Question about Hotpoint Washing Machines
Hi i have an ultima wmd 940 hotpoint washing machine !! i have a split in the plastic piece which supplies water from the inlet to the tray!! what is this piece called and were could i get a picture of the machine to make sure i get the right part many thanks
  • 472 Answers
A few sites yu can get on and actually type your model number and see the part you need are as follows:::
www.repairclinic.com
www.apdepot.com
www.sears.com
you should be able to type your model number on these sites and locate your part.
Posted on Jan 03, 2011
Hi - I have a hotpoint wmd 740 ultima washing machine and have an error telling me to check water supply. The hose is fine, water pressure checked etc but the manual suggests it might be the inlet valve...
I don't know exactly where it is but it has to be early in the line. Follow your hose to the first component it goes into. That is where I would start to look for a filter. I am betting it is probably some sort of a screw on filter right on the first component you come across. It is not there just keep following the trail. You will have to take off the back on the unit to trace.
Jan 31, 2015 | Hotpoint Washing Machines
My washing machine hotpoint ultima wmd 940 is dead no power ,but the fuse in the plug is ok.
the mains lead normally goes to a connector block at the top of the machine then onto a mains filter both of these can fail ie burnt out connections ect check these out first remember to un-plug machine first
Nov 10, 2014 | Hotpoint Washing Machines
Hotpoint ultima wmd 940 program counts down but machine not working
Good afternoon
Your washing machine has more difficult problems than I have met before.
The only thing I can advice you is to get an electrical expert from
a shop that specializes in your type of machine.
Whille you are waiting you could browse on the internet and look at MANUALSONLINE.COM
kolbrun
Feb 26, 2012 | Washing Machines
Wmd 960 ultima switches on prog select ok but then does nothing - no whirrs or sounds of water going in - water available
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Aug 10, 2011 | Hotpoint Ultima WF860 Front Load Washer
I have a Hotpoint WMD 960 Ultima. When I remove the washing after a cycle, the clothes are covered in dirty marks. can you tell me if this is something you can advise me about?
Look within the drum and observe if there is any dirt on it. Also check the quality of water. Check if there is any dirt /grease from the drum bearings due to failure of the bearings/seals.
Finally have the machine cleaned using good detergent cleaner , please check the link below for some tips:
http://www.espares.co.uk/parts/cleaning-products/dishwasher-cleaning/p/1423
Jul 09, 2011 | Hotpoint Ultima WF860 Front Load Washer
Hi, i have washer / dryer "Hotpoint Ultima Super silent WD860" with an error code F13 when trying to use the dryer Please advice Thanks
Check the water supply, inlet valve, and hot & cold hose connections.
Got this piece of advice from their site..
Hope this helps.. :)
Jun 10, 2011 | Hotpoint Washing Machines
Hotpoint wmd 960 ultima,when press start button nothing happens apart from the clock starts count down to end of wash
if water starts but drum dont move.............
check the rear belt....if that is on then the motor needs new brushes............
easy fix ........... about £12 diy
cheers
Mar 22, 2011 | Hotpoint Washing Machines
Hi i got hotpoint ultima igot flashing h20 on screen
These are the notes I have-
Providing it is not in demo mode, H20 means 'no water is being supplied'.
Press and hold 'start/cancel', release then press again to cancel the drain. The machine should now be reset.
If H20 returns there is a problem with the water supply- the hoses are kinked or squashed, the taps are not turned on fully or the water inlet valve is malfunctioning, apparently!
Good luck,
John C
Mar 11, 2011 | Hotpoint Ultima WF860 Front Load Washer
Wmd 940 wont fill,, water pressure ok,hose ok,f01
Solanoid. does it fill on any other programe. try hot wash, then rinse
Feb 01, 2010 | Hotpoint Washing Machines
Washing Machines Logo
64 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
