Question about Meade Autostar Telescope with Tripod
The read out is reporting motor problems... - Meade Autostar Telescope with Tripod
  • 3,186 Answers
RESET the hand controller, change the batteries to new ones, and do a Calibrate motors. Then you will need to re-train the drives and enter all the other setup data.
Posted on Jan 03, 2011
2000 Dodge stratus 2.4 started flooding all at once.P0117 code advance said was bad coolant sensor so disconnected it & still same problem.Changed plugs & they weren't wet just black.Any ideas ?
replace the coolant temp sensor as it reports engine temp to the ECM to set the mixture for combustion
by disconnecting it , the ECM is reading a cold motor and will enrich the mixture as if the choke is still on
it also reports when the coolant is at the correct temp and as it gets hotter tells the ECM to turn on the radiator fan
Feb 02, 2017 | 2000 Dodge Stratus
Smog fail 1997 honda civic,i need interprate
Use the internet to study Exhaust Gases related
to vehicle emissions
Then work on the causes of a particular gas that
is causing a high reading
You will need the report from the emissions center
with the gas readings, or your not working with much
You will need a pretty good understanding of motors
& several years experience to work on it's issues
Sep 26, 2014 | 1997 Honda Civic
What does E01 mean
this a problem with s.sensor. ERR1 indicates a speed issue. In this case, the motor speed as reported from the optic sensor differs
from the speed setting.
Analysis: Optic sensor signal issue -- Either the optic sensor signal is not right, or it is read incorrectly, or
the signal is not reaching the display.
Run the software calibration for easy diagnostic, and fix it.see the diagram attached, cleant the sensor with alcohol isopropyl 100% and tight the connector very well. see under the HOOD motor the instruction and follow the steps.
Nov 28, 2013 | Exercise & Fitness
Showing code e1
follow this steps and fix it. God bless you
ERR 1 - Motor Movement
Oct 01, 2013 | New Balance 2500 Treadmill
Nautilus T515/T516 treadmill stopped suddenly while I was running on it. I heard a snap right before it happened, so that made me check the belt, but that was fine. The screen reads E1 when I turn it on....
see the video and lube the deck belt. Use silicone or wax see your owner manual.
God bless you
May 30, 2013 | Exercise & Fitness
How do you Z out a 435dx
"Z" (Prints End-of-Day Management Reports and Resets Totals) - Prints the "Z" management report at the end-of-the-day and resets totals to zero (except "locked-in" grand total).
To print Management Reports, slide the control switch to the "X" or "Z" position as needed, then press the [amt tend/TOTAL] key. Refer to explanation starting on page 37.
"X" AND "Z" SALES MANAGEMENT REPORTS
__________________________________________________________________
Transaction data is maintained in the memory of the cash register as long as the battery back-up system is in effect. This data can be printed as a report for management review.
The Management Report can be printed from either the "X" or the "Z" position on the Control Switch.
"X" POSITION REPORT (Refers to a mid-day reading)
The "X" position report prints the accumulated information and RETAINS ALL TOTALS IN MEMORY. Use this position to print periodic readings of transaction information at any time through-out the day. (Some users call the X-report a mid-day report).
"Z" POSITION REPORT (Refers to an end-of-day or close-out reading)
The "Z" position report prints the same information as the "X" report. However, once this report is printed, ALL TRANSACTION TOTALS ARE RESET TO ZERO except the Grand Total. (Some users call the Z-report an end-of-day report).
NOTE: To prevent accidental printing of the "Z" report, set the security code as explained in the SECURITY CODE section.
Once this code is set, a "Z" report will not print until the security code is entered. If a "Z" report is attempted without entering the security code, the prompt "SEC Code" will appear in the display.
PRINTING THE SALES REPORT
IMPORTANT: Once a "Z" reading is taken, it cannot be duplicated, so be sure to have plenty of paper in the register.
1. Set the Control Switch to either the "X" or "Z" position.
2. Press the [amt tend/TOTAL] key.
NOTE: If a security code has been assigned, be sure to enter the security code before pressing the [amt tend/TOTAL]
key.
TO CLEAR THE GRAND TOTAL:
1. Set the Control Switch to the "prg" (Program Mode) position.
2. Type [2], type [0], then press [RA].
After this operation, the grand total resets to zero.
Oct 21, 2011 | Royal 435dx Electronic Cash Register
Casio te-100 register - our z-readings totals are on random days being added to the previous days totals and departments. How do I fix this?? I have made sure that z readings are being done, not x...
If you are doing the same report each time, it should never fail to reset. Find one that is too high, then check the REPORT BEFORE THAT ONE and make sure it was a Z report (has a Z at the top of the report). It still sounds like someone is taking an occasional X report by mistake and that will affect the NEXT report taken. --------------------------------------------------------------------------------------
If anyone needs more information, C-tech has the Casio TE-100 manual here: http://the-checkout-tech.com/manuals/cashregisters/Casio4.php
Jun 03, 2011 | Casio Parts Cash Register PC Desktop
Why i'm banned from Barbiegirls.com ? Please help me !
its easy ! i read the problem it might be a mistake like once i wanted to go on my account but it said there is no such username but i typed it correctly later, i sent them an email about the problem and it got fixed so just send them an email about it.
Dec 15, 2009 | Computers & Internet
Hard Disk Problem
That failure is predicted by the SMART reporting system. Its a status chip on the drive that reports to apps that can read the smart data from the hard drive. Its not always accurate but it usually is.
Time backup your data on that drive ASAP and then buy a new drive.
Sep 07, 2009 | Toshiba MK1637GSX 160 GB IDE Hard Drive
Optics Logo
60 people viewed this question
Top Meade Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Experi
Level 1 Expert
Greg Cann
Greg Cann
Are you a Meade Optic Expert? Answer questions, earn points and help others
