Question about Heath Zenith Journeyman 270 Degree Motion Sensing Security HD-9250-WH-C
How do you replace the sensor on a Heath-Zenith SL-5411 2 Light Motion Sensing Par Flood Security Light?
3 Suggested Answers
fisherman816
  • 66 Answers
SOURCE: How do I replace the Halogen bulb on the Heath
Unscrew the bulbs counterclockwise with youre finger tips.
Posted on Nov 13, 2009
  • 250 Answers
SOURCE: need to wire motion sensor to light, have three
The black wire goes with the black house supply wire, and the red wire goes with the black wire from the lighting fixture. The white wires all connect together.
Posted on Feb 22, 2010
Lights flash on and off
Very common issue with motion sensing lights. You can either replace the light sensor which is available at most hardware stores or you can disable the motion sensing feature and just have an on-off light. To disable the sensor, (turn off the power!) unscrew and remove the light sensor (it is the reposition-able box under the light.) It depends on the particular light, but you usually just match up the wire coming into the light from the house and the wire from the bulbs and connect them with a wire-nut.
Jan 07, 2014 | Heath Zenith SL-5318-WH Dual Brite Motion...
The LED flashes, but the lights won't come on. Do I need to install a light shield. The sensor is mounted in a well shaded area 10 to 12 feet above ground. There are landscape lights beneath the sensor are...
There are settings on the sensor itself. Should be a dusk to dawn setting that will keep it off during those times and then function at night. as far as not working I would first suggest setting the sensitivity. Disrupting to power could have reset this.
Oct 15, 2013 | Heath Zenith Heath/Zenith SL-5411-WH Heath...
Why does motion sensor not fully illuminate a fluorescent 4' light?
many motion sensor do not work with fluro tubes as stated on the fitting instructions as it has the same affect as you turning the switch on and and on to change from auto to manual operation
the problem comes from the ballast and the starter operation
Jul 04, 2017 | Heath Zenith Occupancy Motion Sensor Wall...
I need a download for the instructions that came with a Heath/Zenith SL-4142-B motion-sensing porch light.
I was looking for the exact same thing today and found out it is the same as the SL-4152-B instructions:
http://heath-zenith.hcents.com/data/manuals/595-5578-09.pdf
Hope that helps. Enjoy.
Jan 02, 2011 | Vacuums
Looking for a wall motion switch that has a 180 degree side view
Try the GE Motion sensing switch found at Wal-Mart on the electrical asile. I believe it is made by JASCO Products. I use this is my garage and closets without an problems.
Cheers,
GeekyGuru
Dec 29, 2010 | Heath Zenith SL-6106-IV Motion Sensing...
Need to wire motion sensor to light, have three wire(red, black & white), need to know how to hookup wires? my model no. is :-heath zenith sl-5318-bz-a
Feb 22, 2010 | Heath Zenith SL5316WHB Replacement...
Outdoor sensor won't work
Hi, Remove the cover and check for power. If you have power,replace it.No power, look for a tripped breaker. Good Luck,
Shastalaker7
Nov 14, 2009 | Heath Zenith SL-6106-IV Motion Sensing...
Open Questions:
See all Heath Zenith Journeyman 270 Degree Motion Sensing Questions
Heath Zenith Journeyman 270 Degree Motion Sensing Security HD-9250-WH-C Logo
127 people viewed this question
Top Heath Zenith Home Security Experts
Mike
Domenico Grillo
Are you a Heath Zenith Home Security Expert? Answer questions, earn points and help others
