Question about Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine
Beeping Ice Machine
The problem with the ice machine is that it's beeping and not making ice...and the metal bar over the ice bin is in the proper position. hoshizaki km500mae ice machine makes ice but we have to reset it each cycle because it will stop and then beeps 3 times until it is reset.
  • Anonymous Sep 07, 2008
    1. expantion valve freezing
I have a Hoshizaki KM-250BAF that is making 3 beeps then pauses and them makes 3 beeps again. If I unplug the ice maker and plug it in it continues to make the 3 beeps. The manual does not mention anything about beeps. Can anyone help?
Posted on Aug 29, 2008
I have Hoshizaki 501 starup two secont and cut off automaticly ,than make one beep every 3 second,so i can not know what happening ,can you help me out!!!
Posted on Sep 22, 2010
Before calling for service, check to see that power is on and unit is correctly plugged into a live circuit. Check circuit breaker. If you need to reset breaker more than occasionally, call a well qualified technician for service.<a rel='nofollow' href="http://www.gatorchef.com/Icemakers-s/3.htm"> Equipment</a> should have its own designated circuit and not use extension cords.
Posted on Jan 31, 2009
    Director Badge:
    Uploaded 100 video answers.
  • Hoshizaki Master
  • 479 Answers
Posted on Oct 09, 2015
    Problem Solver:
  • 4 Answers
Float switch stuck open,water valve leaking,hot gas valve leakin,pump motor not pumping,TXV not operating properly,low refrigerant charge, or inefficient compressor.Beeps means you have had two consecutive occurances of the above problem. Reset machine and check the above items.
Posted on Sep 04, 2008
My hoshizaki ice machine KM-900mrf model beeps 3 times and stop making ice. After reset it starts, but stats beeping again after an hour.
Have a look at the side of the evaporator; there is a probe (thermistor) attached to it that tells the control board when to initiate the harvest cycle. make sure it's clean and attached properly and doesn't need replacing. If hitting the float switch initiates the harvest cycle it sounds like you have a blocked/ scaled water tube or switch housing. take off the bottom of the switch assembly (black rubber bit) and clean through to the water chamber. run a cycle of descaler before trying again.
Jul 04, 2015 | Hoshizaki Freezer Commercial Ice Machines...
Why isn't my Hoshizaki km 630 mkh ice maker not making any ice?
that could be a number of problems..is it making any beeps or flashing lights on the circuit board? Have you tried to reset the circuit boards reset button with the machine on. ? If the machine seems totally dead then the bin thermostat is most likely the problem..
Aug 02, 2014 | Hoshizaki Freezer Commercial Ice Machines...
The ice maker make too much ice
Too much ice is usually and indication that the bin thermostat is not functioning correctly. It has either come out of it's holder, is not calibrated properly, or has lost it function and needs replacing. The thermostat "Kills" power to the control board when Ice comes in contact with it and shuts the machine down. Hoshizaki says it should happen within 6-10 seconds of ice contact after the end of a harvest cycle. I would start there first.
Apr 09, 2014 | Hoshizaki Freezer Commercial Ice Machines...
How to reset hoshizaki ice machine
small white button on control board. press once to stop beeping. Very small but it is labeled and very hard to see.
Feb 09, 2012 | Hoshizaki Freezer Commercial Ice Machines...
My machine doesn't makt any ice and the macine is beeping.
Need to know the number of beeps as this is a code to tell you what went wrong with the machine.
Aug 01, 2011 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki ice machine beep 3 times, what is it stand for?
in the freeze cycle too long. Most common is the water valve leaking through. Second thing to check is for a stuck float switch.
Oct 18, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki ice maker am-50bae . Made ice regularily--- filled ice bin half way...next day-- all ice melted away with no more new ice? next day shut off for 3 hours now o new ice.
make a few quick checks. If there are water filters on the system, be sure they are not restricked. Could be clogged. Next, check the bin stat. It usually is mounted in the ice bin. If it breaks or goes bad, it shuts down the machine. Start there and let me know if I can be of any further help.
May 19, 2010 | Hoshizaki Freezer Commercial Ice Machines...
My Ice machine started beeping from the fuse last night and is not working
The beeping in ice machine is a code. Take off the electrical panel cover. Carefully look for and press the small reset button on the board. This will restart the machine. If it shuts off again call a service company out.
Oct 18, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Beeping 3 times every 3 seconds
The 3 beeps indicates that the unit was in the freeze cycle for 60 minutes. Causes: 1.) Water valve leaking, allowing water to continually enter the system. 2.) Float switch stuck, sending false signal to board. This indicates ice not being produced. 3,.) Low freon level causing long freeze cycle. 4.) Hot gas valve leaking thru causing warmer than normal evap plates=low production. 5.) Expansion Valve not feeding freon properly to evap plates.
Items 1 and 2 are the most common. Number 3 possible due to freon leak in the system. Number 4 and 5 are usually a very rare occurance.
Hope this helps ya.
Sep 05, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine Logo
1,336 people viewed this question
Top Hoshizaki Freezers Experts
Dennis Boxerman
Dan Webster
Dan Webster
Are you a Hoshizaki Freezer Expert? Answer questions, earn points and help others
