Question about Goodmans Televison & Video
Goodmans ld 1912 tv data base is empty - Goodmans Televison & Video
Where are the railway carriages from?
They are based on the Worth Valley Railway near Keighley in West Yorkshire (http://www.kwvr.co.uk/) and are often in use for the public to travel in during special events. They are owned by the Vintage Carriages Trust (http://www.vintagecarriagestrust.org/) and the Lancashire and Yorkshire Railway Trust (http://www.lyrtrust.org.uk/) - one of theirs is the unique Blackpool Club Carriage of 1912, which was partly refurnished on set to be Winston Churchill's travelling office.
Sep 04, 2016 | Peaky Blinders (2013)
Keylock - how to remove without remote
Without a remote control, you can't unlock it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 04, 2014 | Televison & Video
Westinghouse LD-4655VX Power on fine, nice picture, but around 5 minutes turn off self it
hi. the led tv turn off itseft aroun 5 minutes was complete shut off or another ?? need more data???
Jan 08, 2014 | Westinghouse LD-4655VX 46" LED TV...
Missed the screws
4mm diameter by 7mm long screws avail @Lowes in special fastener section
May 28, 2012 | Westinghouse LD-4055 40 Class LED HDTV...
Have purchased a Technika TK81R universal remote control to use with my Goodmans LD 2667D but canot get it to work any idea what to do?
Setup codes for Technika TV with universal remote contol are:
0031 0004 0005 0009 0051 0053 0105 0109 0170 0000 0174 0001 0008 0012 0042 0058
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
    Code Search Method
    1. Manually turn on the device (TV, VCR, etc.) to be controlled.
    2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
    3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
    4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
    5. Press and release MUTE to install the code. The indicator light goes off.
    Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Apr 27, 2012 | Televison & Video
Can I get a manual for a Goodmans LD1547D
I have not been able to find an online manual for your LD 1547D. However, you can go to the Comet/ Goodmans website (link below) and submit a question for a manual after registering your email address.
Customer Questions & Answers: Click here to Ask a New Question
Or:
http://answers.comet.co.uk/answers/0331-en_gb/product/594466/questions.htm?page=3
Feb 05, 2011 | Cell Phones
LD code and will not empty. I cannot find my manual
i believe the ld is for load dispersal so check you are not overloading machine
Dec 16, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Database empty?
Set top box VSTBAW09
Error code: data base empty??
Aug 31, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Washer won't empty water....
Ld Long drain "Ld" flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
Press STOP/CANCEL to clear the display.
Mar 18, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Televison & Video Logo
117 people viewed this question
Top Goodmans Televison & Video Experts
Kolbrun...
Are you a Goodmans Televison and Video Expert? Answer questions, earn points and help others
