Question about Avanti EWC28 Wine Cooler
Wine cooler has no light or power working it simply shut down
  • 472 Answers
You want to check power coming into unit... do you have power at the switch... there was alot of issues a ton etime with there power control switches and thermostats... check incoming power to unit and see if the switch has failed... also these units have small controls on them that will fail from time to time. you are going to have to see where power has failed at.
Posted on Jan 03, 2011
Vinotemp wine cooler just stop working.
Ok check the power supply input. Assume you have do e that and all ok. More than likely it could be a thermostat or compressor gas leakage. Has the compressor been running more than usual before it gave up working. Check for rust on the internal coils as sometimes they fail. Depending on what you paid for the wine cooler it may be cheaper to simply replace it. Can highly recommend Delongi 145
litre bar fridge, after replacing several cheaper brands and it is very reliable and cools really well though they are not at the cheap end of the market. You get what you pay for with appliances. Best of luck resolving the problem but if the wine cooler no longer is getting cold but the compressor continues to run, you can bet that it's out if gas from a leak in the internal pipe work and generally not worth attempting to either locate and or repair.
Apr 28, 2014 | VinoTemp (VT60GNV) Wine Cooler
Do I need a wine cooler to store my wines or can I store them in a normal refrigerator?
The purpose of a wine cooler is to store wines at their proper temperatures in a proper manner. Wine coolers are set to higher temperature ranges than other systems simply because wine should not be kept as cool as other beverages.
Jul 31, 2012 | Furniture
Unit has been operating in a wine closet and just stopped working it there anything I should check or clean? swaney167@aol.com
does the 'closet' have any ventilation? if not the unit could have overheated and shut down or , worse, burned up the motor. any 'electric smell to it? under the unit, should be a fan, it that stopped it will not cool. look for lint build up under the unit or around any air vents. How old is the wine cooler? can you get any info from the Wine cooler's mfg web site? www.danby.com/products/wine__beverages -
Dec 26, 2010 | Danby DWC440 Wine Cooler
Power surge caused wine cooler to quit cooling
Power surges, spike and brown-outs are a nemesis to small refrigeration units. The capacitor for the compressor likey was affected and possibly the start components in general, especially if the unit was operating when the surge occured.
Jul 20, 2010 | Haier BC112G Wine Cooler
Ice build-up on GE ZDW24A wine cooler cooling coil
Probably the thermostat is bad , you can bypass it by putting together the two wires from the thermostat and if the unit starts working ,replace the thermostat ;only do this if you havesome knowledge of electrical work and be very carefull.
Nov 04, 2009 | GE ZDW24A Wine Cooler
2 mos old. simply stopped working. no power at all to lights, motor ,etc.
check if you get power by the motor if no power change the thermostat
May 13, 2009 | Avanti WCR683DZD Stainless Steel Wine...
Vinotemp VT-16TEDS has light on but doesn't cool
First check the grating over the fan in the back. If it is covered with dust, there won't be enough air flow and the unit won't cool. Clean the dust off and see if it cools back down. It may take a long time to cool down if it is full of wine, so I recommend taking the wine out to test if it works.
Jan 17, 2009 | VinoTemp VT24-G 24 Bottle Wine Cooler
Avanti EWC28 Wine Cooler Logo
231 people viewed this question
Top Avanti Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you an Avanti Furniture Expert? Answer questions, earn points and help others
