Question about Universal Remote Control MX-350 LCD Remote Control
Have a model Mx-350. Just got a Dynex 32" tv/dvd combo (DX-32ld150a11). Does anyone have the code for this unit so that I can program my Universal Remote mx-350.
  • 8 Answers
SOURCE: Program codes for tv and satelite.
https://fjallfoss.fcc.gov/prod/oet/forms/blobs/retrieve.cgi?attachment_id=305485&native_or_pdf=pdf
The manual
Posted on May 25, 2008
  • 12 Answers
SOURCE: mx 3000 universal lcd remote
There are 4 reasons why your unit is behaving this way:
1. Charger is the problem.
2. The docking station is the broken.
3. The battery is broken or not accepting charge.
4. The actual unit is the problem.
It is very hard to tell which one is causing this to happen.
Let us do some troubleshooting first:
1. Plug your charger in an A/C outlet and make sure the red power light (left) is lit, otherwise the charger or the docking station is broken.
2. You can test the charger with a multimeter. Unplug the charger from the docking station and measure the voltage across the outside and inside, it should register more than 5 volts DC. If there is a 5Volt DC the docking station is the problem otherwise the charger is broken.
3. If the red power light is lit and the status light (right) is lit too, your docking station is broken.
4. If the red power light is lit, dock the unit into the charger, the status light (left) should turn red when your battery is accepting charge or turn blue when your battery is fully charged.
5. If the status light will not lit at all (while the red power light is on), tap the screen while the unit is docked on the charger. If the unit will become alive, you need a new battery otherwise you need a new unit.
12 hours is very long time to charge, the status light should turn to blue in less than 2 hours especially for a new battery.
Posted on Aug 31, 2008
SOURCE: Cannot program Sony Blu Ray player w/ MX 500
I would suggest you use the learning mode and teach your remote from the remote that came with the Sony
Posted on May 03, 2009
savers2008
  • 286 Answers
SOURCE: My universal remote MX-880 just
It could be that the batteries have had there final charge and need replacing . Hope this helps.
Posted on Apr 14, 2011
  • 19 Answers
SOURCE: How do I program my mx-350 to run at&t uverse
Type this address into your "address bar" (long white bar on top of the internet explorer page)
www.universalremote.com/resources/pdfs/MX-350OwnerManual.pdf
Posted on Jun 28, 2011
Need remote code for Dynex 32" LCD HDTV 3 digit code model. DX-32L221A12
Rick, dynex TV codes at links below. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Dynex 32 inch Class LCD 720p 60Hz HDTV
Dynex Remote Codes
https://ca.answers.yahoo.com/question/index?qid=20081229074745AA4Jlgf
RCA Remote Code Search
Apr 25, 2016 | Dynex Televison & Video
Will my DX-32LD150A11 Play PAL DVDs?
No. It plays only NTSC discs.
Apr 21, 2012 | Dynex DX-40L260A12
I have the uiversal remote 3 control to prgram the DVD on my dynex tv 24 inch tv which has a built in dvd. None of the codes i put works help me please!
Not all universal remotes will have ALL codes available to program---they are truly NOT UNIVERSAL.
That remote just may not be able to do this.
Apr 11, 2012 | RCA 3-Device Universal Remote
I have a Dynex TV & a Dynex DVD player, Lost the remote to the DVD player but I have a PHDVD5 universal remote that I'd like to use for them both, or AT LEAST the DVD player. I just don't know...
TV code is 115
Will not find a code for the DVD player though. Im not sure which model you have, but Dynex will send you to MCM Electronics for original replacement parts, that is their provider. Check out www.mcmelectronics.com or give them a call at 888-235-4692 to see if they have your remote. Remotes for the models DX-DVD2 and DX-UPDVD2 are both listed for $4.99 plus shipping.
May 13, 2011 | Philips PH-DVD5 Remote Control
Dvd is stuck in the player ... DX-32LD150A11..
There should be a small, pin sized hole on the face of the DVD player. It may be hard to see, but it should be there and close to the eject button. This hole is the manual eject override. Turn the power to the player off, and slowly slide a paper clip or pin into the hole. The disk should start to come out. Once you have enough to grab, grab it and pull it all the way out.
If this does not work, the disk is jammed because it jumped off track. Something like this may require disassembly for removal and would most likely indicate the player is damaged.
May 09, 2011 | Dynex DX-LDVD19-10A LCD TV
Just need a remote control code for att uverse remote, for a dynex dvd player DX-UPDVD2
First, there is no such thing as a 'universal' remote, even the 'learning' remotes will not learn from every original remote. Second, for anyone to help you, you need to post both model numbers, the player's and the remotes.
Generally, if a remote is only even a little older than the player, it may not contain the code set for the player.
Dec 31, 2009 | Dynex DX-PDVD9 Player
Programming Scientific Atlantic remote to work with New Dynex TV
dynex is bestbuy's product try emerson, mine is working with emerson codes
May 12, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
Universal Remote Code for Dynex 20" TV/DVD
I just bought a 32" dynex lcd and saw that i couldn't program my two $5 ge remotes to work it. From reading in this forum and others I'm not the only one with the problem, I thought I was stuck with only the dynex remote. But the dynex website tells you how to get universal remotes to work,
It tells you to try the codes for Orion, Emerson, Memorex, Sansui, Sylvania, Zenith. The second orion code worked for me. both my ge remotes look and work the same but one uses a four digit code and the other uses a three digit code. I used 0135 on one and 135 on the other. There is a good chance that if you try the codes for the brands dynex lists you will find one that works. The 0135 or 135 might work for most dynex tv's.
If you have a ge remote and haven't programmed it for volume punch through you might try it. It allows the tv volume to be controlled using the ge remote even when it's set to something other than tv.
Nov 04, 2007 | Televison & Video
Universal Remote Control MX-350 LCD Remote Control Logo
Top Universal Remote Control Televison & Video Experts
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
