Question about Dimplex Heating & Cooling
My Dimplex duo500i is making a constant ticking noise? It sounds like a relay?
SOURCE: ticking and rattling sound
sounds like the problem is brake related. That ticking you're hearing is your front brake rotors, clicking against the sides of the brake caliper. As you speed up, the clicking will get faster untill you won't be able to hear it, (it's still there, it's just inaudible at such a rapid revolution) upon deceleration, you will notice it more prominently, clicking in rhythm to the speed of your wheel's revolution.
basically, It indicates your brake pads are worn down. Unfortunately the condition will get worse, louder, and the car will become extraordinarily more dangerous to drive as front braking will be compromised if the vehicle's braking conditions persist.
A qualified mechanic will setup the brakes, rotors, check for warpage, hone the rotors if need be, and be able to install a proper replacement pad.
Posted on Jul 10, 2008
emissionwiz
  • 76164 Answers
SOURCE: engine is ticking
MOST COMMON CAUSE IS WORN CAM FOLLOWERS, ALSO CALLED LIFTERS IN OLDER CARS.
Posted on Feb 12, 2009
TheMobilian
  • 8220 Answers
SOURCE: ignitors keep making ticking sound, all burners
Probably a spillage or boil over has clogged the burner and some of the liquid has dampened the shank switch mounted on the burner post. Get a shop vac and clean the burner. Wait a day or 2 and see if the switch stops. OR disable the ticky ticky by removing the bottom drawer and looking for the spark module. Remove one of the hot wires and tape it up. Light the burners like granny does with a match. LOL
Posted on Jul 17, 2009
dsakrison1
  • 65 Answers
SOURCE: Why does car make constant ticking noise from
The exhaust system on your car is stainless steel, and it heats and cools quickly, there is nothing wrong with this. all your hearing is the joints in the exhaust system expanding and contracting. My 2007 impreza 2.5 does the same thing. And when you turn car off the system is cooling off and contracting.
Posted on Oct 02, 2009
  • 11 Answers
SOURCE: Ticking sound when TV off
get a better tv
Posted on Oct 16, 2009
Hi, I have a Dimplex DUO500i storage heater and
Sounds like you heating coils burnt threw. how much did you pay for it? Might want to buy another.
Oct 29, 2013 | Heating & Cooling
2007 ford ranger 4 litre wont start. No electrical power at all. Fuse box ticks.
Sounds like a relay. Open fuse box and feel which relay is ticking, they are normally black square boxes. Isolate the one that is making the noise, you may be able to swap it out for another relay that is not being used.
Aug 06, 2013 | Ford Ranger Cars & Trucks
Battery died but when opened up to check battery there is a ticking sound
Yes one of the relays could be draining the battery.
I would open the fuse and relay boxes and try to find where the noise is coming from. If it is a relay, pull it out and see if the noise stops.
Jan 15, 2013 | 1999 Toyota 4Runner
My ac goes off and on again and a clicking sound on passanger side
sounds like a relay is dead...the clicking sound is the relay turning on and off again...like "tick, tick tick, tick"? there is a relay behind the plastic paneling but you would have to investigate to find out which one it is...just pull off the paneling where you hear the noise and follow it to the relay that is clicking...
Jun 10, 2012 | 1990 Nissan 300ZX
The blinkers in my 2003 f250 super duty wont work until an hour after it has ran and they will only flash once unless i put on the breaks. After they have been working something inside will make a constant...
It sounds like you need a new flasher relay. You can get it at your local automotive store. Make sure you get one that is heavy duty enough. If you often tow a trailer with lights, you will want the heavy duty one.
Feb 18, 2011 | 2003 Ford F250 Super Duty Crew Cab
Ticking noise
It is part of the waste gate just above the gas tank. It periodically checks for leaks and pressurizes and releases. Gives a ticking noise when it does this. Not a problem and GM is aware of this and said its normal on our cars.
Jun 02, 2008 | 2007 Chevrolet Cobalt Coupe
Heating & Cooling Logo
62 people viewed this question
Top Dimplex Heating & Cooling Experts
paulcarew
ashburton
Kory Ronning
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
