Question about Goodman GMS90703BXA Heater
We have a goodman gmpn100-4 that won't work. There is a light switch in the electrical source from the main power source, and if you turn it off, then on again, the unit light flashes 3 times. When you turn it on, you can get it to get hot and run for about 30 seconds, then it shuts off. What causes this, and where can I get a diagram so that I can fix it? Thanks so much!
  • 472 Answers
As far as the manual it will have the user manual in it... call 817-831-3772 this is a goodman number i have located in fort worth texas they should be able to fax or mail you a copy of your manual..
the operation of the furnance the thermostat calls for heat and the enducer draft motor comes on and runs pulling a negative pressure on the hose that runs from the housing over to a pressure switch.. once the pressure switch closes then power is sent to your hot surface ignitor(glow plug)
and then once it gets hot a milivolt current is sent to gas valve and is told to open for a few seconds. there are also limit devices around the burner that usually are resetable just push them and a high heat limit that if tripped usually will cause fan to run non stop...take door panel off and hold door switch and watch operation where does is fail in what part of operation....good luck to you hope this helps please vote.....
Posted on Jan 03, 2011
  • kevinmargo Jan 06, 2011
    I believe that I am experiencing the same problem with my furnace. The gas will shut off shortly after the hot surface ignitor (glow plug) turns off. I can force the valve to stay open to let the furnace heat the house. This problem is intermittent and after forcing the value to stay open, the furnace will run normally for 6-12 hours and then needs attention again. I've replaced the computer board with no luck. The last part in my thinking is that the valve is defective. Any assistance anyone has with this would be appreciated.
Goodman GMH95 furnace getting code 3.
humming noise from motor means it is seized
Jan 13, 2013 | Goodman Heating & Cooling
Start then not start,no power to inestion or starter ,then start and run a while shut it off then wont turn over again
It may be a bad ignition switch, that or a loose or bad electrical connection somewhere. Check for corroded terminals in the power distribution box near the battery. If no help, you may need an electrical diagnosis of the ignition circuit and the ignition switch.
When it won't respond, do lights and other accessories work? If no, it's a main power problem near the battery or distribution box. If yes, it sounds like the ignition switch or the wiring from the switch to the starter or to the ignition system.
Oct 23, 2012 | Chrysler Town and Country Cars & Trucks
MIne Whirlpool duet is having probloms please help me with it!
see this causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Oct 05, 2012 | Indesit W 123 Front Load Washer
Kenmore Elite Model 110.42926 202 after setting the desired cycle will not start when you push the start button
Oct 05, 2012 | Kenmore Elite 45986 Front Load Washer
Tv won't turn on
you have to shut your main power down at the breaker box. It can be off for about ten min.
I hope this works for you.
?label=319qcjrupaeqnpg78wm&guid=on&script=0ep?sid%5b%5d=36973114&sid%5b%5d=30541789&sid%5b%5d=30541794&rid%5b%5d=955456&rid%5b%5d=882320&rid%5b%5d=882321&pt=ecoust2996?phint=oiqseg=36973114
Feb 11, 2012 | Sharp Televison & Video
My goodmans tv switched itself off and won't work
Make sure that the electricity is working
Make sure that every connection is in place the
scart connection as well.
Disconnect and wait for 2-5 minutes
and connect and start.
If that does not work look for troubleshooing in the manual or click on the name of your TV here at the top of the page.
good luck
kolbrun
Aug 11, 2011 | Goodmans GTVL32W27HDF 32 in. LCD TV
Two years old. No power. Shut is off to empty the tank and it won't turn on. NO power light. Tried the reset button. Trien another electrical source,,still have nothing thank you
Try the tank position there should be a switch that is activated to shut the unit off if it not in place, or water would get on the floor.
Jul 01, 2011 | Danby DPAC120068 Air Conditioner
Goodmans LD3265D1 TV won't switch on.
use a freeview box, turn the dtv off in the menu
To get it too power on press the source button a lot after a (good) few trys your get it up on another source, my own tv does this and using a freeview/freesat box makes it use-able just a pain to turn on in the first place even if you turn the dtv off in the menu
If anyone knows how to get it to turn on stright to another source would be great to know how
Mar 31, 2010 | Goodmans GTVL32W27HDF 32 in. LCD TV
Goodman gds80703 turns on and off intermittendly 3 light blinks
There will be a diagnostic code that will blink on the control board. Look thru the clear window at the control board after the unit does not light up. On the reverse of the front panel, you will find a wiring diagram and in that area there will be a diagnostic code table. Sounds like a bad gas valve.
Feb 15, 2009 | Goodman GDS80703ANA Open Flame Mid-Size...
Goodman GMS90703BXA Heater Logo
191 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
