Question about Amana Refrigerators
Model afd2535deq, 6 yrs.m old. not cooling, compressor and fan running. clened all coils.
Tech007
  • 63 Answers
SOURCE: whirlpool side by side not cooling
Your refrigerator had a defrost problem but now after you laid it down it sounds like you gave it a oil restriction when you laid it down there is oil in the compreesor it left the compressor and made its way into the evaporator in whice it has clogged the strianer dryer you will now need system work you could try to unplug it for a few days and then replug it in it might start to get cold if it does then you will have to checkk the defrost system it will either be a defrost timer ot heater ot defrost limiter or defrost fan good luck
Posted on Aug 31, 2007
SOURCE: Frigidaire stand alone Refrigerator won't cool Fans and Compressor work
Ended up having a freon leak in tubing around door. Luckly the warranty was 5 years in sealed system. New one was FREE.
Posted on Feb 23, 2008
22yooper
  • 828 Answers
SOURCE: compressor making a loud noise, freezer cannot cool
It sounds to me like the internal relief valve is lifting due to discharge pressure being to high such as it a system that is over charged with refrigerant. Have the system tested for pressures on high and low sides. If someone has serviced this unit recently there may be to much of a charge in the system. Also check the name place for the proper refrigerant and charge .
Posted on May 19, 2008
  • 327 Answers
SOURCE: Kenmore 596.73502201 Not cooling. Compressor , fan, seal ok
If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions:
  • Is the refrigerator completely dead? If so, see “It's stopped completely.”
  • Is the thermostat knob turned to the proper setting? If not, reset it.
Next, see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
Cooling is poor For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
Posted on Dec 19, 2008
SOURCE: maytag refridgerator model MSD2651HEW refridge not cooling properly
my water dispencer has a low flow after an initial regular flow. why?
Posted on Sep 05, 2009
Fridge was not cooling, but freezer worked. replaced evaporator fan motor, now fridge and freezer is not cooling at all. amana fridge afd2535deq
Did you check to see if the compressor is running? Did you mess with any of the wiring during your "repair"?
Jul 08, 2017 | Amana Refrigerators
The strip between freezer and refrig become hot then cools off. It's like it is going thru a cycle. We cleaned the coils underneath, but it is still getting hot and then in about 15 minutes, it's...
When you cleaned the coil underneath did ya notice that their was air being blown out their by a fan,having clened the coil was a good start but if the fan by the compressor isn't running that divider between the ref/freezer will be hotter than normal( its normally warm and thats ok),so check that the condenser fan is running and that it seems to running at a good speed.
GENE
Sep 23, 2011 | Whirlpool GC5SHEXNS Side by Side...
I have a Kenmore 596.72219200, refridge/bottom freezer that heats up to 50 deg then goes back to normal cooling. This is for both refrig/freezer. The blower fans run but not cooling . Any ideas before I...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 12, 2011 | Refrigerators
The outside of the top freezer of my refrigerator has been getting very, very warm. It remains warm for maybe 30 min., then cools off, and then gets very warm (almost hot) again about an hour later, only...
That is usually caused by the evaporator fan not running. It's located under the fridge accessed from the back behind the cardboard cover. The fan should run when the compressor runs.
Jul 26, 2010 | Frigidaire Refrigerators
Unit runs and you can hear the compressor come on but it is not pulling any moisture out of the air
if it seems to be running normally except no cooling , is the fan in the house running????...Is the house Cold and damp???.If there is no cooling and you know that the compressor and everything else appears to be normal then you likely have a Refrigerant leak and that will cause no cooling.....Usually a very expensive repair...if your unit is 5-10+ yrs old you likely need a new "A" coil.
Oct 29, 2009 | Goldstar DH504EL Dehumidifier
What is proper operating temp of freezer/refrigerator?
0-5 F in the freezer.36-42F in fresh food.
Check for ice buildup on the back wall of the freezer. Check the freezer fan motor. Check the compressor fan motor.
Sep 06, 2009 | Kenmore Refrigerators
Compressor kicks out and it's new
First of all, clean your outside coils so that you are assured of good cooling air. The compressors have an overtemp device that is usually internal to protect them against heat. If you have an air compressor use it to blow out the coils good. If the compressor will start, the capacitor is good so it sounds like a cooling problem with the compressor
Jun 25, 2009 | Ruud UAMB Air Conditioner
Fan running,both cold settings at 4 , freezer 14 degrees C
you need to replace the start components on the compressor, theres a relay that mounts on to the compressor that takes out the start winding after it starts the compressor up. You can also try whats called a three in one to try to start up the unit. Good Luck.
Mar 28, 2009 | Maytag MBB2254G Bottom Freezer...
Sanyo sr-1013w not cooling
sounds like it has a refrigerant leak somewhere in the unit.
Feb 20, 2009 | Sanyo BC-1206 Commercial Beverage...
Whirlpool refrigerator (top mount freezer) model ET8FTKXKQ00
I feel sure you will find the compressor start relay is probably bad unless it is a Frigidaire manufactured refrigerator. If it is a Frigidaire then if may very well be a bad compressor.
I hope I have helped, supertechks
Mar 28, 2008 | Refrigerators
Refrigerators Logo
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
