Question about Sentry Safe Keep Safe Wall Safe, 7150
I got a keep/safe wall safe and i wanna change the combo number but cant find the model number and i dont know the combo is 0 left 2x past 0 to 80 right 1x past 80 to 55 left to 2 can you tell mehow to change the combo thanks
joboo1
  • 257 Answers
SOURCE: get new combo on senry dial safe
Hi, There is only one way, and that is to send a letter with the serial number to Sentry and if the info matches who is supposed to own it, they will send you the factory default combo to open it. Good Luck!
Posted on Feb 14, 2009
DerStrom
  • 103 Answers
SOURCE: Family member passed away and left numbers
Begin by turning the knob in a complete circle a few times. Then, turn the dial to the LEFT to the first number of the combination, then RIGHT to the second number, and back to the LEFT to the final number. If the safe has more than three numbers, just keep alternating, starting by turning the knob left, then right, and so on. I am sorry for your loss, and I hope this post has helped you. Sincerely, Der Strom
Posted on Apr 12, 2010
Testimonial: "Thanks for your advice...We will try it out. Have a good day...."
SOURCE: Changing the combination
These sentry safes dial combinations are not built to be changed as they have no key change hole. Switching the order of the tumblers could be done by a trained locksmith. I would suggest buying the electronic sentry safes as these safes can be reprogramed.
Posted on Aug 05, 2010
SOURCE: Have Sentry 1250 safe. I have the combo but can't get it to work.
A1 locksmith will tell you.
If your safe doesn't have a key, skip Step 3.
Turn the dial to zero.
Insert your sentry safe key and turn it until the plunger pops out.
Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
Turn the dial to the left to the last number (stop the first time on your last number).
Pull the handle down; cracking sentry safe open.
Posted on Aug 09, 2010
SOURCE: NEED TO OPEN A SENTRY SAFE BUT DON'T KNOW WHICH
Locksmiths advise If your safe doesn't have a key, skip Step 3.
I have combo but don't know right or left and how many times to go pass numbers or not and do I go back to 0
if you have combo then start at 0 turn clockways (right) tthree times stopping on first number then counter clockways (left) two times stopping on next number then clockways (right) to last number this should open safe . Good Luck
Sorry I may be mistaken on the directions instead of Right,Left,Right do the opposite Left,Right,Left sorry for the mistake. Good Luck
Feb 11, 2016 | Home Security
Can't remember 1 of my combo numbers
That should be simple. Just do the other numbers and start with 0 for the one you have forgotten and keep trying the combination, changing that number each time you try the combo until you find the right one.
Nov 08, 2014 | Home Security
Have old 50 yrs weilink safe have comb. not opening
You could have the correct combo... but not be using the correct pattern. Here it is.
Turn dial several times to the right to clear it...stop on 0
Turn dial to left (ccw) 3 times past the first number and then stiop on that number the 4th time around.
Turn dial to right 2 times past the second number stop on that number the 5rd time around
Turn dial to left 1 time past the 3rd number and stop on the 2nd time around.
Turn dial to the right until it latches (could be the last number or the drifted number) until it stops
Twist handle and open door.
NOTE:If this fails to open it then its possible (after years of use and w/o service) that the numbers 'drift' from there original spot. You can try to find this out by applying pressure to the handle (which engages the 'fence' inside and rubs it against the wheel pack). While applying light pressure rotate the combo dial and where it locks up should be one of the numbers... check this against your 'correct combo' and see how they match. If it's off then all of them are off. You'll need to determine the 'new' combo by drawing the dial with the numbers use the fence located number (usually the first or last) and then reverse engineer the combination. You may also want to grab a book on safes/ safe-cracking to understand the mechanics if this doesn't make sense. Good luck!
Jun 03, 2014 | Safe International Digital Electronic Safe...
I have a year 1897 safe i had it open once but now it is refusing to open what should i do?
You mean you locked it and forgot the combo? Or it just refuses to cooperate? My safe is real finicky, it has to be perfect or it doesn't budge. I could give you the combo and you still couldn't get it open.. Anyway, try this, providing you have the combo, turn right 3 or 4 times to clear the dial, stop at the first number, then go back 2 full turns past the first number and stop at the second number, go right again past the second number and stop at the third number, then left till it latches on the last number. If that doesn't work,, try it with your numbers just a digit or 2 off, try one at a time, then try 2, might take a while, but it will be worth it. If you get it open, I would get the back off the dial and confirm the numbers, then right them on a magnet and stick it to the bottom of the safe. Check it out.
May 22, 2010 | 1995 Jeep Grand Cherokee
Family member passed away and left numbers behind...but we dont know how to open the safe. Its a Sentry 1250 Model # 1963131
Apr 12, 2010 | Sentry Fireproof Safe
I CANT OPEN MY SENTRY FIRE-SAFE MODEL:DS3431 SAFE. I KEEP TRYING TO DO WHAT THEY SAY DO TURN DIAL TO ZERO, TURN KEY ETC; NUTHING IS WORKING. CAN U HELP?
Make sure that the key barrel is all the way out. Then replace this example code with your factory code and try it
Example combination: 70-55-05
  1. Do two rotations to the left stopping at 0.
  1. Do two rotations to the left (Anti-clockwise) on the third time past 0 go to your first number.
So – 0 to 0, 0 to 0, 0 to 70
  1. Do one rotation to the right (clockwise) on the second time round stop at your second number.
So – 70 to 70, 70 to 55
  1. Turn directly from your second number to your third number heading to the left.
So – 55 to 05
  1. Push down the handle.
Dec 13, 2009 | Sentry Fireproof Safe
S3517sentry safe need to reset
Press: Program 2x, enter a digit user-code (green led remains on), enter the 5 digit user pin (of your choice except 00000). After 5 digits entered, the green LED turns off.
May 11, 2009 | Sentry Fireproof Safe
Brinks safe model # 5054
go to honeywellsafes.com apparently brinks was bought out
Jul 28, 2008 | Computers & Internet
Brinks fire resistant safe model 5059 instruction manual
To bad you dismantled. Here is the turning sequence:
General Turning Sequence Instruction NOTE SAFE MODEL 5054/5055/5059/5080/5081/5084/5111/5190/5195/5575/5700/5702.
Combinations consist of FOUR (4) positions (numbers).
BEFORE YOU START
Before you begin, please clear all settings by turning the dial CLOCKWISE (to the right)
three times. We also recommend to try the procedure with your safe door open first. Then
follow these steps:
TURNING SEQUENCE
1. Start the dial on 0 (zero).
2. Turn the dial to the RIGHT, passing your first combination number FOUR (4)
times and stopping at that number on the fifth time around.
3. Turn the dial to the LEFT, passing your second combination number TWO (2)
times and stopping at that number the third time around.
4. Turn the dial to the RIGHT, passing your third combination number ONE (1) time
and stopping at that number the second time around.
5. Turn the dial to the LEFT, to the last combination number and STOP.
6. Insert the key in the cylinder lock and turn RIGHT to open.
Your safe should now be opened.
Jul 16, 2008 | Computers & Internet
I can't seem to unlock my safe Sentry 1250.
Also make sure you are executing the combination in the right steps... For mine (a three-number combo), these are the steps that work:
* turn the knob to the LEFT, pass 0 at least THREE times and stop at the first combo number
* turn the knob to the RIGHT, pass 0 ONCE and stop at the second comb number
* turn the knob to the LEFT and go directly to the third combo number (do not pass 0, do not collect $200)
Feb 25, 2008 | Sentry Fireproof Safe
Sentry Safe Keep Safe Wall Safe, 7150 Logo
1,070 people viewed this question
Top Sentry Home Security Experts
Jim London
Jim London
Computer Repairing
Computer Repairing
 Brian Main
Brian Main
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
