Question about Toshiba Equium 7100S PC Desktop
How can I stop my Toshiba Equium from overheating and crashing. This usually happens after about an hours use but also it always occurs (almost immediately) when I try to transfer big files such as videos etc. from a memory card
    Brigadier General:
  • 8,909 Answers
If the air ways are clear and the fan is running fast, does it blow lots of hot air or would you expect it to blow more. Try cleaning the exhaust side of the uProcessor fan out with a vacuum cleaner and use fresh heat sink compound on the uProcessor heat sink..
If it still gives trouble, browse toshiba.com for a BIOS update to speed the fan up.
Hope that helps.
Posted on Jan 03, 2011
My Toshiba Equium A110-252 keeps turning off. When I try to turn it on, it turns off again. It can run for unspecified period of time (a day, a week) and one day it just turns off and it is impossible to...
It is not worth replacing the board as a new laptop is possibly cheaper. Could be an issue with the heat sink compound drying out and not taking the heat away correctly from the uProcessor. It may be fluff build up in the heat cooler!
Oct 07, 2013 | Toshiba Equium A110-233 A110-252 A110-276...
Crashes several times a day.
I had a similar problem with a Compaq laptop. Turned out to be the battery. To see if it is, take the battery out and run it from the mains for a while. If the problem occurs then its not the battery (not much help I know but it illiminates one possible source).
Jan 17, 2013 | Toshiba A505S6005 Core i3330M DualCore...
My Equium A200-1V0 fan stopped working
The User's Guide is available on this page on the Toshiba website, under the User's Manual tab.
I have also compiled a tip for dealing with overheating issues on Laptops as that is a common issue.
You may please refer to this link for reviewing the same.
May 10, 2010 | Toshiba Satellite A100-S8111TD Notebook
Need drivers for laptop hard drive crashed reloaded windows but no drivers toshiba does not list this model
www.drivermax.com
visit the above site, download the free driver utilty and it will scan for hardware, find the latest drivers and let you choose what to install( I used it to "downgrade" from vista to xp on my Toshiba Equium P300D, it was excellent).
Oct 10, 2009 | Toshiba Satellite M35X-S109 Notebook
Problem with Toshiba Equium Laptop which is switching itself off. even when connected to mains supply Is this a problem with the switch or power supply? Hope you can help thanks
If the laptop shuts down and won't boot up straight away, then the problem could be an overheating CPU problem. It could be a faulty fan and/or the fan and heatsink assembly is clogged with dust.
Check the fan and if it has stopped spinning then replace it and if the fan and heatsink is clogged with dust, loosen the dust and remove it.
Sep 28, 2009 | Toshiba Equium 3300M PC Desktop
I have got a Toshiba Equium A200 series that won't bootup
if the fan is not running continuously then its the fan ans board problem.because the board is getting hot and fan is not running so the board is getting overheated and the machine is nor working.and if the power light is ON and fan is running but only the screen is black/blank then its the problem of inverterboard.the cost of new board is $25 get it replaced fromn near by laptop repair center. thanks.
Aug 30, 2009 | Computers & Internet
Toshiba equium m40x won't power up
whats happening is that the cpu is overheating and shutting down the computer due to your fan not spinning, if you wish to test this remove the bottom panel and remove the fan and its cooling tubes should all be one part (quite easy 3 or 4 bolts) and blow on the cpu or put a pedistal fan facing it or any other form of cooling that wont damage it, and try to start it if it boots for a while it is the fan and you will need to replace it, i had this exact problem yesterday
May 18, 2009 | Toshiba A70-S256 Notebook
Toshiba Equium L20 Laptop crashed
is it running in safe mode just press the F8 key and start in safe mode
and restore the system .
Oct 19, 2008 | Toshiba Computers & Internet
Toshiba Equium 7100S PC Desktop Logo
197 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
