Question about K-Tec Kitchenetics K2 Stand Mixer
I broke the food pusher on my old Gourmet Champ food processor attachment and want to know if it can be replaced.
Do you sell parts for my Kitchenette Gourmet Champ k-11 I need to get some parts for my mixer
no
fixya site does not do parts
go google and type in- parts for kitchenette gourmet champ k-11 mixer ---
go to a retailer that sells the brand and get the service agent name and get parts from them
Jan 22, 2017 | Food Mixers
Why wont my food processor work?
[PDF]Food Processor - Cuisinart
https://www.cuisinart.com/share/pdf/manuals/dlc-xp.pdf
CuisinartDough blade, metal chopping blade, 3 slicing discs, shredding disc, detachable stem... food processing technology plus the largest work bowl on the consumer ...
[PDF]Download Manual - Cuisinart
https://www.cuisinart.com/share/pdf/manuals/dlc-10s.pdf
Cuisinartwork bowl, cover and pusher ... The work bowl won't come off until the ..... DOUGH.BLADE. 12. The Pro Classic1" Food Processor can mix and knead dough in a.
[PDF]INSTRUCTION BOOKLET - Cuisinart
https://www.cuisinart.com/share/pdf/manuals/fp-12dc.pdf Cuisinart12-Cup Cuisinart Elite Collection® 2.0 Food Processor FP-12N Series. For your ...RECOMMENDED MAXIMUM WORK BOWL CAPACITIES ... dough blade, adjustable slicing disc, reversible ...... immediately after use so food won't dry on them ...
[PDF]Premier Series 7-Cup Food Processor DLC-2007N - Cui
Jan 01, 2016 | Cuisinart Dough Blade Plastic for DLC-2014...
Kitchenaid food processor, motor rotates but when blade is inserted it won't rotate
It will be something in the mechanism that activates that switch in the base. It is more common for the fault to be in the lid but it is not so uncommon for it to be the bowl. You are using the pusher aren't you? That's the mechanism activator. This information is relevant to the wide mouth model.
Jul 30, 2014 | KitchenAid Food Mixers
Food processor assembly
I'm going to take a guess that you can't get it to work....tell me if I'm wrong. The biggest mistake people make when assembling their food processors is putting the bowl on backward. It will not run if the bowl is on backward. The handle on the bowl should face the front of the base. Once you click that into place, put the blade on, then lid and lastly the pusher. For safety reasons, all of that has to be in place for it to work.
Jul 18, 2012 | Cuisinart DFP-3 Handy Prep 3-Cup Food...
English manual Kenwood Gourmet FP101
This will cost 2.95 GBP
http://www.belstar-electrics.co.uk/products/Kenwood-FP101-User-Manual.html
or register free at
http://kitchen.manualsonline.com/support/kenwood/blender/please-help-find-the-manual-for-this-kenwood-food-processor-11218
Jun 02, 2012 | Kenwood Food Mixers
Kitchenetics The Gourmet Champ K-11 replacement parts
Kitchenetics The Gourmet Champ K-11 replacement parts can be found at amazon, click here and take a look: Amazon com kitchenetics mixer. I hope this was helpful. Cheers
Apr 06, 2012 | K-Tec Kitchenetics K2 Stand Mixer
First and second gears seem stuck
You most likely broke a keyway on page 14, item 36.
http://www.hobartlink.com/extranet/extranetmanualsandcatalogs.nsf/57866D624A678E7385256CB0007232DA/$File/F-19357%20(05-95).pdf
The unit is filled with grease, and is not as easy as it may seem. Being that a grease change is likely needed, it's about three hours work for a trained tech.
Jun 25, 2008 | Hobart A200 Stand Mixer
Replacement parts for K-Tec Kitchen Machine
I just talked with Blendtec about this issue, since I had the same problem. I asked if there was a stronger drive shaft since my previous Kitchen Champ model had a different, sturdier drive shaft that lasted about ten years.
The company representative explained that the new drive shaft is designed to break, but that's to save the motor. If the stress on the drive shaft could damage or cause excessive wear to the motor, the drive shaft breaks instead.
She also recommended using just enough flour so that the bread dough pulls away from the sides of the bowl. The reason most drive shafts experience too much stress is due to too much flour in the recipe.
To replace the drive shaft, go to http://www.blendtec.com/Parts.aspx or call Blendtec at 1-800-Blendtec
The only part that will work for the Kitchen Champ is the Drive Shaft (Champ). Apparently, the German drive shaft -- which looks like the one from my old Kitchen Champ -- is not interchangeable.
Since this is my second Kitchen Champ and my previous one lasted over ten years, I'm delighted to understand what went wrong. I'm hopeful that using less flour will prevent another problem. And, I'm very pleased with how helpful Blendtec was, explaining this to me.
Dec 25, 2007 | K-Tec Kitchenetics K2 Stand Mixer
K-Tec Kitchenetics K2 Stand Mixer Logo
59 people viewed this question
Top K-Tec Food Mixers Experts
eyecam
Are you a K-Tec Food Mixer Expert? Answer questions, earn points and help others
