How to put staples in apsco stapler 2002 - Office Equipment & Supplies
  • 2072 Answers
SOURCE: AS 300 electric stapler--pulled out
What has most likely happened is part of a staple is stuck in the front portion of the stapler where it forms the staple and presses it into the stapler.
You would most likely have to remove the stapler, and remove the binding staple from the stapler head.
Posted on Sep 28, 2008
goalie39
  • 469 Answers
SOURCE: stapler is not dispensing staples after new cartridge is inserted. Can you help?
Remove the staple cartridge, look into the cartrige area, are there any stray staples in this area, if so remove them, cycle the unit a couple of times without the cartrige in place, check the output end, any stray staples here? re assemble making sure you pull the first row ow staples even with the nozzle of the cartrige.
Hope this helps
Ed
Posted on Apr 30, 2009
SOURCE: stapler constantly shoots out staples even when there is nothing to staple.
There is a contact switch / lever on the staplers that engages the stapler when it is pressed. It must be stuck. locate the lever and see if that's the case, and release it if you can. just my 2 cents, because I'm a copier/fax tech -not a stapler expert :)
Posted on May 04, 2009
SOURCE: Panosonic Electric Stapler does not staple paper!
It could be either jammed up with staples or the spring mechanism is shoddy.
Posted on Dec 04, 2009
  • 114 Answers
SOURCE: I have a Canon 1180 printer with sorter and
if you have cleared any jamed staples in the cartridge and it is still doing the same thing it may be a weak staple motor or a gear on the staple assembly may be slipping.
Posted on Apr 18, 2010
Apsco a9 stapler user manual
Try Googling (Apsco)(a9)(manual) without parens.
Aug 03, 2017 | Tools & Hardware - Others
How to put back together
Stanley Model TR45 Light Duty Staple Gun Review - YouTube
? 3:35
https://www.youtube.com/watch?v=hWmvXhkqnYI
Jul 25, 2012 - Uploaded by Vansvideoreviews
Stanley Model TR45 Light Duty Staple Gun Review ... How toPut Staples in a Craftsman Stapler (Model 968447) ... Stanley SharpShooter Manual Staple and Brad Gun review - Duration: 9:35. by Unpack Guy 35,948 views.
How to load staples into a Stanley Stapler - YouTube
? 2:11
https://www.youtube.com/watch?v=j4Q5W0uKS-s
Mar 26, 2013 - Uploaded by David DeStefano
This video shows you how to load staples into a Stanley StaplerModel # TR110. ... Stanley SharpShooter Manual Staple and Brad Gun review ...
put stanley sharpshooter staple gun back together ... - Fixya
www.fixya.com > Forum > Tags
Find solutions to your put stanley sharpshooter staple gun back together question. ... staples for the TRE500 Stanley Sharpshooter Electric Heavy Duty Stapler.
Dec 10, 2015 | Stanley SHARPSHOOTER HEAVY-DUTY STAPLE GUN
How do I reload staplers?
There are two basic designs of staplers. The most common type is the Swingline or Stanley Bowstitch types. At the business end of the stapler there is a small catch that you need to pull rearward and the front staple head will drop down. Inside, you will see a metal bar and a spring. Pull the spring back towards the rear of the stapler and insert a full clip of staples appropriate for your stapler. Release the spring slowly so the metal tab pushes against the staples... should be pointed tips down. Put the stapler on a firm surface and press it as you would when stapling something. The two parts of the stapler head will join back together again.
Apr 02, 2015 | Office Equipment & Supplies
What gage staples do I need for a p300 ryobi air stapler?
Good morning Victoria,
The staple series that you'll need is probably need is a 90 series. These are again an 18gauge wire in several different lengths.
Regards
collatedfasteners
Jul 05, 2014 | Ryobi P300 One+ Stapler Brad Nailer
How do I open an Apsco 2000 model stapler, to refill it ?
Push the button upward, then pull the piece at the front forward, the staple tray will slide out.
Jun 16, 2014 | Staples One Touch Executive Stapler
Help please! I have a Paper Pro high capacity stapler that will not staple. I can open it up and put staples inside, but no staple will come out when pushed down. Oddly enough, if I put ONE staple inside...
are you using the correct size of staple?? (thickness wise) secondly check the spring is pushing as it should, also a fix to get it working is as you put the staple stack into the stapler, seperate them and see if will staple. other than that it's defective and you should purchase a new one.
Oct 30, 2013 | Staples PaperPro 1200: Heavy Duty Stapler
Apsco A9 loads apsco HO staples, can remember how to put the staples in it anymore.
Carole - re A9 Apsco stapler - my A9 is not a staple-gun but is what I call a heavy-duty stapler for 10+ sheets of paper. There is a hinged metal hood at bottom end of handle (beige colour on mine). If you pull that metal hood upward towards you (being the handle mechanism) you will see the staple loading track mechanism with tradtional-lever that releases spring for loading staples. Good luck!
Feb 08, 2011 | Tools & Hardware - Others
Instructions on how to load a swingline heavy duty stapler.
You pull up and back on the stapler head. Then pull out the spring that keeps the staples loaded. Be careful as the spring is very strong. Then put in the staples and put the spring back in behind the staples.
Aug 13, 2010 | Swingline Heavy Duty Stapler 30 160 Sheet...
How to put the staples
depress the handle enough to release the side catch on the stapler. now pull the bottom track down. insert a few rows of staples and snap the track back up into the stapler. the spring loaded follower goes in back of the staple stack.
Oct 20, 2009 | Arrow CHROME STAPLE GUN ARROW IND....
Problem loading gun..Where do we put in the staples and change the dial to accomodate it? fred
The staples should load in through the end of the hammer stapler. The end is spring loaded to push the staples forward, so push the end - usually a crome square - into the handle end then move that part up approximately 1/4 inch and pull back. The spring mechanism should slide out so you can add new staples. These staplers take a specific size of staple and a certain number to allow you to put the spring mechanism back into the stapler. If you do not know the correct size for your stapler someone at your local hardware store can help you find the correct size and they will probably even show you how to load it. Good luck!
Jul 07, 2009 | Ace Hardware Ace Heavy Duty Staple Gun...
424 people viewed this question
jasbo
jasbo
