Question about Kenmore Washing Machines
My toploader washer smells sour inside - Kenmore Washing Machines
Remove the turning wheel in the drum and clean underneath and inside it. Also clean the filters. You can also descale the maschine by adding descaler and choose the hot washing cycle.
Posted on Jan 03, 2011
I cleaned my washer with affresh and it still smells very sour
dump a box a baking soda in it and run empty . see if it helps your problem
Jun 22, 2016 | Whirlpool WTW6400SW Cabrio Washer
My Maytag Topload Bravo washer has the smell of bad well water, or stagnant water on occassion. (I have city water, btw.) Also, no matter what detergent I use or what cycle I wash, or what tempurature the...
I can't be sure without looking at the machine but I have had several of these type of machines the get cloths under the agitator "wash plate thing" in the bottom of the basket. This will eventually clog up the pump but stuff that hangs out in there can really get to smelling after a while. Try removing the wash plate and see if you see anything under there. In the future make sure you use a lingerie bag for all small items to prevent them from getting stuck under the wash plate.
Oct 28, 2010 | Maytag Bravos MTW6600T Top Load Washer
Mildew smell in washer
there is a chemical you can get to help with the smell from SMELLYWASHER.com
Feb 19, 2010 | Kenmore 22942 Top Load Washer
How do I get the sour smell out of the washer. I
I found a 50/50 solution of vinegar and warm water will generally do the trick.
Nov 06, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Sour smell coming from washer even when door is
If you have a front loader it will hold water around the seal of the door and after time it will mold and start to smell.
Jun 29, 2009 | Kenmore 94702 Front Load Stacked Washer /...
Sour clothes smell from washer
Until you can find the filter (I'll investiate!) I suggest running it on hot hottest wash you can (empty) with just bleach. That at least should kill the bacteria that are causing the smell
Jun 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool duet front loader washer
Mold and bacteria in your door seal is a symptom of problems deeper inside the unit. All washers - not just Whirlpool, have this problem. The area of worst buildup is always on the inside of the plastic outer tub just above the normal waterline where suds and soiled water splash up and don't get rinsed out. To clean this problem area add 1 or 2 caps of smelly washer cleaner to a full load of laundry. The added bulk of the laundry will raise the water level to include the "splash area". Intermittently pause to soak more extreme cases.
Aug 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
My washer a Tromm LG DLE377W leaves a bad smell in clothes after washed the smell is in the washer also smells sour
Sears has tablets for front load washers that work great. I use one every month and it has helped the stinky washer smell and the bad smell in the clean clothes. It is called Affresh and it works better than any of the cleaners you can buy in the grocery stores.
Aug 07, 2008 | LG Washing Machines
Frigidaire Affinity Front Load Washer
You have to remove and clean the rubber around the front of door,
, Snap it back on.
disconnect AC to prevent any accidental shock.
open the bottom access panel
screws on bottom front , open the large filter and be ready for latent water to spill out , have rags ready.
clean the inside of the filter with clorox.
finally run a strong solution of clorox when you finish.
then rinse well.
leave the door open after loads finish
the door has a child lock
black dot next to lock on door , insert coin and rotate.
keeps them from closing the door.
Feb 14, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
55 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
