Question about Video Game Consoles & Games
It says that ive obtained the ip adress but not the internet connection
What system are u useing? just because the system found the ip address doesnt mean it connected to the router. check and make sure you have the passwords and router name, select ur home network and follow the steps. that should get you where you need to be.
Posted on Jan 03, 2011
Can't get connected to internet says unable to obtain IP adress
If trying to connect to home router: check router stickers for IP adress.
Sep 06, 2011 | Nintendo Video Game Consoles & Games
Need ip address for syrens, not sure if i remember right: 192.168.1.1???
Hi Stephan,
the ip address of your router by default should be "192.168.1.1". to check if the ip adress of your router here's the solution :
  1. go to control panel > network and sharing/networking >change adapter settings
  2. then you'll see your local area connection
  3. right click on it>properties
  4. double click on (internet protocol tcp/ip) "tcp/ipv4 in windows vista/7
  5. the select "obtain ip address automatically" & "obtain dns server464142c.jpg automatically" click ok and click ok for the other window
  7. the dns server ip show should be your router ip adress
  8. open your web explorer and type in your router ip an press "enter" you'll get your router configuration where you'll be able to change the default ip.
I hope that it will help & don't forget to rate
Kind regards
Feb 14, 2010 | Sea and Sea Syrens OnBoard WiFi...
Unable to configure router. I am using Netgear router, WGR614
first enter to your network connections in control panel, double click local area network, properties, internet protocol(TCP/IP), and tick Obtain an IP adress....Obtain DNS server..... and after that ok...ok..ok.
Now open an internet explorer window and type in the adress bar 192.168.1.1 and press enter . if you are asked for username or password try writing admin on both. good luck!
Oct 27, 2009 | NetGear WGR614 Wireless Router
Attempt to obtain IP adress failure
contact your internet provider and have them unlock your IP address
Aug 24, 2009 | Dmm Call of Duty: World at War
Internet connection failed but IP address obtained.
sounds to me like you have the security turned on . Just type in your security key on PS3 and it should connect. Best of luck!
Jan 11, 2009 | Video Game Consoles & Games
Ps3 connection to the internet
Are you sure that you got the right Ip ? Otherwise I would try to shut down the system and put all cables out and in again. If that doesnt help I am sorry and
Good Luck!
Dec 27, 2008 | Sony Playstation 3 (PS3) Console
Cant connect to http://192.168.0.50
what you need to do here is manually set your static IP adress, I had this problem as well and I know what to do.
you need to go to your network connections ( Controll panel>network connections) in xp (Controll panel>network and sharing center then left hand it sais: change adapter settings )
then rightclick your wireless connection and look at it's properties. then you need to click on Internet Protocol, for vista/windows 7 it's internet protocol 4 which you need to select. once selected click on properties just a little below.
there you'll see the setting is on: obtain Ip automaticly, but you'll have to choose ( use the following IP adress ) and enter
IP adress: 192.168.0.99
subnet mask: 255.255.255.0 Default Gateway: 192.168.0.50
once entered press OK and now go to your browser and type the routers adress (192.168.0.50) in my case and now you should be in your modems setup menu.
once changed your setting you need to change your IP back to auto obtain IP adress. or your internet still won't work
Oct 20, 2008 | D-Link AirPlus Xtreme G DWL-2000AP...
Ps3
wired conection , connection test fails obtain ip adress connect but connection internet failed.
Oct 07, 2008 | Sony Playstation 3 (PS3) Console
Signing in
Connect it to your router with an ethernet cable.
Make sure the router is setup correctly to your modem, if you can connect all your devices by ethernet cable to the internet then it's set.
If you are using a wireless connection and if it asks for the WEP or WPA key, make sure that you are entering the correct encryption key. You may want to call your router manufacturer to know the correct key for the wireless connection. FYI, it will say that the wireless network is connected but it will still fail the IP Address.
If you have a wired connection and the IP Address or DNS failed, I suggest you to call your Internet Service Provider to check for the Internet connection and obtain these (static IP address, subnet mask, default gateway, primary DNS server and secondary DNS server). If your Internet is okay, enter the IP settings manually on the console (System > Network Settings > Edit Settings > IP settings).
That should work.
Feb 22, 2008 | Microsoft Xbox 360 Console
Ps3 internet
Have you tried to find the settings automatically? Your router may be stopping the ps3 from access it to retrieve the information
Dec 07, 2007 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
14 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
