Question about Microwave Ovens
Lost instructions, how do you use the Breville Duo Sandwich Master please? I would like to make a cheese toast sandwich.
MicrowaveSvc
  • 9047 Answers
SOURCE: will not heat
The loud pop was almost certainly the high voltage diode going bad. To find parts, I suggest you call the number on your owner's manual or check with the store where you bought it. Sunbeam may not make this part available, so be prepared. Maybe they have authorized servicers in your area. Ask them about that. Good luck.
Posted on Sep 22, 2007
  • 135 Answers
SOURCE: Took 12 minutes to heat up a roast beef sandwich (not frozen).
Hi there!
My guess would be that the magnetron is faulty. If you have a testmeter, unplug the terminals on the magnetron and measure between the body of the magnetron and either one of the terminals. There should be no reading. If you have a reading it is faulty. Then also check the High Voltage Cap. Cylindrical shaped metal item with two terminals. I would replace the Cap anyway. It's 9 Years old. Conclusion: Magnetron is faulty, runs Hot and then switches off the machine on the Thermal switch(located on top of the Magnetron). No problem with the food. Be sure to unplug the Mains before you check it out. The Cap may also still be charged so do take precaution. Good Luck,JUS004
Posted on Feb 29, 2008
  • 234 Answers
SOURCE: microwaved a sandwich from Wendy's-apparantly it had tinfoil wrap
There is fuse in the back somewhere around where the cord comes into the unit.My guess the fuse is blown
Posted on Mar 15, 2009
  • 8909 Answers
SOURCE: need instruction manual for
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers, for spare parts and service and Installation Instructions as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Posted on Dec 23, 2010
  • 5160 Answers
SOURCE: I have a Goldstar Multiwave
You can defrost items by time but not with the Q-Defrost or Auto-Defrost functions. (I've found it best to defrost ground beef with timed intervals at power 1. Auto Defrost by weight usually starts cooking the meat. You will need to try it a few times to see how long and what power to use.)
Manage My Life has the manual here: http://www.managemylife.com/mmh/owner_manuals/52491/GOLDSTAR-Countertop-Microwave-L1005548?brand_name_search=MA1011W . Sears Parts Direct may have a copy that you can order. (I didn't see it listed but didn't check the entire set of parts lists.)
I hope this helps.
Posted on Jul 10, 2011
When turning Fan on (any speed), top vent grille blowing lots of air, but not pulling air underneath
some microwaves vent to the exterior. check outside for a vent. If it is a recirculating model, perhaps the filters are plugged, the vent pathway is blocked (packaging material) or a loose panel at the back so that the exhaust fan air is leaking out somewhere else. I don't know what else it could be unless the fan is loose on the motor shaft and the fan motor is running but the fan blades are not moving air.
Nov 15, 2014 | Microwave Ovens
Instructions
The instruction manuals are readily available online in PDF form and are free.
Aug 17, 2014 | Breville Quick Touch Microwave Oven,...
I have bought a second hand breville fan assisted breadmaster, but it has no manual - can you help please?
Assuming its a BR1 try this: http://safemanuals.com/user-guide-instructions-owner-manual/BREVILLE/BREVILLE%20PART%201-3-_E
hope this helps!
Jul 24, 2011 | Microwave Ovens
I am looking to buy a sandwich maker like the 17936 and set it on timer for the morning so they are ready for when I wake up and go to work - does this russell hobbs model heat up and then stop heating...
Here are a few links to some information about the Russell Hobbs Model 17936 Sandwich Maker:
http://www.amazon.co.uk/Russell-Hobbs-17936-Sandwich-Maker/dp/B002MRS1NM
http://www.reevoo.com/p/russell-hobbs-2-sandwich-maker
http://www.sonicdirect.co.uk/catalogue--iID--5785--russell-hobbs-17936-2-slice-sandwich-toaster-in-brushed-stainless-steel.php
I don't think you will find a small sandwich maker with the type of automatic timer you are describing. Most full size digital ovens have that function, but very few smaller units like the 17936.
Also, would it not be a bit impractical to leave a sandwich with perishable toppings in the machine overnight in order for it to begin cooking in the morning? Any kind of meat product left out overnight unrefrigerated may become dangerously contaminated and spoil.
For all the time these machines take to heat up, you might as well just get up 5 minutes earlier in the morning and prepare your sandwich then.
Good luck though either way.
Jun 14, 2011 | Microwave Ovens
Need instruction manual for Nordic ware microwave micro max hamburger/sandwich grill
I hope this helps.
Dec 23, 2010 | Microwave Ovens
I have microwave Oven with grill only and no
Sorry this isn't a forum for helping you out with receipes.
A grill means you can use it put cheese on bread (toast eventually) or to give COOKED meat or fish a brownish effect when the grill function has been activated.
Jul 25, 2009 | Microwave Ovens
Microwaved a sandwich from Wendy's-apparantly it had tinfoil wrap
Mar 15, 2009 | Kenmore 62622 Microwave Oven
Hi there!
Feb 29, 2008 | GE JE1640 Microwave Oven
Microwave Ovens Logo
111 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
