Question about Magellan eXplorist 200 GPS Receiver
The screen is real faint since I changed battery how do I get a clear screen again?
    Problem Solver:
  • 5 Answers
Mine did that. I went to preferences and reset to default and then i did clear memory all and it instantly started working.
Posted on Sep 05, 2013
Faint screen
Try using an external screen. If that is OK, replace the screen as there may be a hairline crack on the driver boards.
Apr 01, 2014 | Toshiba Satellite Pro L300 Notebook
Fuji HS20EXR wont turn on after turning off
A defective rechargeable battery caused this on my camera, not sure about the blue haze though. Make sure battery is good or use fresh alkalines.
Mar 24, 2014 | FUJIFILM HS20 EXR Digital Camera
My hp mini 210-1000 boots up well both on battery and adapter but it displays faintly on battery while it display well on power adapter
the problem is that its set in the power saving options. i mean on battery its set to power saver . while on power adapter it changes to hp recomended or high perfomance. So if you want to change it go to the right bottom of your screen and click the battery symbol it should give you the option to 1> change screen brightness 2>more power options. Go to more power options and select "change plan settings" beside the power saver.(not the one beside the other options) and change ur brightness. but its always better to keep it at ur minimum(with what ur comfortable) as its helpful to save battery
Jan 10, 2013 | HP Mini 1000 Netbook
Hi & thanks. There is a small 'M' on the top center right of the 'number' screen. How do I get this to go away? Remove the battery? Thanks again & regards, -louis
This M does no harm. It merely reminds you that you stored something in memory. You can try pressing the AC (Clear All) button. Alternatively, store 0 in all the memories. If I am not mistaken you have 3 memories. Try
0 STO 1 to clear Memory 1
0 STO 2 to clear Memory 2
0 STO 3 to clear Memory 3.
Jun 29, 2011 | Texas Instruments BA Real Estate...
I dont remember power on password for hp nc4400
The power-on password prevents use of the computer until the password is entered. The
setup password prevents unauthorized changes to Computer Setup. To clear the
passwords, you must remove all power from the system board. If you do not know the
passwords, use the following procedure to clear the password:
1. Remove all battery packs.
2. Disconnect the AC power.
3. Remove the real-time clock battery.
4. Wait thirty minutes.
5. Reconnect the AC power. DO NOT INSTALL THE BATTERY!
6. Restart the computer. During Power-On Self Test (POST), a ? 162 System Options
not set? message appears.
7. Shut down the computer, then disconnect AC power again.
8. Replace the real-time clock battery.
9. Install the battery pack(s).
10. Reconnect the AC power.
11. Start the computer.
12.It should work....
Apr 08, 2011 | HP Compaq nc4400 Notebook
The battery dash light, the parking brake light, the brake failure light flicker faintly to bright to faint while I drive and it died on me. when I tried to start the car the following lights came on...
Replace the alternator,and clean the battery cable ends real shiny,no grey,or black film left on the cable ends that connect to the battery.Alternator does not have enough power to run the ignition and all it`s assesories.
Oct 28, 2009 | 1990 Volvo 240
Geko 101 wouldn't turn off. Removed/inserted batts, wont turn on
Press the power on button while holding OK until the unit switches on- that puts the 101 into Service mode. Then press the up key until the screen contrast is about right. (or press the down key... to make it darker). You'll be able to see if all the tests pass. Then when you're happy with the setting, turn off.
Mar 31, 2009 | Garmin Geko 101 GPS Receiver
My laptop compaq armada1700 ask me power-on password what can i do?
Follow the instructions of the service manual for the Armada 1700 (you need to have some skills):
2.2 Clearing Passwords
The power-on password prevents use of the computer until the password is entered. The setup password prevents unauthorized changes to Computer Setup. To clear the passwords, you must remove all power from the system board. If you do not know the passwords, use the following procedure to clear the password:
1. Remove all battery packs from the battery bay and MultiBay, if applicable.
4. Wait five minutes.
6. Restart the computer. During Power-On Self Test (POST, a "162 System Options not set" message appears.
10.Proceed with the troubleshooting procedures.
Point 10 means you need to do the setup via disquette to set the date and time again, to avoid the "162 system option not set" message of the POST.
Lucas from Argentina
Mar 22, 2009 | Compaq Armada 1700 Notebook
Lexmark X83 Changed black cartridge print warns Black ink low Prints so faintly can't be read
the printer heads probably need cleaning. If you go to control panel>printers and scanners> right click the printer you are using> click in properties, there should be an option there for maintenance. Choose clean print heads. When the heads have been cleaned print out the result. If this has improved but is still a bit faint repeat the steps until the page is clearly readable.
Oct 22, 2008 | Lexmark Office Equipment & Supplies
Asus M2N-MX SE
remove jumber next m/baord battery, turn on the motherboard. turn it off and put back the jumber,
or remove the battery let it out for 15 min and put it back again.
May 06, 2008 | ASUS M2N-MX Motherboard
Magellan eXplorist 200 GPS Receiver Logo
136 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
