Question about Electrolux Dryers
Error E08 on the panel of my drier T3530. Why this error appear?. What is the solution?
2 Suggested Answers
SOURCE: ELECTROLUX T4130 (Compass Control) We
Hi!
Just reset one of the thermostats, inside the dryer, on top of the heating elements.
Works?
Posted on Feb 04, 2011
E08 on my dryer
Search online for "error code E08 + your make & model"
Aug 23, 2015 | Hoover Dryers
Tip
Xbox 360 RROD E08 / error code 0020
x 360 RROD E08 / error code 0020x 360 RROD E08 / error code 0020x 360 RROD E08 / error code 0020
on Mar 25, 2010 | Microsoft Xbox 360 Console
What does it mean when your Samsung flat top oven and broiler will not work and the code reads E-08
E08 Error Message on a Samsung Electric Built-in Oven:
The E08 preheating error code appears if the set oven temperature is not reached within 50 minutes. If this code appears, the reason might be due to overheated thermostats, a defective heater or a defective relay; in which case a repair will need to be arranged.
However, if food has been put into the oven during the preheating time that may cause the error code, since the presence of food cools the oven and so it doesn't reach the right temperature. The error message can be removed by turning the oven off and turning it on again.
To prevent this error code from happening again, the oven should not be used during the preheating period. The preheating period ends just after the sound signal and the icon in the display have turned off. When the oven gives the signal, it's close to the set temperature and your food can be put in.
Apr 14, 2015 | Samsung Kitchen Ranges
Throwing code E08. How do I fix it
I Googled my washer to look up some stuff i couldn't find for my own washer other than here and i did not see E08 as an error code in my manual or on any of the other websites but i did see F08 followed by E01 which was a water supply error:: and you have to check for proper water supply:: check the hoses and the faucets to be sure that the screens are not clogged and the hoses are not kinked to clear the code touch the power button once then touch the power button again to restart the washer if the code appears again the manual says to call for service to send out a service tech.
Jan 09, 2014 | Maytag MHW3000BW Maxima X Front Load...
We have an electrolux Wascator T3530 . It is showing a fault F1 on the display. What does this mean?
First thing you can try is to unplug the dryer for fifteen minutes or so. If that still bring up the error code then it is your board inside your dryer.
May 03, 2011 | Electrolux Dryers
ELECTROLUX DRYER T4130, error code E08 show on panel. have tried turning power on and off, but still the error code E08.
Dryer had been overheated (clogged or damaged air filter). Reset 3 thermo-fuses (small red buttons): 2 under top cover and 1 under back side round cover
Jan 02, 2011 | Electrolux Dryers
ELECTROLUX DRYER T4190, error code E08 flashing on panel. have tried turning power on and off, but still flashing. problem?
How to solve this problem
Aug 14, 2010 | Electrolux Dryers
Hoover error E08
hi I had this fault, google said it was tachometer fault. the e08 fault on my hoover optima was not the tachometer, i checked it, but the fix was very easy, the motor brushes were worn out and i changed them for 10 quid, I made a video of it its on youtube http://www.youtube.com/watch?v=xYn-f78GB4U and it shows you how to test the tacho and how to change the brushes, hope this helps someone
Oct 02, 2009 | Washing Machines
Dryers Logo
119 people viewed this question
Top Electrolux Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
John
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
