Question about Ovens
I have a Jenn air oven. Model KEDC205BWH. It is giving me an F3 error code.
  • 4,323 Answers
Hi
Error F3 means a loose/broken wire on the oven temp sensor or the sensor is bad and should be replaced. To solve this issue start by checking the oven temp. sensor for 1100 ohms, if the rating is more then that then check the control and door switch and replace the part that is bad. Hope this helps...please post back for further assistance.
Daniel
Posted on Apr 13, 2011
Top electric oven will show an F3 error after being turned on and will beep. Botton oven works fine. Jenn Air electric oven model JJW927AAW. Serial number 11993640WO
HI thanks for your question.. code F3 says to replace the oven sensor, located in the oven. top left corner. Replace the oven sensor. Thanks
Dec 17, 2010 | Jenn-Air Ovens
After self cleaning process oven door would not unlock replaced display panel F3 error fan runs constantly lower unit still works upper unit still will not unlock
F3
or
F4
Shorted or open oven temperature sensor
(RTD) Check sensor harness and harness connection
between oven sensor and oven control. Replace oven temperature sensor (RTD) if
wiring is ok.
Dec 04, 2010 | Jenn-Air WW30430P Stainless Steel Electric...
I have a Jenn Air Oven that quit working. It
HI - The code described, F3 then F2 both correspond with indicated failure of the temperature sensor. This is a fairly inexpensive part and is easy to replace. The normal resistance of the sensor is 1000-1100ohms. Worth fixing for sure. Complete model number from tag on unit will be needed to get correct part. Let me know if this info helps- have more if needed- Thanks-  Ed
Mar 16, 2010 | Jenn-Air Ovens
Jenn-air SVD48600P oven will not work / F3 error . I recently replace the expense control / clock unit on my oven because it would not heat. This was advice from repair person. Once replaced the over...
Hi jmhostetler9,
This F3 that keeps flashing on your oven is caused by a shorted or open oven temperature sensor (RTD). To fix this problem check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central. Just get your model # ready when you call.
Hope this helps.
Thank you for using FixYa.
Dec 22, 2009 | Jenn-Air JJW8530C Expressions Collection...
Jenn Air Code F3 continuous beeping
HI thanks for your question.. code F3 says to replace the oven sensor ,located in the oven. top left corner. replace the oven sensor. thanks the appliance doc. please rate my answer .
Jun 22, 2008 | Jenn-Air JJW8530C Expressions Collection...
Ovens Logo
95 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
