Question about Vacuums
I would like the manual for the Sanyo Super Quick Charger
I am trying to change the bag on my sanyo transformax 3in1 vac, cannot open it how do i open it?
This video may help you. Also you might find the manual at this site: http://homeappliance.manualsonline.com/manuals/mfg/sanyo/sc15m.html
Nov 16, 2016 | Sanyo Vacuums
I cannot get it to recharge. I have tried all the outlets in the house and the red light goes out and it never get recharged no matter how long I wait.
Betty,
It could be either the charger or the battery pack inside the vacuum. The only way to really tell would be to have it checked with a multimeter to see if the charger was working or not.
Jun 11, 2015 | Dirt Devil M0896RED 9.6 Volt Quick Power...
When I put the battery on the charger the light on the charger stays on for little awhile the it starts to blink, but when I try to use the battery it is not charged. So I am not sure if I need a new
Hi there! It sounds like you have our Linx stick vacuum or hand vacuum model. Plug only the charger into an outlet, the blue light on the charger should flash once. If the light on the charger flashes once then the charger is fine. Try resetting the battery by following these quick steps below.
1. Remove the battery from charger or cleaner
2. Unplug the charger
3. Insert the battery into the vacuum and turn the unit on for 30 seconds (even if it has no power)
4. Remove the battery
5. Plug the charger into an outlet, make sure the light on charger blinks blue once.
6. Insert battery into charger
The light should be a solid blue, indicating the battery reset worked. If so, allow the battery to charge for 3-4 hours, completely deplete battery on your next use and re-charge. If the light on the charger is still blinking, your battery will need to be replaced. I have included a link where you may go to purchase a replacement battery if needed. Hope this helps!
Search Results
Sep 21, 2014 | Hoover Floormate H3000 Upright Wet/Dry...
Sanyo sc-s260 user manual
I want to clean my vacum cleaner, How i can open my sanyo vacum cleaner model: sc-s260
Dec 26, 2013 | Metropolitan Vacuum Cleaner Vacuums
Dirt devil doesn[t hold charge
Try running the battery all the way down by letting the vacume run in a corner or another room and even when it stops leave it on for a hour to drain the battery. Then shut the switch off and try charging the battery. Make sure the charger is putting out enough volts by looking at the rated output of the charger and while it is plugged in check it with a volt meter. If it does not hold a charge and the charger is putting out the right voltage you need to purchase a new battery for the vacume
Mar 18, 2011 | Dirt Devil Easy Lite Quick Vacuum
We have been given a super showerwave microwave and need an instruction manual can I get this on line?
First try http://kitchen.manualsonline.com , but you'll need the model number.
Also try calling Sanyo Fisher service. Sometimes they offer it for free.
800-421-5013
Monday - Friday, 7:30AM - 5:00PM PST
Sep 26, 2010 | Vacuums
Recently I purchased Sanyo Eneloop NC-MQN04ES Charger. I need the user manual for this charger. How many hours does it takes to charge 4 aa and aaa Batteries. I charged it for more than 6 hrs. But the led...
This is from the user 's manual i just copy paste it
Specification: Voltage : AC 220V - AC 240V,
Input : 50/60 Hz 6W,
Output : DC 2.4V 220-280mA x2 (AA),
100-140mA x2 (AAA),
LED indicator : ON - charging OFF - Timer off (approx 16hours) Battrey/Charge Time Approximate Hours :
-Eneloop Ni-MH AA (typ 2000mAh) 10(h),
-Eneloop Ni-MH AAA (typ 800mAh) 8(h),
-Ni-MH AA (typ 2700mAh) 13(h),
-Ni-MH AA (typ 2500mAh) 12(h),
-Ni-MH AA (typ 2100mAh) 10(h),
-Ni-MH AA (typ 1700mAh) 8(h),
-Ni-MH AAA (typ 1000mAh) 10(h),
-Ni-MH AAA (typ 900mAh) 9(h),
-Dimension : 118 x 75 x 40 mm
Jul 03, 2010 | Vacuums
Pulse Bagless dust press system vacuum cleaner I need to download the instruction manual
Dear Customer
please check the following link for
Sanyo Instruction Manual Upright Bagless Vacuum Cleaner SC-150, SC-180
http://homeappliance.manualsonline.com/manuals/mfg/sanyo/sanyo_upright_bagless_vacuum_cleaner_product_list.html
please rate this,Thank u
Dec 16, 2008 | Sanyo Vacuums
Possible broken belt..brush doesn't turn on Sanyo Revo SC TA3000 vacuum. Cannot find manual.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=748077
Generic problem for all Vacuums
Possible broken belt. Brush doesn't turn
Posted by Helene on Jul 06, 2008
Possible broken belt. Brush doesn't turn on Sanyo Revo SC TA3000 vacuum. Cannot find manual.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. You can contact the Sanyo factory phone # and or your local vacuum cleaner dealer for the belts. But the owner’s manual you would have to contact the Sanyo factory @ the phone number provided below. If you have further questions please feel free to contact your local vacuum cleaner dealer in your area, or contact the Hoover website and or the cust serv phone # @ Hoover listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://us.sanyo.com/appliances/vacuum_cleaners/
Customer Service – Go to the Contact Us page and fill out the email request
The Service Center Cust Serv Line 1-800-421-5013
Monday thru Friday 7:30 AM to 5:00 PM (PST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 06, 2008 | Vacuums
Vacuums Logo
104 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
