Question about Global Industrial Paperpro Prodigy Powered Stapler, /
I have a prodigy pro stapler. When I push the top lever the tenson has been lost. Can you tell me how to fix it. Can it be taken apart and the tenson reset?
My stapler won't wrap staples around the paper. What can I do?
Amazon.com : The Classics Staple-Free Stapler the "Paper ...
www.amazon.com/The...Staple-Free.../B000IGCUZE
Amazon.com, Inc.The Classics Staple-Free Stapler the "Paper Grip" with 5 Sheet Capacity, Kid Safe (TPG-133). by The ... Gift-wrap available. Enter your ..... It is hard to get the correct pressure on the paper--too much and it tears, not enough and won't fasten.
PaperPro Prodigy One-Finger Desktop Stapler, 25 Sheet ...
www.amazon.com/PaperPro...Stapler/.../B000GGY9L...
Amazon.com, Inc.
Rating: 4.4 - ‎399 reviews
Gift-wrap available. ... One-Finger Stapling Technology only needs one finger to stapleup to 25 sheets ... The Paper Pro Prodigy Stapler is the most distinctive, powerful non-elictric stapler available. .... This is such a great, easy to use, and quality stapler that once you use it, you won't want to use a ... A near-great stapler.
Swingline® Full-Strip Stapler, 15 Sheet Capacity ... - Staples
www.staples.com > Office Supplies > Office Basics > Staplers
Staples Inc.Stapler can easily handle up to 15 sheets of paper at a time and has ... refill this Swingline stapler with a full strip of standard office staples, so it won't run out of ...
Staples One-Touch™ Plus Desktop Flat Stack Full Strip ...
Jan 10, 2016 | Swingline 87845 Optima ® 40 Desk Stapler
How to take apart
Use a knife or small screwdriver to remove the little lock rings on one side of the stapler. DO NOT lose them With the lock rings removed, push the pins toward the other side of the stapler and remove them. Now the internal mechanism can be removed through the bottom of the stapler after you remove the staple "pusher" from the rear.
That's about as far as you can take that stapler apart.
Jul 28, 2014 | Arrow T50P ARROW STAPLE GUN
Help please! I have a Paper Pro high capacity stapler that will not staple. I can open it up and put staples inside, but no staple will come out when pushed down. Oddly enough, if I put ONE staple inside...
are you using the correct size of staple?? (thickness wise) secondly check the spring is pushing as it should, also a fix to get it working is as you put the staple stack into the stapler, seperate them and see if will staple. other than that it's defective and you should purchase a new one.
Oct 30, 2013 | Staples PaperPro 1200: Heavy Duty Stapler
How do you open/refill this stapler?
Push the top of the lever located on the back of the stapler.It will pop out on a spring. Slide a new strip of staples in and push spring/rod assemble back in until it clicks into place.
May 31, 2011 | Ace Hardware Ace Staple Gun
How do you add staples to a swingline 8784x stapler
You need to remove the black cap at the back of the stapler, then use a screwdriver to press down on a lever inside the stapler. The stapler holder will pop out at the front, then pull it further out and load with staples. May be an easier way, but this what worked for me.
May 20, 2011 | Office Equipment & Supplies
Does it come apart to empty the dirt?
There is usually some kind of lever that you push to release the dirt cup.
Since all models are different I can't tell where yours is at.
If you can't find it, read the manual. If you don't have a manual, ask your momma.
Look for a lever that says "unlock", or "unlock to empty" or "push to unlock" or "pull to unlock"
etc.
Feb 14, 2011 | Euro-Pro NV22 Shark Navigator Bagless...
The staples don't come out. I have taken it apart
Make sure that the driver blade is all the way up to top of travel (push driver up with thin tool). Load staples and check that the first staple moved into position by looking down nose. If the driver is all the way up out of the way of the path of the staples and staples do not move into place check of debris or wrong staples. If first staple is in position fire nailer several times. If only one staples then miss, driver is not returning to top. This is usually caused by poor seal at the bottom of cylinder, cracked lower bumper or piston orings are too tight or too loose. Good luck
Feb 27, 2010 | Stanley Bostitch STB-MIIIFS Flooring...
See above
317b762.jpg4a538aa.jpg067f3f0.jpg5077a62.jpgca392ef.jpge76904e.jpg77309d5.jpgThis is an older b&d stapler but the designs are similar in most cases. The position of the springs, and the order you put them in, are an obvious factor.
The parts that overlap go in after the parts underneath.
When you have one half assembeled you should not have to force the cover to go on, it should just sit in place while you put the screws back in.
If the handle coil spring and the flat spring are not seated properly the top cover will not go on easily.
These types of staplers are designed to clear from jamming without being taken apart, the staples, under normal circumstances, do not have access to the body of the unit past the flat spring.
As with any tool forcing the tool after a fault will only make matters worse, I would try some light oil or spray lubricant first before taking anything apart, these springs can be a pain to get back in, which is why I have not taken this one any further apart. Hope this helps you. If it does please let fixya know.
Regards
Les
Feb 02, 2009 | Black & Decker 5700 Powershot Forward...
PaperPro 1110 Prodigy metal stapler Has ceased up. How do you open the top to access the mechanism? thanks Gerard
My PaperPro Prodigy stopped firing staples. Examination of the hammer mechanism was fine. (apparently sometimes an internal part can break) Check with stapler opened and no staples. Hold the safety lock pin down with a fingernail or sticky tape so you can check operation of the hammer mechanism. Should withdraw to clear staple compartment and then fire. If this looks good, examine the roof of the staple compartment. Mine had a little lump of brown grunge in the roof of the staple compartment next to the hammer - stopping the staples from sliding up into firing line. Scraped it out and works fine again.
Apr 02, 2008 | Cell Phones
Global Industrial Paperpro Prodigy Powered Stapler, / Logo
623 people viewed this question
Top Global Industrial Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Global Industrial Office Equipment and Supply Expert? Answer questions, earn points and help others
