Question about Maytag Microwave Ovens
Microwave mod# MMV4203DQ00 - turn table does not turn
    Brigadier General:
  • 8,909 Answers
Sounds like the motor is faulty.
Replacing the turntable motor.
The motor assembly is fixed to the base of the oven usually with two screws and access i obtained by removing the inspection plate directly beneath the motor. It is usally a plug in synchronus motor that revolves at a few revs per minute but the plastic cogs in the motors gear box fail and the motor assembly must be replaced. They are fairly inexpensive and obtainable usually from a domestic appliance repair shop.
If you feel confident, disconnect it from the mains power, remove anything in the cavity and turn it upside down if it is a tabletop model, a little more complicated if it is built in!
Remove the inspection plate and disconnect the motor. Remove the motor and go and get a new one. Re fit it and put the microwave back in its position. Plug it back in, with the turntable and plate. Put a cup of water on the plate inside of the oven and heat for 20 seconds to check the plate goes round.
Hope this helps.
Posted on Jan 03, 2011
Whirlpool microwave mod: wmh76718as0 no power to the turntable. Motor is good, fuse ok, all other functions ok. Bad control board?
check that the turn table is not belt driven underneath
it is like a rubber band and they do break
Jul 06, 2016 | Whirlpool Microwave Ovens
MY TURN TABLE IS NOT TURNING AND MICROWAVE NOT HEATING
the motor for the turn table has broke and when it doesnt turn it wont heat?needs new motor or new microwave
Apr 07, 2016 | Microwave Ovens
Why is my turntable not turning in my microwave oven?
Is your microwave clean under the table? No stuck on food or anything? Does the the oven work without the table?
Does the little prop in the centre that turns the table move when there is no table on it? Try to carefully clean it and see if that helps.
Feb 17, 2015 | In Microwave Ovens
Fix a kenmore microwave turn table model 721.80012401will not turn
http://www.ebay.co.uk/sch/i.html?_odkw=kenmore+microwave&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.H0.Xkenmore+microwave+motor&_nkw=kenmore+microwave+motor&_sacat=0
Aug 11, 2014 | Kenmore Microwave Ovens
My MMV4203DQ00 micro was installed on Sept. 3, 2010. For the last week, the turntable will not turn.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Oct 10, 2010 | Maytag Appliances Over-the-Range Microwave...
Mod # JVM1653WO001 turn table not turning
On some microwave oven models there is a switch on the front panel that enables the user to turn the turn table on or off. If you do not see this feature on your front panel display, you probably have a problem with the motor that drives the carousel. This problem is commonly caused by a turntable motor that has worn out and needs replaced. The following link explains how to access and replace one:
http://www.fixya.com/support/r3555716-replacing_a_turntable_motor_on_a_microwa
This is a very simple repair, that usually is not expensive. The motor usually averages about $35 - $40, but the price also depends upon the model. This repair can also be performed on an over the range model microwave oven WITHOUT uninstalling it.
I believe your model number is actually "JVM1653WD001". This is the closest number I could find that compres to the number you provided. You can usually purchase replacement parts at the any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites listed offer helpful exploded view diagrams to assist you in parts location/identification. If the model number is correct, the part number for a replacement is WB26X10038. You may also consider replacing the turn table shaft. This is what connects to the turntable motor and the carousel plate rests on. The part number is WB06X10138. If you have any questions, please let me know. I hope this helps you.
Jan 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Turn table doesn't turn
Is the plate engaging the drive?
Jun 15, 2009 | Kenmore 63792 Microwave Oven
TURN TABLE QUIT WORKING
take down the bottom panel and replace the turn table motor p# wb26x10038
Mar 20, 2009 | GE JVM1631 Microwave Oven
Microwave Oven EM-804T
You need to trace the power feeding the high voltage transfomer. Because the table doesn't turn, it implies that a door switch or safety interlock is the problem.
Jan 01, 2008 | Microwave Ovens
Microwave Ovens Logo
88 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
