Question about Samsung PCH521R 52" Rear Projection Television
Hello, After I've changed the stk's on a rear projection SAMSUNG TANTUS 42" it worked fine for a couple of weeks, then started to had a convergence issue during the first 1 or two minutes after turned on. Now it simply won't turn on jus makes a constant funny noise. It could be a wrong stk's model? thanks
  • lintsui_r Jan 06, 2011
    Thanx curtis, I´am not familiar with tv´s and to be honest I don´t know what do you mean with "the lamp" I can do a little more research but I still appreciate your guiding here.
    Best Regards and thank you very much.
  • lintsui_r Jan 14, 2011
    well, the new STK´s i´ve just installed are 392-040. I will check those resistors then the stk´s.
    New Friend:
  • 90 Answers
That noise is the lamp trying to turn on but it is probally burnt out so you may need to replace the lamp.
Posted on Jan 03, 2011
  • Samsung Master
  • 5,138 Answers
You could have STK IC that is defective causing problem, Set will shut down if you have Bad IC.
Mats Electronics is who I order my ICs from 1-800-628-1118
Posted on Jan 06, 2011
  • ladywinn
    ladywinn Jan 14, 2011
    STK ICs you need to go by the number on old STKs 392-020?
    Also there is 2 resistors that need to be replaced they will be bad,located in front of ICs 2.7ohms or 3.9ohms
  • ladywinn
    ladywinn Jan 15, 2011
    This Model does not have a Lamp , it is projection that has 3 Tubes Red/Green/Blue.
    You have installed the correct ICs, So Where are you at Now? I have 3 pages of problems and solutions for the Fix in my Index Manual.
MY TV HAS NO POWER I CHECKED THE FUSE IT SEEMS
hello have you checked the glass fuse inside the tv it will be in the power supply beware if replace the and blows again the you have a dead short circuit
regards
shaun
Apr 09, 2010 | Samsung HCN4226W 42" Rear Projection...
I have a samsung hcn4226w no power at all even to power button.
Yes,the STKs can cause set to shut down, call Mats Electronics 1-800-628-1118
STK392-020
Feb 25, 2010 | Samsung HCN4226W 42" Rear Projection...
Samsung tantus blinking red light
you need to general service the whole unit. this will include re-soldering and changing some defective components from the board, which has been damaged through using from past years. my advice is to have a quotation from service tech and then think about repairing it..if it is better to buy a new one..
Nov 16, 2009 | Samsung PCH521R 52" Rear Projection...
My hcp4752 started smelling hot now the colors are
It looks like you have a problem on your convergence panel. Look for burned resistors near the STK-* IC's. One or more of the STK-* IC's may be bad. When the resistors get hot they smell but so do the IC's. You can replace the bad parts or you should be able to replace the entire panel then go thru a convergence alignment.
Jun 06, 2009 | Samsung HC-P4752W 47" Rear Projection...
Samsung hc-p4241w problem
Look for 2 Big black chips they will be together on convergence broad STK-392-110s,120s replace both ics.Use STK-392-180s
Mar 29, 2008 | Samsung HC-P4241W 42" Rear Projection...
Tv comes on and flick off in one minute
need to know the make and model number of the TV in order to help you.
Mar 13, 2008 | Televison & Video
Samsung 52" tantus pch521r convergence panel
I found a this SITE that carries that convergence assembly for your TV.
Good Luck.
Mar 10, 2008 | Samsung PCH521R 52" Rear Projection...
Red line fault
· Samsung parts for convergance problem
· http://www.partstore.com/Part/Samsung/Samsung/BP9500142E/New.aspx
Aug 07, 2007 | Samsung HCN4226W 42" Rear Projection...
Samsung PCH521R 52" Rear Projection Television Logo
42 people viewed this question
Henry  Thomas
Henry Thomas
