Question about Del-Rain 1500-V 1500 Watt Ceramic Heater
The fan is operating on my Model 1500 V portable heater but no heat is coming out. Is there a way to replace the heating element? We are in the Scottsdale, AZ area if you have a service company that could repair the unit.
    Genius:
  • 1,015 Answers
Most of these heaters are not worth the price of repairing.You will spend more on labor then a new heater will cost. One thing you can try is to shut switch off on the heater and turn the thermostat to high then unplug unit for 10 mins. Plug back in and turn on. Some of these heaters will reset by doing this.It may not help but it costs nothing to try. Hope this helps you. Thanks
Posted on Jan 03, 2011
I plug my portable heater in nothing happens the light comes on it's a 1500 sunheater
Sounds like a bad element or bad t-stat. Not really worth fixing.
Mar 13, 2017 | Heating & Cooling
Can I buy a heating element for this heater?
On google
Patton replace heating element Heaters Questions ... - Fixya
www.fixya.com > Forum > Tags > replace heating element > Heaters
Patton heaters replace heating element related questions and answers. Ask yourPatton ... I can't seem to find a phone number for the manufacturer to call for parts. Any help? ... Question about PQH307UM Electric Utility Heater. 1 Answer ...
Patton PQH307UM Electric Utility Heater Quartz elements ...
www.fixya.com > ... > Patton > Patton PQH307UM Electric Utility Heater
Patton PQH307UM Electric Utility Heater, quartz elements replacement related ...Element. Where can I find replacement quartz tube heating. Element Infrared ...
Patton PQH307UM Electric Utility Heater Element ... - Fixya
Patton PQH307UM Electric Utility Heater, element related issues. Get free help, solutions & advice from top Patton experts. ... The heating element is above the thermostat, and all you will see is a round disc with two wires attaching to. Ad.
Patton PUH680-U Utility Heater Replacement fan motor ...
Jan 19, 2016 | Patton PQH307UM Electric Utility Heater
How do I clean my portable fan/heater?
Not sure what make and model you have got. Take the power cable out from the mains socket. Place palm of your hand on the front grill (when it is cold) and slide left and right. At some place you will notice enough movement towards one side. Push it to the extreme on that slide. This will usually release the bottom part of the grill. Lift up and take it out. Replace in reverse order after you clean it. Be careful not to dislodge the heating elements. If this is not suited to your model then please provide details of your heater.
Sep 11, 2014 | Heating & Cooling
Model PT 268 heater doesn't work at all but seems to have voltage
Yes it would seem that the thermostat or the knob would be the problem...when checking for voltage you need to check for 220v across the two terminals for the heating element. You will have 120 feeding back and forth all over the place but the fan and element will only work if they have 220... so you can have voltage and it still not work...
heatman101
Apr 23, 2010 | Patton Electric Patton PUH680-U Electric...
Main fan oven not heating
If the light and the fan are working then it is the heating element that has failed. You need to replace it.
Its not a difficult job but you have to take the back off the oven. The heating element is usually in a circular shape around the fan housing.
You have to disconnect the wires to the heater and remove the retaining screws, fit the new heater and reconnect. Remember to switch off the power before starting work
Jan 04, 2010 | Ovens
Rheem RHQA Heater:Blower works but no heat.
Is there a setting on the thermostat for Auto or Fan? If so, make sure it is in the Auto setting. You will have a contactor that turns on the elements and a relay for the fan. Follow the wiring diagram to see which relay energizes the fan then unplug it to see if the fan stops.
Nov 02, 2009 | Heating & Cooling
No heat or fan operation
24/7 Appliance Repair @ (608)214-5632 we are located in southern wisconsin, Thank You
May 26, 2009 | Marvin 3150 Mid-Size Heater
Need to replace part. Short-irratic off/on. Where can I get it?
theis is the safety swith that senses overheating. If the fanmotor cuts off and the heater elements don't, this switch will sense excessive heat and open the circuit for both the heater fan and the heater element(s). If it is "shorted" it is because it is cool and not needing to activate to interrupt the power. The problem I am having is that the switch opens prematurely after just a coule minutes of operation. the unit has to cool down befoe it wll cycle on again for just a few minutes.
Trying to find the part nubmer for the switch.
Apr 26, 2009 | Fahrenheat (FFH1614) Wall Mounted Panel...
Amana electric dryer will not heat/ LEA60AW Everything works fine but no heat...have cleaned all lint from inside the dryer by taking front panel off. What else should I check.... I noticed it wouild come...
Check for 220 Volt at the heater entrance to the heater box (accessible from picking up the top on most models). If you have 220v there the heater element is out. If you don't have 220v on the terminals of the heater the problem is in the controls. The fuse link, the timer contacts, the centrifugal switch on the motor, and the heater safety thermostat and operating (s), are all suspect and have to be eliminated 1 by 1. Hope this helps. With any luck all you need is a new element. Clean the duct out while replacing the heater if so because the main thing that causes heater element burn out is low air flow a kinked Dryer vent hose, lint, and plugged up fan on the motor are the 3 main causes of low air flow. If yours has little holes in the inside cabinet these can get clogged with lint also and cause a problem. Hope this helps and please rate me accordingly Thank you and good luck.
Feb 23, 2009 | Amana ALE643RB Electric Dryer
My Dayton garage heater model 2E636B does not heat up.
These heaters are the same as the marley heater, the element never gets red hot. the unit is set up so the fan kicks on after the element has heated to a certain temp and turns off after the element has cooled. It is common for these heater fans to cycle on and off quite often untill the air temp reaches about 55 degrees and then will operate normaly. If the fan still cycles too often you may have to replace the fan control and high limit switch. These are not very expensive and easy to replace yourself. they arte usualy attached to the back of the element with clips. The luke warm air is what these units put out. I have an equivelent to the dayton G73 and it heats a 24' X 30' garrage all winter in central Minnesota.
Nov 17, 2008 | Dayton G73 Utility Heater
Del-Rain 1500-V 1500 Watt Ceramic Heater Logo
151 people viewed this question
Top Del-Rain Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you a Del-Rain Heating and Cooling Expert? Answer questions, earn points and help others
