Question about Samsung Refrigerators
It will not get cold. it runs - Samsung Refrigerators
    Brigadier General:
  • 3,917 Answers
Hi
If the freezer is not getting cold then there are various circumstances that the problem could occur, please check the bellow links to have a detailed idea related to the problem of refrigerator:-
http://www.acmehowto.com/howto/appliance/refrigerator/diagrefrigerator.php
http://www.repairclinic.com/Refrigerator-Troubleshooting?red=Refrigerator-Repair-Help#itsnotcool
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Jan 03, 2011
Where is the cold water valve on amana washer
the cold water valve is at the end of the hose at the back of the machine
if the cold water pipes run outside to the garage , it is a fair bet that the water in the pipes has frozen
easy to check --take the cold water hose of the tap and see if it runs
if it runs replace the solenoid for the cold water valve
May 10, 2017 | Amana Washing Machines
Won't start when cold
hello wyatt...... Is your jag.built with a carburetor or fuel injected?
Carb, your choke is not set to close when cold, and should be set. When set, it also sets a cam that keeps the engine running fast. Then when warm, you hit the pedal and the cam moves, and the engine speed goes to normal. Unless the choke is set, the engine cannot keep running, as it tries to run on cold gas and it can't run good on cold gas. It needs more gas, therefore, and the choke makes more gas go into the engine.
Fuel Injected, the computer should adjust the amount of gas your car is getting when cold. If not, the coolant sensor might be bad.
The coolant sensor senses the cold engine and tells the computer to add more gas. Once the engine is warm, the coolant sensor tells the computer to put the gas to normal.
So, if the sensor is not working, the engine will try to run normal, and if cold, it can't. Joe Thanks for choosing Fixya!
Dec 24, 2010 | 1985 Jaguar XJ6
Cold water run into washer slowly. Pull off cold
water may flow fine through the hose itself, but you prob. have a damaged water inlet valve on the washer.. ( what the hoses are conected too... hope this helps...
Oct 27, 2009 | Washing Machines
Cold water won't run into washer. warm is fine,
Hello.
If the cold water will not run into your washer you will need to replace the water valve on your unit.
Jul 16, 2009 | Washing Machines
The cold water won't run anymore. The warm will run but no cold. Even in the rinse cycle.
The cold water supply valve can be bad, the cold water hose can be twisted and crimped, the selector switch for cold can be not operating or the water inlet filter < on washer end of hose can be plugged, the water valve for supply may be off or some other cause.Inspect cold water hose for crimping, disconnect both supply hoses and check for any debris on washer valves, run cold supply to verify it doesn't have a problem then problem exists within washer. From this point if you still have problem then you will need assistance to narrow down cause.
Apr 25, 2009 | Washing Machines
Turn on cold wash and no water will run.
It sounds like your cold water celenoid is going out. You have to replace the whole water valve. it should be around 30 bucks. your local parts store should have it in stock, Just take your model # with you.
Nov 21, 2008 | Maytag Atlantis MAV8551 Top Load Washer
Kenmor frig not getting cold
same problem then suddenly would not shut off, kept running. found out it was the thermo couple as well as the timer.
Mar 16, 2008 | Kenmore 60721 Refrigerator
Water won't stop running
It might have a small stone or something similar in the water soleniod valve or it might just be sticking open somewhat. I'd go ahead and change the cold water soleniod valve because it's not closing itself and shutting off the water flow.
Jan 08, 2008 | Maytag Performa PAV2200
Refrigerators Logo
50 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
