Question about Cycling
Trying to change pedals on a kalin atb ht 100 mtn bike. I don't know how to seperate the pedals from the frame.
3 Suggested Answers
SOURCE: polaris rmk mtn bike or victory vegas low mtn
The Polaris RMK and Victory Vegas Low are the exact same bike with different colors and names.
They are made by Ming Cycle in Taiwan and are distributed by an American company-----Cycle Force Group.
The Polaris and Victory are Ming's top of the line dual suspension mountain bike, they have upgraded wheels, front disk brakes and 19" frame. If color doesn't matter to you, then the Victory Vegas Low is usually the better deal.-------Can be found on Amazon, Wall mart, Miejer.
The Polaris and Victory generally have the best reviews and ratings of any dual suspension mountain bikes priced below $250
Posted on Dec 01, 2010
dunnbiker
  • 8546 Answers
SOURCE: What are the threads and
The make of the bike does not define the crankarm on it which might define the spec of the threaded hole.
A simple web search for "bicycle pedal thread pitch" leads to..
http://www.sheldonbrown.com/gloss_p.html
Look for "pedal threading"
Posted on Aug 19, 2011
I need help identifying my kalin bike through its serial number
Kalin only makes components/parts. No way to ID from just serial number. See my tip for more info: How to determine the year value etc of your bicycle
Nov 06, 2016 | Cycling
Mongoose Ledge 2.1 pedal thread size
Measure the threads on the crank. Use or borow a pair of calipers. Measure with two threads as the outside edges to get proper diameter.
Apr 17, 2014 | Cycling
They stole my bikes pedals and I want to know what size they are to buy them?
Being a mtn bike it probably had flat pedals or lock-in SPD. Either way, pedals dont come in sizes, the shoes do. A pair of pedals will fit ANY bike, just select the type you want. Just be careful when screwing on, there is a LEFT PEDAL and a RIGHT PEDAL. They screw on in oppposite directions.!
Mar 29, 2013 | kawasaki 73026-9 KDX126FS Dual Suspension...
: Id like to change pedals of my mountain bike, which type should I prefer?
There are so many types of pedals. I recommend that you'll get a pair that you know and you are comfortable with. Or you can also check for reviews on pedals and take the ones with the highest rate. However, you should remember that what's fit some people will not necessarily fit you...
Check this link: http://www.vitalmtb.com/product/category/Flat-Pedals,20
Jan 14, 2013 | Cycling
I need to know what kind of crankshaft does a mongoose men's melee have?
Ya mean BOTTOM BRACKET? Probably something at the low end of Shimano. They don't publish the minutae for their department store bikes.
You could ask Mongoose directly or take it your Local Bike Shop and have them determine the answer (which is recommended in Mongoose's manual if you want service on a 3-piece crankset anyway).
http://www.mongoose.com/usa/usaeng/mtn/man_inst
http://www.mongoose.com/mtn/ask-mongoose
Sep 21, 2011 | Cycling
What are the threads and pitch for a Mongoose Mtn. bike pedal - Right side?
Aug 19, 2011 | Cycling
My rear tire is not turning when moving the pedals. The gears change but the tire is not spinning. I think it has to do with that plastic cover near the cogs, but not sure how its suppose to be.
Take the rear wheel off the ground (you could flip the bike upside-down to do this) and try to spin the pedals with your hand. Try spinning it backwards and forwards while you adjust the gears. ...If you adjust the gears while the chain is not spinning, the chain could get jammed. This could be your problem.
If that's not it, then try grabbing the wheel itself to see if you can spin it with your hand. If you cannot, then it might just be hitting the bicycle frame or the brake pads. See if you can find the spot where that is happening. If you can, then try to adjust the wheel in the frame by loosening the nuts or the quick-release lever (just push it away from the frame) that holds the wheel on to the bicycle frame... then wiggle the wheel around just a little to see if you can align it so that it is no longer hitting anything. Be sure to either tighten the nuts or push the quick-release lever back towards the frame when you are done. (Don't wiggle it too much unless you want the wheel to come out of the frame!)
If neither of these things work, you probably need to take it in to a bike shop. Most shops will give you a free estimate- they should tell you what is wrong, as well as how much it would cost to fix it.
Aug 12, 2011 | GMC Denali 700C Road Bike
What are the hardware differences between hybrid and mountain bicycles? How feasible is it to go from mountain (fat tire) to hybrid (thin low drag tire) functions? Can I just change the wheels or is it...
Some of this will depend mostly on what type of bike youre talkin' about here. Some cruiser/comfort type bikes will have the exact same rim size as nearly all mtn bikes and will swap with no problem but a 26 and 700 size wheel is NOT the same and there is NO compatibility between tires or frame of the bike including the fork. On a standard 26x2.1 size mtn tire the smallest you could go to is a 26x 1.50 that will fit on that wheel. if you have a French 26x1 3/8 size (S6) tire then the answer is the same....NOT compatible with anything 26" whatsoever. You cannot change the wheels either depending on the frame/fork you have. All you need to do is change the tires and keep the wheels! Any hardtail mtn bike will work fine as a commuter bike if you change the tires to a thinner and smoother tire for less rolling resistance.
Dec 16, 2010 | Cycling
Gear cable snapped leaving nipple and tiny bit of cable in the break lever and gear change mechanism. Unable to operate.How do I take it to bits?
Remove the barrel, which is in your brake lever and insert a new cable. If you don't have the tools, just go to your local bike shop and have them do it, it shouldnot be expensive. It is a minor repair and your life depends on it being done right.
Oct 04, 2010 | Shimano Brake Cables Atb Mountain Bike...
Polaris rmk mtn bike or victory vegas low mtn bike. Which is a better buy found them both for around the same price
May 13, 2010 | Victory VegasLow 26 Men's Dual-Suspension...
Cycling Logo
189 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
