps.
Jan 24, 2011 | Microwave Ovens
Hi I have bought a new Prestige Induction cook top. I have been using it for quite some time, but without any problem. All of a sudden today when I try to heat water , the temperature panel goes to E3...
I have bought a new Prestige Induction cook top. I have been using it for quite some time, but without any problem. All of a sudden today when I try to heat water , the temperature panel goes to E3 and nothing else works.
In order to start it again I have to switch off the power and start all over again.
Please help me in fixing this problem
Oct 28, 2010 | Microwave Ovens
66993 pizza oven microwave oven combo pizza oven not heating error code f1 microwave part works
Hello, please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
Jul 20, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
Kitchenaid microwave oven KBMC140HSO
I started having the same problem with my KBMC140HSSO. You cannot see the error codes without disassembling the control panel (the codes are on another display that covered by the front panel). After doing so I found the error code to be F2, E3 which is "Key held down too long, or key shorted". I am ordering a replacement keypad and will report back if this fixes the problem.
Mar 29, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
Microwave Ovens Logo
50 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
