Question about Teac Audio Players & Recorders
I tried to dub a tape; I put the original tape on the left and the blank tape on the right side; original tape got wound around a spool. Happened each time I tried to copy the tape. Help.
    President:
  • 624 Answers
That's because the take up reel is not turning, sometimes it is because of a bad belt. No way to be 100% certain without looking at it myself, but that is most common. If you check it out yourseld, be sure to get the proper belt and it is put on the right way or you will continue to have problems. Sometimes it is a good idea to have it looked at by an experienced technician. This would ensure that it is fixed properly.
Let me know if I can be of more help.
Dave
Posted on Jul 09, 2008
I have a Fisher RS636 receiver. I can't seem to record from "Tape 2 to Tape 1" or from 1 to 2. I don't have a remote. Will this be a problem? Can you guide me through procedure. Do...
Most receivers have a dub switch and it would still be in one direction only, say Tape 1- >> Tape 2. Lacking a dub switch the Tape Loops are in an order like that so monitoring the one upstream of the other allows the second one to see it as a source.
Aug 22, 2011 | Audio Players & Recorders
Need to hook up a Realistic model 31-2000 equalizer to a Yahama receiver.
Be advised that the engagement of any device in a Tape Monitor loop on a late-model Audio/Video Receiver will effectively tie the receiver down to stereo-only analog sound reproduction. I'll explain.
The connections themselves are fairly simple but it pays to understand what happens in the loop.
In general, any Line-Level external processor (EQ, dynamic range expander, etc) will go into a Tape Monitor loop on a receiver. A Tape Monitor, when engaged, sends the stereo analog signal Out to the Processor, massages it and returns it to the receiver via the Tape Monitor IN connectors to be passed on to the receiver's internal processes (volume, tone, whatever).
Old school analog stereo-only receivers consistently work this way. Newer digital and audio/video receivers introduce a couple of problems: 1) digital sound processing to simulate a variety of soundfields; 2) multiple output channels, either discrete or digitally-generated.
The latter requires that whatever signal is being processed experiences a maximum of one analog-digital-analog conversion.
EVERYTHING analog coming into the modern digital receiver is automatically converted to a digital signal for internal processing unless you choose a STEREO-only or STEREO-Direct setting. Consequently, no further external analog-digital conversions would be allowed if, say, a Tape Monitor circuit was activated, and a possible feedback loop could otherwise be created in a digital-sourced selection (output to its own input), so the unit is wired to treat the Tape Monitor as the first analog step in the process and defeats any pure digital sources.
In a multichannel unit, what would happen to the other channels if you sent ONLY the Front Left & Right out for processing? They would NOT be processed. That logical problem also plays into the decision to defeat digital sources if the Tape Monitor is activated. I don't totally agree with the engineers but that's the way it is. Nature of the digital beast.
Okay, back to the hook-up: Receiver Tape- or VCR Out to the External Processor (EQ, whatever) Preamp-, Amp-, Tape- or Rec-In; Receiver Tape- or VCR In from the External Processor (EQ, whatever) Preamp-, Amp-, Tape- or Rec-Out.
So, to sum up, you can only use the EQ for analog stereo sources. If you actually want to use an analog recording deck you could place it within the typical Equalizer's own Tape Monitor loop(s). Many have two to facilitate equalized dubbing between decks.
[Or you could obtain a dbx Program Route Selector (check eBay, I highly recommend the 400x, of which I have two) and it would, while only using one receiver Tape Loop, allow for three discrete attachment paths for processors and three for tape decks with the added flexibility of front-panel selection of any and all, with the processors being before, after or between the source or tape decks. Plus it has a dedicated facility for an inline dbx Noise Reduction Processor that can also be juggled around via pushbuttons. Pretty neat.]
Jan 17, 2011 | Audio Players & Recorders
Forgot how to record (dual) tape to tape (been a while)......can not remember sequence of buttons to press or if i need to press buttons at the same time (i.e. Trying to record 1 cassette tape to another...
The left side is usually the playback deck and the right side is the record deck.put in a tape on the left side and push play.Then push the record button first and while holding it down ,the play button on the right side deck.One deck will not have record buttons on it,and that is the playback deck.
Jul 09, 2010 | Audio Players & Recorders
Hookup
If ur using it for cd player u take the Right Out an Left Out put it in to Eq Right In an Left IN An next to it there is Right Out Left Out an to the reciver you put Right In an Left In Do that with dvd,tape....
what ever it is your trying to hook up
Right is Red
Left is White
Oct 15, 2008 | Onkyo HTR500 Receiver
DEAD LEFT CHANNEL!!
The most common problem is a dirty record<>play switch inside the unit. Try this: Using a blank tape, press and release record/play buttons several times. This can clean the switch a bit. Then play a tape. If it fixes the problem, then you need to take the unit apart and use a plastic safe spray cleaner on the switch (Check at Radio Shack, their tuner cleaner Catalog #: 64-4315 will work fine). Spray it into the switch and then work the switch with the buttons several times.
Hope that helps...
Geno
Apr 04, 2008 | Audio Players & Recorders
Kenwood KX-W6080 dual stereo cassette tape deck
I have the same unit which had the same problem. It has to do with dirty contacts on each tape mechanism.
Remove the main cover and look down on each tape mechanism. You will see 4 contacts on each unit. These come in contact with the tape. Remove each unit by removing 4 holding screws.
You will now be able to spray some contact cleaner into the front of the plastic contact cover. I removed the covers on both of the second from the right contacts so that I could clean them with an abrasive. These are the main ones.
Put everything back the way it was and the tape deck should work great.
Mar 24, 2008 | Kenwood Audio Players & Recorders
I Have a Teac W525R double auto reverse cassette deck and I cant dub from ;Play (left sd) to Rec. (right sd). What gives? I push rec then play on the other side and the rec stops. Then I tried the other...
Don't do either of those things. Just hit one of the DUB START buttons (NORMAL OR HIGH) Located right under the tape counter. The deck does the rest.
Feb 19, 2008 | Teac Audio Players & Recorders
Sound not coming from left side surround sound speaker or my right side front speaker
it is highly likely that you're TV is outputting mono sound, hence the left channel only. check your physical connections to the TV and the balance / channel volume on the television as well.
May 01, 2007 | Onkyo HTR500 Receiver
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
