Question about Canon ImageRUNNER 3570 Copier/Printer
The canon ir 3570 won't staple on the correct side of the papers. we want it to staple in the upper left corner but it only staples in the upper right corner. Can't use the stapling fuction unless it can staple correctly. Makes me staple by hand.
  • 62 Answers
SOURCE: f-1 finisher not stapleing
Have you tried the staple setup procedure, or maybe swap the Finisher DC Controller off the Finisher that the known-good stapler carraige came from? I think DC Controller.
Posted on Nov 16, 2007
  • 62 Answers
SOURCE: inserting staples
If the machine has an in-built finisher, the stapler is located in the rear of device. Pull the finisher release handle and pull the finisher towards you. Extract the staple cartridge by pulling up in the green tab at the rear right of the finisher. The staple cartridge can be opened by squeezing the sides together to allow the spring to act. (Sometimes it can be helped with a screwdriver popping the clear tabs located on the underside). Insert the replacement staple pack and pull the orange tab before closing the cartridge shut. Reinsert into the finisher and push down to locate it. Should work ok after all that.
Posted on Dec 01, 2007
SOURCE: cant staple from driver but can staple directly from the machines panel ... particularly 8x14
Most Likely the issue is resolved by configuring the driver properly. If you right click the printer under Printers and faxes in your start menu you need to go to properties, then to the configuration tab and then to Auto Configuration. it will then communicate with the printer and find out what options are installed and then enable you to use stapling from your computer. Make sure to select where the hands are pointing also. thanks. you will understand.
Posted on Jun 05, 2009
  • 5 Answers
SOURCE: How to install staples in Canon ImageRunner 4570
CHECK TO SEE IF YOU HAVE A STAPLE JAMMED IN THE STPLER UNIT FIRST, MOST LIKELY THATS YOUR PROBLEM,GOOD LUCK !!!
Posted on Jan 23, 2010
kachi
  • 406 Answers
SOURCE: the paper jams into the right corner when
if you can get it out consult a technician to do that, because it is the cause of the paper jam and could also damage the drum if you continue.
Posted on Feb 06, 2010
Konica monolta c650 wont fold
Saddel stich (Church program and staples in the middle)? or corner? Or booklet with two staple on the on left hand side? Saddel stick requires paper in landscape.. Check the staple cartridge. ensure both cartridge are securely installed.
Aug 29, 2014 | Konica Minolta bizhub Office Equipment &...
How do I replace staples in the Konica Minolta Bizhub 600?
The saddle stich or the booklet??? saddle stich is like church program with staples in the middle. Booklet is staples on the left side of the paper or the corner stapler to different staplers and depends on the finisher model?
Aug 08, 2011 | Minolta Office Equipment & Supplies
We used to have canon imagerunnerr 3100 and recently swapped out for 3220. Everything works basically the same except stapling. On the 3100 if I was photo copying and stapling a landscape document it...
Its only because I care about folksthat I answer questions like this since the chances of have my score diminishing is so great when the feedback rolls in.Ok,gut check tells me you have a different(less capable) stapler(finisher).The old standard has been upper left corner. then came the "zoom" stapler that could move to most anywhere to provide stapling on LTRR and legal.I bet you have a NEW and improved copier, but the finisher has less capabillities.Ask for the old finisher back if thats an option.The old finisher SHOULD interface with your new copier. I hope I helped.... ! :-)
Jan 04, 2011 | Canon imageRUNNER C3220 Color Copier
How do you change a staple cartridge in a canon imagerunner 2870?
first open upper front cover.
then pull handle on left corner of front side, the sorter unit will come out. see behind side of sorter unit u'll find a small green handle to detach the staples cartridge, replace the staples cartridge and insert unit into stapler. push back sorter unit an close the upper front door. end
Dec 20, 2010 | Canon imageRUNNER 2870 Copier
Cant get staples into it!!!
Sue, First, confirm that you have the right size staples. They are sized in two dimensions - width and length. The most common width sizes are T50 and T35. Your stapler and your pack of staples should have a number such as this. Your stapler will accept staples only of the correct width but of various lengths. The lengths are given in fractional inches - 3/8 inch and 1/2 inch are common.
But perhaps your problem is how to open the stapler. It does not swing open like a stapler you would use for papers. Instead, it has a sort of spring piston that has to be removed from the back-end of the stapler. If you lay the stapler down flat on the table so that the hinge of the handle is at the upper left corner, then what I am calling the back-end of the stapler is the lower right corner. Pick up the stapler so that you are looked directly at this back-end. There is a small metal square at this corner that is spring-loaded and is held in place by a little hook. Push in on this metal square as you move it up (or is it down?) to disengage the hook. Now the piston will pull out easily. Put your staples in the hole (they will only go in one way) and replace the piston. I hope you found this helpful Good luck!
Aug 19, 2010 | Arrow CHROME STAPLE GUN ARROW IND....
Canon ir 3530
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
E490 wrong DF type
E500 finisher communication error
E503 finisher internal communication error
E505 finisher backup memory error
E514 stack delivery/trailing edge assist motor error
E519 gear change motor error
E520 off-set motor error
E530 rear alignment error
E531 stapling error
E532 stapler shift error
E535 swing error
E537 front alignment error
E540 stack tray ascent error/upper tray ascent error
E542 lower tray ascent error
E577 paddle error
E584 shutter error
E590 punching error
E591 puncher dust sensor error
E592 punch horizontal registration sensor error
E593 punch shift error
E5F0 saddle paper positioning error
E5F1 saddle paper folding error
E5F2 saddle guide error
E5F3 saddle alignment error
E5F4 saddle rear stapling error
E5F5 saddle front stapling error
E5F6 saddle butting error
E5F8 saddle connector error
E5F9 saddle switch error
E602 hard disk error
E604 image memory error/shortage
E609 hard disk error
E610 herd disk coding key fault
E674 fax board communication error
E710 IPC initialization error
E711 IPC communication error
E716 communication error for pedestal/ communication error for 3-way unitA1
E717 communication error for NE controller
E719 coin vendor error
E730 PDL software error
E732 scanner communication error
E733 printer communication error
E740 Ether board error
E743 DDI communication error
E744 language file/boot ROM error
E745 TokenRing board error
E746 accessories board wrong model error
E748 controller board and SDRAM size mismatch
E805 fan error
Feb 21, 2010 | Canon ImageRUNNER 3570 Copier/Printer
Load Staples in a Canon ImageRunner 2200
First step, have staple cartridge on hand, type J1 for the iR2200.
Open the front cover of the finisher, which is the door directly below the control panel, which opens from left to right.
There's a handle to grab on the front right corner where the paper comes out, pull it out all the way.
This will expose that module's back right corner where the green staple holder handle is.
With thumb and forefinger, reach in, take hold and lift up and pull out the staple case by its green tab.
You'll see "push" on the sides of the staple case, squeeze thumb and forefinger, one on each "push" sign, and the top will spring up, which is the clear plastic case through which you can see a large spring. Pull out the staple cartridge from the back, under the green tab.
Put the new cartridge in with the orange seal tape hanging out the back.
Press down on the spring-loaded case until it clicks into place again.
Remove the orange seal tab by pulling straight back, then down, not at an angle, as you don't want it to break, just to come off.
Holding it by the green tab, lower the staple case back into the finisher until it settles snugly into place.
Hope that helps!
Feb 09, 2009 | Canon imageRUNNER 2870 Copier
Canon imagerunner 2270 staples on the right side
Under user screen you have in lower left corner finisher or similar. press it, and chose staple and left or right
Nov 20, 2008 | Canon MF8180C Color Laser MFC Printer
Inserting staples
Nov 26, 2007 | Canon imageRUNNER 3570 Copier
F-1 finisher not stapleing
Nov 16, 2007 | Canon imageRUNNER 5000 Copier
82 people viewed this question
old marine
old marine
