Question about Stiebel Eltron DHC-E 10
Blinking light on unit +shuts off completly for heating garage floor
Hot water heater keeps shutting off.
This sounds like a circuit board has a component that may be heating up and failing. When the unit is unplugged power is shut off to the circuit board, which will allow the component to cool down and start to work again. If this is the case then the component will fail completely at some time.
Dec 22, 2015 | Water Water Heaters
Unit will not turn off
If your light stays on after water is shut off, your flow switch is sticking. YOu need to replace the flow switch. If your light shuts off, but the unit continues to heat and trips your tco, then your element is bad and the unit needs replacing.
Dec 18, 2013 | Bosch AE-9.5 PowerStar 1.5 GPM...
Adjusting Apollo hot water tank
I am not sure what you are asking, But i am going to assume that you want to know about changing the Temp on the heater for inside the house.
If the floor heat was installed properly than it should have a temperture manifold or adjustable thermostat for seperate heating.
You need to find the thermostat or manifold for the garage heat and set it at what ever temp you want the garage to stay at.
Then you can change the A B C knob to a higher setting A is cold B is warm ac is hot. So Increase your temp setting on the heater and this will increase your house water temp for hotter showers and faucet temps. However, they recommend not setting the temp above 120 degrees to prevent severe burns.
If you have a newer home increasing the Hot water heater temp setting may not change the temp at the shower or faucets if you have scald guard faucets installed in the house. This will require adjusting the scald guard valves on each faucet.
I recommend using a candy thermometer or digital thermometer to check the faucet and shower Temp prior to using them and make sure that you inform everyone in the house after you change the temp so that no one gets scalded.
I hope this answers you question, feel free to contact me if you need more help!
DR Wilkins
Oct 15, 2013 | Water Heaters
No heat from heater
Copy following link to help identify water heater.
http://waterheatertimer.org/How-to-fix-water-heater.html
Add a comment and describe water heater in detail. Attach video with clear description.
If unit has blinking lights, then check product manual for error codes from blinking lights.
If unit is delivering no hot water, check for cross connections
http://waterheatertimer.org/Crossover.html
Call service technician and catch up on routine maintenance, such as cleaning water filter, etc
Jun 10, 2013 | American Heat ADK-2 - Electric 8.2KW...
Blinking red light no heat
It sounds like you are actually in lock out. Recycle is when during a call for heat, the flame goes out, the unit will try to restart itself. Hope this helps
Nov 10, 2009 | Water Heaters
PTG-74PVN Error Code -0 14 and LED on the controller board flashes 4 blinks every 6 seconds. Fan turns on few seconds after power up then stops. No fan, no spark, and no fire when water flows. Where can I...
code 14 is a big deal shut that thing down! you will burn it up if you keep running it, your over heat wrap on the heat exchanger is too hot. call rheem they can walk you through it
Aug 12, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
1 unit intermittently shuts off and other won't ignite
if you have the exhaust run together it will not light up,, they have to be seperate,, the computer board sences the unburnt gasses and will not allow it to start,,
Jun 24, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Heater
have service completed
Oct 24, 2008 | Rheem Water Heaters
Stiebel Eltron DHC-E 10 Logo
Top Stiebel Eltron Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Stiebel Eltron Water Heater Expert? Answer questions, earn points and help others
