Question about Leisure HOMEPRIDE Electric Fireplace Heater w/ Remote
Where can i get a replacement motor for my electric fireplace insert model fl18-r I live in smith falls ontario
    Genius:
  • 1,015 Answers
You can try grainger.com and go to industrial motors with the model no.,h.p rating manufactures name and voltage. They carry a large selection and are good about service. Hope this helps you. Thanks
Posted on Jan 03, 2011
Tip
Flame Electric Fireplace Electric Fireplace Heat
Fireplaces have become the heart of the home, a warm place to gather with friends and family. Fireplaces turn any blank wall into a gorgeous focal point. A fireplace fits any decor and is a stylish addition to any room. Electric fireplace logs have improved greatly over the past few years and now days can look so good that they can fool people into believing that they are looking at a real fire, something which is especially true when you have crackling effect of fireplace logs, which aim to imitate the sound of a real fire.
Even though electric fireplaces do not generate flame, most provide the effect of a fire, which ranges from an orange light shined through plastic logs to simulate the appearance of coals burning, to an elaborate flame projection on the doors of some of the free-standing models. If you need a fireplace to heat your home you may want to consider a gas fireplace for better efficiency. If you need a fireplace for more decorative purposes a cheap electric burning unit might better suit your needs. The electric fireplace has experienced a quantum leap from those electric logs with reflective tin foil drums that adorned the hearth while the lava lamps were in vogue. An electric fireplace can add a great deal to a home, in terms of both form and function, and are also very effective at heating up a room.
Electric fireplace heaters simulate the look of a fireplace, but don't actually burn gas or wood like a traditional fireplace. Electric fireplace inserts simply fit into existing fireplaces and provide an artificial fire that creates the warmth and ambiance you want with just a flip of a switch. A modern electric fireplace insert does not require any type of venting system and many units are portable.
Even though these fireplaces do not generate flame, most provide the effect of a fire, which ranges from an orange light shined through plastic logs to simulate the appearance of coals burning, to an elaborate flame projection on the doors of some of the free-standing models. They plug into the wall, and can run on a "flame only" setting, or can be used as a heater, typically with 4,500–5,000 BTU (4,700–5,300 kJ), that can heat a 400 sq ft (37 m2) room. Since there is no real flame or combustion taking place, electric fireplace heaters release no toxic fumes or dangerous gases.
Everyone knows that a fireplace is about more than heat, especially when you're looking at a real fire, when one of the most entrancing things about it is the fact that you can see real flames. Most electric logs use a standard 110 volt power source, and come with various levels of flame of brightness. By choosing a really good set of electric fireplace logs, and particularly those which have a crackling effect and real flames, you can be assured that your fireplace will not be simply a unit in the room to make the room feel warm, but will be something that you enjoy looking at as well.
Electric fireside inserts are also a good option if there are issues with your hearth which make them a hazard with wood burning fires. Electric fireplace log inserts typically include an electric fireplace log set and an ember bed, and inserts are incredibly easy to install. Electric fireplace inserts are safe and clean. Most importantly whether you choose a modern electric fireplace or any other type make sure it will be most cost effective and suitable for its purpose in your home.
http://www.fixya.com/support/r3710316-portable_heat_flame_electric_fireplace
on Dec 24, 2009 | Heating & Cooling
Buck stove 27000 fan runs on low but when goes to high will shut down moved temp gage to front and rewired with harness won't fun on manual either.
Buck Stove ' Hearth.com Forums Home
www.hearth.com/talk/threads/buck-stove.45094/
Jan 6, 2010 - I replaced the blower motor. immediately blower would run for... ... Buck Stove 26000 insert (1982, in the living room fireplace) Has kept ... I throught the same thing so I fired the stove really hot, motor would not run past low setting and ..... I have a pre-1979 Regular Buck 27000 where the thermal disks are ... Anyone burn an insert without the surround?
Jan 8, 2012
Insert Blowers - to use or not?
Jan 3, 2011
Buck Stove Fan Noise
Dec 27, 2010
Any HVAC Techs or Electric Motor Gurus Here?
Nov 22, 2010
More results from www.hearth.com
Nov 08, 2015 | Cars & Trucks
How to install fireplace insert
need to consult a fireplace store or the project center at home depot/lowes..
Nov 12, 2013 | Smith AO Pool Pump Motor
How to replace my charmglow electric fireplace with a gas insert
Check your local building codes for restrictions. You MUST have the proper exhaust for a gas unit. There may also be flooring and wall requirements that need to be changed.
Jan 18, 2013 | Heating & Cooling
My rheem 50 gal water heater model 81mv52d keeps tripping the breaker, what do i need to do to stop this
Check all wiring at water heater and possible upper thermostat is bad, and in need of replacement.
Aug 15, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
I have a Amish looking electric fireplace, Model FL18-r, which has quit heating altho the fake flames still work. I am trying to see if the heater insert can be replaced, where and for how much, or...
There are a couple of reasons the heating unit part of the fireplace stop heating. A dust and lint build up in the heating coils can cause them to burn out. The heater overload circuitry has shut the heater down or has failed or the unit needs to reset. so lets go to the easiest thing for you to do, yourself.
RESETTING THE HEATER
Turn the Master ON/OFF Switch to OFF. Unplug the fireplace and wait 12 - 15 minutes before plugging it back in. Then turn the Master ON/OFF Switch to ON. Turn ON each individual function of the fireplace, one at a time. If the unit was able to reset itself, each function should work normally. If it doesn't, then one of the issues I listed above is the problem.
If your fireplace is less than one year old, it should still be under warranty. So contact the manufacturer (you can find the contact info in your Owners Manual) about repair or replacement.
One personal aside: None of the electric fireplace/heaters on the market today, have a long trouble free life span. Usually, it's 9 months to a year, when consumers start having problems. I sold these type of appliances for a couple of years, as an adjunct to our gas fireplace and heater business. When they started to become a problem for our customers, we quickly realized, that no matter who the manufacturer is/was, they are not what they are touted to be and we discontinued selling them. It's been 4 years since we discontinued selling them and apparently, nothing has changed in their manufacture. As, I answer more than my share of questions about them, here on FixYa. As one person told me, "I wish I had bought a vent-free gas fireplace instead. It would have cost me more, but would have been more reliable and would still heat, even if the power was out."
I hope this helps you trouble shoot and solve the problem.
Happy Easter!
Apr 23, 2011 | Heating & Cooling
Twin Star electric fireplace fan (maybe heater) doesn't work!
I have a twin star electric fireplace insert model #28efo24grs that is missing a remote any suggestions >>>>917-747-4893
Dec 13, 2009 | Kitchen Appliances - Others
Electric fireplace does not heat
I have a cheap electric fireplace bought in SuperCentre store-heater no longer works. It says its a one piece system. Can these heaters be replaced or repaired(probably made in China) or am i better off scrapping it and buying a new one?
Oct 15, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Heating & Cooling Logo
371 people viewed this question
Top Leisure Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Colin Stickland
Colin Stickland
Are you a Leisure Heating and Cooling Expert? Answer questions, earn points and help others
