Question about Sharp XR-10X Multimedia Projector
How do I replace a sharp xr-10x lamp? do I need a technician or can I do it myself?
  • 8,197 Answers
Page 50 to 52 on the link below will tell you how to change the lamp.
http://www.infovideoproiettori.com/proiettori/sharp-xr-20x-manual.pdf
Good Luck
Posted on Jan 03, 2011
Problem with Sharp XR-10X The power light blinks red
According to the manual, a red blinking light indicates that the lamp cover is open. Try reseating the lamp and making sure everything closes up right. If the light is still blinking, it is most likely a problem with the projector itself and you may need to find out about getting it serviced.
Jun 27, 2011 | Sharp XR-10X Multimedia Projector
XR-10X/XR-10S - Can't find a way to open up the lid!
maybe your Sharp XR-10X are damage so you want to know what will you do??
Sep 17, 2009 | Sharp XR-10X Multimedia Projector
Sharp XR-10X/XR-10S - CAN'T FIND THE RESET BUTTON
Hi, I just opened my Sharp xr-10x DLP projector today, which had no power, no lights, no functions. A previous post worked for me...Remove the 6 screws on the bottom of the unit (you'll need a longer phillips) and the two screws on the back, toward the top of the unit. Obviously, be sure to keep these handy for reassembly (I have two curious dogs and a 4 year old to contend with). Then, to remove the housing...use a std screwdriver and slightly pry the cover off from the rear of the unit. This should losen allowing you to pivot the cover forward and then off from the projector lens. If you need to reset your unit, the reset button is near the lamp, not the lens (to the side of the lens). It is a small red button--depress this. Next, you can connect the ac cord and try powering up the unit. For me, I got a blinking red light but could not power up the unit. I then opened up the lamp compartment on the bottom of the unit (2 srcews) and remove the lamp. Next reconnect the lamp...when doing so, make sure the two prongs fit the lamp--this is the power supply. Then replace the lamp cover and retest the unit. At this point, my projector powered up as it used to. Finally replace the projector cover...from the lens then backward. Tighten all screws and you, hopefully will be ready to use the projector again.
Keep in mind, your problem may be the need for a replacement fuse or lamp. The fuse should be available at an electric supply shop or a Radio Shack store. I have seen replacement lamps for $190-$275 available online.
Good Luck...Hope this helps you out. As I said, I just completed this process myself today and am happy to have avoided the shipping costs and $65 diagnostic fee + labor and parts to have Sharp repair this. We are looking forward to 'movie night' on the 8' screen tonight! Hopefully, you'll be enjoying your projector soon!
Sep 16, 2009 | Sharp XR-10X Multimedia Projector
New bulb in now wont work - no power - wont turn on to reset lamp
first, make sure you have the correct lamp. the lamp for the xr-10x-l looks like the xr-10x, but the plugs are different (common mistake). make sure you have the AN-XR10L2/1, not the AN-XR10LP/1. to reset the lamp timer (with the projector plugged in but off), hold down the enter, down arrow, and menu buttons and press the power.
May 30, 2009 | Sharp XR-10X Multimedia Projector
XR 10 X with low brightness with new lamp
dirty. colorwheel probably coated and needs replacing.
Apr 07, 2009 | Sharp XR-10X Multimedia Projector
XR-10x bulb timer has timed out. How do I reset the projector?
you need to reset the lamp timer see http://www.ercservice.com/PDF/Lamp-Sharp-XR10-XR20.pdf
Cannot remove lamp assembly from Sharp XR-10X projector
flathead screwdriver under the lamp handle from the front and a sharp push down on the screwdriver handle (but don't break it) will dislodge it. it wedges in there pretty good.
Mar 27, 2009 | Sharp XR-10X Multimedia Projector
Projector shuts off sporadically
need to replace the lamp. i could have diminished not as much to frequent on and offs, but excessive dust. it's heating up too much and shutting down.
May 31, 2008 | Sharp XR-10X Multimedia Projector
Xr-10x
Hold "Down Arrow"+ENTER+MENU/HELP, then press STANDBY/ON. That will reset the counter if done correctly.
Nov 22, 2007 | Sharp XR-10X Multimedia Projector
Sharp XR-10X Multimedia Projector Logo
152 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
