Question about Health & Beauty
My daughters sonicare toothbrush makes a noise but the bristles do not vibrate anymore. She only used it for about 4 days.
This happened to me as well. In my case, it meant that one of the metal bars for the brush head broke. If you unscrew the brush from the base and look at it, touch the metal stabilizer bars inside to see if one of them is broken. If so, a simple brush head replacement will fix your problem.
Posted on Jan 09, 2011
How do I get help with my Philips Sonicare toothbrush, it runs when I am not using it, how is that possible?
There is probably no fix for it, as it is not made to be repaired; if it malfunctions, you are supposed to discard it and get a new one.
However, it is likely the problem is in the switch of the toothbrush.
It may have some foreign matter inside that is causing the contacts to close when not in use, and that its why it is turning on all by itself. If you want to try something to fix it, I would get a tank of compressed air and a blower and try blowing the air into and around the off/on switch.
It might fix it, or it might destroy it.
Aug 04, 2016 | Sonicare Philips Essence 5500 Toothbrush
It is making 3 beeps and I would like to know what that means, and what I should do next.
Hi Noel:
The instructions that came with it should tell you.
I'd guess at 2 possibilities:
1) Needs re-charging
2) Brush needs replacing
Aug 26, 2015 | Sonicare Philips Rechargeable Toothbrush...
Why is it making a loud noise after reacharging,never before
Are you sure the brush attachment is "tight" to the handle? Do you have a new brush to try? It should confirm handle is bad or it is the brush attachment "tightness" .
Mar 11, 2015 | Sonicare Phillips Philips Sonicare...
How do I return an item that has become defective
its 4 years old and way out of warranty. did you expect it to last forever? buy another one if you like it and dont if not. logic...
Nov 23, 2017 | Sonicare Philips EasyClean Rechargeable...
What are the best electric toothbrushes available?
The best electric toothbrushes are the Oral-b Professional Care and the Phillip Sonicare Diamond Clean. You can find more information on these electric toothbrushes on their respected websites: http://www.usa.philips.com/c/diamondclean/289711/cat/en/ and http://www.oralb.com/products/professional-care-smart-series-4000/.
Feb 04, 2013 | Health & Beauty
Sonicare hx9642/20 toothbrush making short humming noises and will tend to turn on on its own. How can I fix this?
This happened to me as well. One long, two short beeps. Incessantly. Only happens when brush is on the charger.
Try this simple fix first. Hold down the SILVER button for 5 seconds while the toothbrush is on the charging base. If the fix works, it will fix the problem immediately like magic.
If that doesn't work, try this:
1) remove brushhead.
2) use screwdriver in the base and turn 1/4 turn
3) push out assembly from the top
4) dry the inside of of the base handle. allow to air dry
5) allow the switch to air dry
6) reassemble
Jan 05, 2013 | Sonicare Philips Flexcare+ with UV...
My sonicare toothbrush won't charge
The best tutorial for repairing Sonicare toothbrushes is here:
Repairing your Sonicare
The problem is either a corroded circuit board or worn-out Ni-Cad batteries. Both repair solutions require soldering, but full repair is possible.
Sep 30, 2011 | Sonicare Philips Essence 5500 Toothbrush
Had my Sonicare Healthy White toothbrush for over a year. recently it started cycling up on it's own and would stop and start randomly. When I put it back on the charger all the lights would go off and it...
I had mine for many, many years without a problem. I bought mine directly from them when they were first starting up, before they started advertising.
There's no easy fix as the internal electronics have gone kapute. Before pitching the unit for a new one, contact Sonicare and see if they will be willing to work with you by replacing it for a discount.
If not, the Oral-B is FAR superior product and is the only type I see recommended by dentists. Really made a difference over the Sonicare.
Both are highly rated however. Ask your dentist for his opinion.
2018 reiview:
Best Electric Toothbrush Reviews of 2018 Reviews com
Feb 09, 2018 | Sonicare Healthy White Toothbrush
Health & Beauty Logo
1,460 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
