Question about Canon CanoScan 5000F Flatbed Scanner
Canoscan 5000F scanner driver needed 64-bit windows 7 OS
You can find solution in vincenzomazzotta.blogspot.com or traslated by google traslate service in english in http://translate.google.it/translate?hl=it&sl=auto&tl=en&u=www.vincenzomazzotta.blogspot.com
Posted on Jan 04, 2011
Canoscan 5000f driver for windows 7
Canon knowingly disabled Windows 7 support for all of the old products in 2009. You need a pre-Vista CanoScan toolbox version 4.1.3.5, it will work fine in Windows 7. I uploaded a copy on my website rust.mine.nu.
Apr 26, 2012 | Canon CanoScan 5000F Flatbed Scanner
Je ne peux pas installer mon scanner "Canoscan
As tu le pilote 64bits??? si non il le faut, il se peut aussi qu'il ne soit pas support? dutout par Windoze 64bits
Bonne chance!
Apr 26, 2011 | Canon CanoScan 5000F Flatbed Scanner
My canoscan 5000f does not work with my os vista 32 bit, do you have a solution?
I have many years experience repairing Canon scanners so here is my suggestion for you.
My suggestion is this, I would google Canon Canoscan 500f drivers, just as I have written it to you. A page will pop up and download the latest drivers from Canon's official web site ( the drivers are dated). Before you install the drivers disconnect the cable from the scanner to the computer. Now install the drivers. Once they are installed reconnect the cable from the scanner to your computer with the scanner powered on. A window will pop up saying a new device or drivers are being installed.Once this is completed then reboot (restart) your computer and you should be able to scan again.
I hope this helps you out.
Mar 09, 2011 | Canon CanoScan 5000F Flatbed Scanner
No driver for Canoscan FB 630U Vista 64 bit
Unfortunately, it doesn't look like Canon supports this scanner under Vista. Check if the Windows generic TWAIN scanner driver will work. The Canon software won't work. If the generic driver can be installed, then you should be able to acquire scans in Paint (File > Import from Scanner or Camera), Windows Fax and Scan (New Scan) (some versions of Vista) or Windows Photo Gallery (IIRC it works like Paint).
I hope this helps.
(Canon wants you to upgrade. I have a different scanner that isn't officially supported past XP and the generic driver works fine. Unfortunately, you can't just use the XP driver in the compatibility mode due to the lack of signed drivers that are required in the 64-bit OS)
Jun 03, 2010 | Canon CanoScan FB630U Flatbed Scanner
Driver for canoscan lide 35 for windows 7, 64 bits
this is the support site ...and the driver I found there is for windows 7 but on 32..Cause they do not have one for 64 bits OS yu should download and try the Vista one on 64 ..cause the compatibility is usually high and it s worth give it a try ..If not the only way you will be able to use is if you reinstall the windows & on 32..You will not feel much difference but the driver's compatibilities will be easier to match
May 31, 2010 | Canon CanoScan LiDE 35 Flatbed Scanner
Canoscan Toolbox returns a TWAIN error with
maybe the software that you download is a 32 bit O.S only that's way it cos you and error. because your O.S
is not compatible to the software that you use. download a 64 bit driver twain
Mar 05, 2010 | Canon CanoScan 4200F Flatbed Scanner
Canon Canoscan D1259U2F dont have any driver for Windows 7 64-bit
the only successful method I found for using CanoScan D1250U2F in 64 bit Windows 7 (I guess the same would be for 64 bit Vista) is to use Windows XP Mode in Virtual PC (attach the scanner as USB device and that's it - works perfectly)
I had a problem with Windows 7 detecting the device as CanoScan (needed for Windows XP Mode to detect is as USB device and allow attach) - the solution was to unplug the scanner, plug it in and CANCEL Windows 7 hardware detection process before it finishes - this leaves it as "CanoScan" device (auto-detect will leave it as "Unrecognized device" and with that unusable/un-attachable in Windows XP Mode)
latest versions of Windows XP Mode will make your hard drives accessible as network locations (no need for external media)
Jan 01, 2010 | Canon CanoScan D1250U2F Flatbed Scanner
CanoScan LiDe 60 wont work on emachine with window 7. Error about being 32 bit.
Go to the following URL: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=235&modelid=11446#DownloadDetailAct
Then select your OS.The drivers and software for Win7 32 bit and Win7 64 bit different. The Win7 64 bit drivers are digitally signed; the 32 bit version doesn't need the same level of security certificates (a Microsoft issue).
I hope this helps.
Dec 18, 2009 | Canon CanoScan LiDE 60 Flatbed Scanner
I have an HP laptop OS Vista i tried to
Hi There,
there are no 64 bits drivers available on the cannon website(x64) and you cannot install it using the 32 bit vista driver
Sep 03, 2009 | Canon CanoScan 5000F Flatbed Scanner
Canon CanoScan 5000F Flatbed Scanner Logo
1,435 people viewed this question
old marine
old marine
