Question about Epson Stylus CX4800 All-In-One InkJet Printer
I have loaded all new ink cartridges. The printer says it is printing, it sounds like it is printing, but you can't see anything. The printer will not allow me to run a clean on it. When I press the button you're supposed to...it starts blinking and so does the start button...I believe the error button is blinking too. Anyway...it won't let me clean it, but there are all new cartridges in to...can't see any print on the paper though...and it sounds like everything is working perfectly. Help!!!!!
  • 22 Answers
If you change the cartridges, never change the printer head. clogged the print nozzles
with dried ink, you can experience as that.
for clean that, you can use separate utility software like as "SSC Service utility".
you can download it from the net. after install that, select the correct printer model
and close it. after that you can see icon on task bar.right click on that and select
"head cleaning " and select "power full cleaning " in that. do two three time same as that
and check the printer.
if cant start the printing, you need to physically clean the head or need to re please
the head.you need to contact your service agent for that.
Posted on Jan 03, 2011
  • Anonymous Jan 03, 2011
    if near end of the print cartridge life can be happened as that.
    other vice in the time period you gave to clean the paper jam, can dry and clogged
    the printer head.
  • 38 Answers
SOURCE: Still stuck ! color cartridge carrier won't move to allow my replacing them as you have suggested.
What kind of cartridges did you replace with?
Like with original ones or the other replacement you get in market.
Because with use to duplicates you get this problems many times.
If you are using original cartridges then try replacing all the cartridges at once.
And even if this does not work then may be you need to take the printer to the vendor to get it repaired.
Posted on Jul 18, 2008
marked
  • 6487 Answers
SOURCE: I have a Canon printer/scanner
Try first to do a cleaning on the colored cartrdige that you have use an ethyl alcohol in cleaning, but if possible for you to try a different colored cartridge that will also be better so we can check if this is a problem with teh colored cartridges that you have...
Hope that helps.......
Posted on Oct 10, 2008
ohms
  • 1879 Answers
SOURCE: Printing in color
already performed several head cleaning from the computer and changed cartridges
go for warranty. common for inkjets regardless of make and model to have that type of issue due to internal electronics malfunction.
SOURCE: Color printing
i can not rerember how they go back in
Posted on Nov 06, 2008
SOURCE: refuses to recognize ink cartridges
Apologies for not responding earlier, forgot all about it. Solved problem by switching printer on and off many times. It eventually recognized cartridges. Now leave it switched on.
Posted on Jan 23, 2010
Kodak esp 5210 wont print black
I figured it out. If you are low on (25%) on either colors or black, then it won't print. Even if you load a new black cartridge and it reads as 100% black, it won't print because it will only print when BOTH cartridges have been replaced and reads 100%.
Same thing happens reversed with color being replaced.
So basically, ALL printers short you 25% ink and FORCE you to buy their ink more often. Kodak is no exception.
I have 100% black and 25% color and a BW only needed text paper won't print. I been through this before. *facepalm*
Apr 16, 2012 | Kodak ESP 7250 All-in-One InkJet Printer
I cannot get my printer to print in only black and white. I have put new ink cartridges in, both color and black. I have selected "print in gray scale only" in the print options. But anything I...
Please take out the new cartridges and re-position them correctly i.e. color cartridge on the left and black cartridge on the right seating. Check that you hear a click sound when the cartridge is placed in the seating. Print a test page. Then switch off the printer for some time. Re start the printer and now carry out the gray scale printing.
Jul 19, 2011 | HP PSC 1210 All-In-One InkJet Printer
How to change printing cartridges
Here's how to change your cartridges: 1 Make sure the printer is on. 2 Lift the scanner unit. The print cartridge carrier moves and stops at the loading position, unless the printer is busy. printmastert_25.jpg
3 Press down on the cartridge carrier latch to raise the cartridge carrier lid. printmastert_26.jpg
4 Remove the used print cartridge. Note: If you are removing both cartridges, repeat step 3 and step 4 for the second cartridge.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
You may also refer to this link: How to Set Up the Lexmark X3600 or X4600 Series All-In-One
Apr 04, 2011 | Lexmark X3650 Printer
How do I change the ink cartridge on my Dell 810 printer
Ink Cartridge Maintenance Replacing an Ink Cartridge
  1. Turn on your printer.
  2. Lift the printer unit, and position the scanner support between the tabs to hold it open.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  1. Press down on the ink cartridge lever to raise the ink cartridge lid.
  1. Remove the old ink cartridge.
  1. Dispose of the old cartridge properly.
  2. If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
  1. Insert the new ink cartridge.
  1. Snap the lid closed.
  1. Lift the printer unit, and hold the scanner support up while lowering the printer unit until it is completely closed.
rcrtdrc1.jpg Aligning an Ink Cartridge You may need to align the ink cartridge when characters are not properly formed or are not aligned at the left margin, or when vertical or straight lines appear wavy.
To align the ink cartridge:
  1. Load plain paper. For more information, see Loading Paper.
  2. In Windows XP, click Start® Control Panel® Printers and Other Hardware® Printers and Faxes.
In Windows 2000, click Start® Settings® Printers.
  1. Right-click the Dell AIO 810 icon.
  2. Click Printing Preferences.
The Printing Preferences dialog box opens.
  1. Click the Maintenance tab.
  2. Click Align Print Cartridge.
  3. Click Print.
A blue and black alignment page prints.
  1. After the alignment page has finished printing, place the page face-down on the scanner glass. Make sure the upper left corner of the front of the page aligns with the arrow on the printer.
  1. Press the Scan button scanicoa.jpg .
The page is scanned. When the scan is complete, the cartridge is aligned. You may discard the alignment page when the alignment is complete.
Please download the manual from the link below and go to chapter Ink Cartridge Maintenance:
http://support.dell.com/support/edocs/systems/PRN810/en/ug/ug_en.zip
Hope it helped.
Nov 22, 2009 | Office Equipment & Supplies
I put new ink cartridge and is not printing
clean cartridge if you are not active print docoments then change printer head
Oct 31, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Won't print anything in black new ink
clean contacts on print cartridge and print head with alcohol
Jul 10, 2009 | Canon SmartBase MP360 All-In-One InkJet...
Not printing
If you are certain you installed the ink cartridge correctly then it sounds like the cartridge sensor has failed. This is fairly common with inkjet printers, give HP a call, it may still be under warranty:
800-474-6836
Jun 25, 2009 | HP DeskJet 6540 InkJet Printer
No ink on page
Clean the contact in the housing area and on the ink cartriage. If that does not work buy a new cartriage. The ink probably dried up in the nozzles. You can place the ink cartriage on a wet paper towel water or alcohal and press the cartriage into the towel. If you see no ing replace.
Jun 11, 2008 | Office Equipment & Supplies
Epson Stylus CX4800 All-In-One InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
