Question about Desa International CCL3924PTA 24" LP Gas Log Heater
Martin Gas Logs Model 18TCP Lost Flame including Pilot and will not relight. What could cause this?
    Scholar:
  • 120 Answers
If pilot is there when it is depressed in pilot mode then the thermocouple is bad.if no pilot gas check for inlet pressure to log set
Posted on Jan 04, 2011
Light pilot light
Many heaters have pilot flames can be relighted with a match or push button operation. Many employ safeguards to prevent unburnt fuel from accumulating in the space or allowing an unstable pilot flame from "proving".
Most appliances have instructions printed or embossed on or near the pilot, gas valve or protective cover. It is very important to closely follow these instructions for your safety and that of others in the area. If you are unable to locate the instructions or follow them and relight the pilot, you should contact the gas company for assistance. This can be in indication of an issue with fuel, thermocouple, gas valve, etc., and would require a service person to correct.
I have included a link to a video to light a gas heater - yours may be the same or similar:
How To Light The Pilot Light On Gas Heater
Feb 23, 2015 | Heating & Cooling
Rayburn problems
if the pilot flame onto the thermocouple is 2 small [partialy blocked pilot feeder orifice] this will cause your described symptoms also flame 2 far from t/couple ! Tip of flame farthest from pilot burner should touch and slightly overlap tip of thermocouple
Dec 23, 2013 | Heating & Cooling
Pilot light wont stay lit on gas logs
If the pilot lite comes on, but will not stay on after it has had enough time to heat the thermocouple, you got a bad or the wrong thermocouple. It does take some time to heat that thermocouple.
Nov 26, 2013 | Woodland Direct CD Vent Free Gas Log Set...
I cant get my HRC200 gas fireplace logs to light.
the pilot flame must heat a thermal couple that develops a small voltage to open the gas valve. make sure the pilot flame is in contact with the thermocouple and hold the pilot start gas button on for at least 1 min befor turning it to the run position
Dennis
Nov 06, 2012 | Heating & Cooling
Pilot light won't ignite
Wait 30 minutes; press reset button. Repeat if necessary. 4. Pilot light out. 4. Relight pilot. 5. No gas. 5. Make sure gas valve to furnace is fully open. Not enough ... home.howstuffworks.com/how-to-repair-gas-furnaces1.htm
Just checked this site. I am sure you will find it useful - Good luck
Feb 07, 2012 | Heating & Cooling
45C- Flame and pilot went out during operation, Pilot won't relight.
If your pilot is a manual ignition model, make sure that the thermopile is clean (free of soot), it is the cylindrical piece of metal behind the pilot assembly which is heated by the pilot flame, a very small amount of voltage is generated by it to open pilot and main burner valves of gas valve.
Jun 03, 2011 | Pitco Frialator 45C Deep Fryer
Pilot light won't light on ventless fireplace
Ventless Gas logs, Vanguard, VS30PR. Propane gas
Pilot light stays lit various times, sometimes for several days then other times for a few minutes. Lights best when temp outside is below freezing. Pilot flame appears to receive too much air. How do you adjust the pilot flame? Is this done using two screws marked A & E? Do you have suggestions?
Thanks,
Ed
Jan 07, 2010 | Desa International Unvented Gas Space...
Pilot blights wont stay lit on older model American gas range
Take a very small wire and clean out the pilot holes. Then find the pilot flame adjustment screw and re-set your pilot to 1/4 inch flame.
Mar 24, 2009 | Kitchen Ranges
Vulcan freeloader hot water heater
Could be moisture in the gas supply line - get your gas fitter to purge the line at the meter.
Jul 08, 2008 | Heating & Cooling
Heating & Cooling Logo
204 people viewed this question
Top Desa International Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
