Question about RCA L32HD31 32 in. LCD HDTV
Suddenly my remote no longer communicated with the tv. I replaced the batteries in the remote. Still no communication. I can operate the tv with it's buttons, but the remote has no effect. Is there any way to tell if it is the remote that is broken, or the tv?
  • RCA Master
  • 8,457 Answers
The Infer Red eye sensor is on the tv manual control buttons PCB board.The manual control buttons are on the tv right side on the tv frame bazel,tv facing you.Test all the manual buttons like power button,channels + -,Menu button and input button.All the manual buttons work,than the remote control is problems and the causes.The remotes devices are heaviely depend on it CPU chip.The remote CPU is short or dead,if everythings buttons on the remote completely dead or will only partially functions.The remote is garbage,remote CPU is dying.Try website like Remotes.com to buy an original remote or very close to it.
Posted on Jan 03, 2011
Why doesn't remote control communicate with Fischer heat pump mini split system
It sounds like the batteries leaked and oxidized the terminals. If you cannot get them clean enough then I would suggest getting a new reomote from the manafacturer.
Aug 24, 2014 | YMGI R410A Ductless Mini Split 16 SEER DC...
I changed the video input on my memorex tv and I'm not sure how to change it back without the remote
Use the menu button to get into the set's menu and try to program without a remote----failing that GOOGLE the model number to locate a new remote.
Mar 17, 2012 | Memorex Televison & Video
My remote control does not operate my GVA TV, the batteries are good, the pair (remote/TV) just do not respond at all, no matter what buttons are pushed.
If new batteries did not fix the problem, then it means the problem is either from the remote or the TV.
Remote: Check the remote battery terminal, see if its not rust. Also, disassemble the remote, can check the connection between the terminal and the remote board, see if there is no disconnection of any kind.
If after checking and all seems well, then it means the remote is defective. To confirm, borrow a remote, test it with the TV. If it works, then it means you need to replace your remote. But if the remote you borrowed does not work, then it means the problem is from the TV and not the remote.
TV: There is a sensor in the TV that communicates with the remote. If this sensor is defective, the remote won't communicate with the TV.
The TV sensor might have loosed contact from inside of the TV or it maybe defective and need to be replaced.
So do the above troubleshooting and let me know if the problem is from the TV or remote. If problem is from the remote, you need to do a replacement. But if otherwise, let me knows as well.
Good luck.
Jan 11, 2012 | Televison & Video
The remote control sensor on the TV has stopped working
Regards.
Jan 09, 2012 | Televison & Video
The tv remote for the vizio Vo47L is no longer working. trying to reprogram it so that it works. The battery is fine and it lights up when i push buttons but it does not control the tv anymore?
Try holding down the <P>, <Q> and <SPACE> buttons down together for 5 seconds.
This often restores the communication link between the remote and the tv.
May 17, 2011 | Vizio VO47L 47 in. LCD TV
Remote does not communicate with TV. Battery connector is loose.
Hi,if the remote was working perfectly before now with the TV,it means the problem is from the battery of the remote control,you have to replace the battery and ensure they are well inserted in the right positions. However,if you have done this and the problem remains,you have to unscrew the cover behind the remote and check the connection between the sensor and the panel,if the connection is broken you have to solder the sensor back to the panel.
Thanks and take care
Apr 21, 2010 | Sony RMT-V402B Remote Control
Sony TV no longer responds to Harmony remote
try using some rechargeable batteries. they tend to have more miliamps and last longer.
Jan 14, 2009 | Logitech Harmony 670 LCD Remote Control
RCA remote not communicating with the TV
Stupid question; have you replaced the batteries?
You can probably get a downloaded user guide from here:
www.safemanuals.com
www.retrevo.com
If those fail, try the RCA (Thompson) website.
Jul 19, 2008 | RCA T20TF667 20 in. TV/VCR Combo
Not receiving commands from the remote. (Panasonic Panasonic CT-34WX54 HDTV)
Sometimes remotes have a switch to select tv,vcr,or cable,amke sure the remote is in the tv mode,other than that rare but remote receiver go bad and they have to be replaced,but before you call for assistance make sure the remote is communicating with the TV.It could be still good with other devices and not with the set.
Sep 27, 2006 | Panasonic CT-34WX54 34" TV
RCA L32HD31 32 in. LCD HDTV Logo
373 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
