Question about Bushnell Trophy Cam with Text LCD
LCD info will not appear on set up mode.(no menu,no set up info,nothing) It worked fine until I connected to computer and copied photos. Batteries are good. (red light appears on front) Inserted new SD card write protect off (Sony 2G) Model 119435 Trophy Cam Brown Can you assist
  • Bushnell Master
  • 19,396 Answers
Hi.
Remove the batteries from inside the camera to reset it. If that does not work, then a short in USB contacts may have caused internal damage (USB carries +5V). In that case call Bushnell at the number in manual.
Removing batteries will usually fix the problem by draining power and resetting the cam. Restart the cam with no card after temporary removing batteries.
Here a manual.
Regards.
Ginko.
Posted on Jan 06, 2011
Acer model AT3201W no picture?? Sound is great, everything is connected tightly. Checked the manual ...no help..
There are several things that could be the problem, as usual. However I did manage to get a set working with the following characteristics:
- Set powered on ok and displayed the Acer logo fine.
- All of the inputs had very low brightness and poor colour.
- The backlight was working and appeared bright.
- The picture was barely usable with brightness/contrast set maximum.
I figured the issue here was a loss of the picture settings in the eeprom in the unit. So I set about to find how to get to the factory menu to set these things. This assumes you can get a menu to display on the set.
To enter factory mode on the remote control press menu/menu/234/menu. You will see the menu displayed with some info in the top bar that is normally not shown.
Then on the front of the TV press Volume- and Channel+ at the same time and hold until the factory menu appears.
You may see that the RGB gain and bias values are low or 0.
If that is the case set the colour temperature mode to Standard and then adjust the RGB gain and bias values to the following:
R gain: 434
G gain: 482
B gain: 484
R bias: 270
G bias: 270
B bias: 264
Then set the colour temperature to Cold and enter the following values:
R gain: 434
G gain: 482
B gain: 484
R bias: 270
G bias: 300
B bias: 310
Similarly, for Warm adjust the values to:
R gain: 434
G gain: 482
B gain: 484
R bias: 300
G bias: 280
B bias: 264
Then, if this was the problem, the picture should be fairly adequate.
Hope this works for you...
BTW I must give some credit here to another poster who provided a similar solution to a different problem here:
http://www.fixya.com/support/t154524-tv_losing_its_channel_memory
May 07, 2010 | Acer AL2671W 26 in. LCD Television
Viewsonic VP930b color problem - Red tint
Go to the setup menu on the LCD panel by pressing button 1 on the front. See if there is an option to reset the lcd to factory settings. Reset it and report if it helps not.
Jul 29, 2009 | ViewSonic VP930b 19" LCD Monitor
How to change resulution when you get input not
Try starting Windows in Safe Mode. During boot, before windows starts loading, just keep tapping F8, until a menu appears in which you can select Safe Mode. In Safe Mode, set the resolution to a safe, low value in the control panel. Then reboot normally, and everything should work fine.
Jun 07, 2009 | Acer AL1916W 19" LCD Monitor
Dell 924 all in one will not print magenta
run a nozzle clean, perform the following steps:
  1. Verify the All-In-One Printer 924 is powered on and connected to a computer.
  2. Verify that the paper support (input tray) has clean, plain white paper loaded.
  3. Press the Menu button.
  4. Press the Down button until Mode: Maintenance appears on the LCD screen.
  5. Press the Menu button.
    The Dell 924 Maintenance Menu appears on the LCD screen.
  6. Press the Down button until Clean Cartridges appears on the LCD screen.
  7. Press the Start button.
    The AIO 924 prints the cleaning page. This process cleans the ink cartridges and resolves many print quality issues.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 19, 2008 | Dell 924 All-in-One InkJet Printer
Setup help
To locate the bluetooth you need to set the bluetooth up into pairing mode. Do this by holding the button on the bluetooth till the ring turns purple. Then see if you can pair it to the phone.
Jul 24, 2008 | Motorola Mobility H700 Wireless Headset
Laptop LCD problem
hi, have you tried switching the screen mode, i think its FN button and F4, failing this you may have a faulty LCD controller chip, messy to fix unless you bring it some one who is repetable at fixing laptops...
Feb 19, 2008 | HP Pavilion dv6000z Notebook
Frozen digital screen
Set TV to standby and press Info, menu, mute then power. The set should turn on with the service menu available scroll down until you select reset press right hand arrow next to enter and then enter. TV will turn off. When switched on it goes into Plug and Play mode to reset the analogue and digital tuner. Allow a full reset then you should be ok.
Dec 21, 2007 | Samsung LE26R74BDX 26 in. HD-Ready LCD...
Print and copy comes out blank paper
mac,
please press menu then start black copy (blue button) then fortimes arrow-up (tel.index). machine will switch to maintenance mode and all buttons will flash. press 8 then zero then severaltimes start black copy until error A1
will appear on the lcd. repeat pressing menu nine times and write down the error codes. Plz post them here again.
To leave the mode press stop then 9 then 9.
Dec 06, 2007 | Brother MFC 420CN All-In-One InkJet...
SCREEN MESSAGE - MODE NOT SUPPORTED
You have set a resolution that is too high or incompatible with your monitor. I assume you are using Windows. Turn the computer on and immediately keep pressing F8 on the keyboard until the 'Windows Advanced Options Menu' appears. Use the Up and Down keys to select 'Enable VGA Mode' Press enter and your screen will work again when windows starts. Now go to the display properties and click 'Advanced' then click the 'Monitor' tab and tick 'Hide modes that this monitor cannot display' OK everthing and now you should be able to adjust the resolution without getting a blank screen again! Good luck and come back to comment soon. Regards
Sep 26, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
CheckMark On My 1-Gig Nano
Your iPod is in Disk Mode. Press and hold the menu and select buttons together until an apple appears. then it should be Ok. More info can be found here: http://docs.info.apple.com/article.html?artnum=93651
Nov 10, 2006 | Apple iPod nano
Bushnell Trophy Cam with Text LCD Logo
1,185 people viewed this question
Top Bushnell Home Security Experts
Lawrence Oravetz
Are you a Bushnell Home Security Expert? Answer questions, earn points and help others
